    Hamburg (HVV) public transportation module - using realtime data
    hamburghvvtransportation
    8 Posts 5 Posters 7.7k Views 6 Watching
    • G
      georg90
      I’ve created a module for public transportation in Hamburg (Germany) which shows next trains/busses departing from your station. It’s using the HVV API with realtime data. Currently only train realtime data is working. It’s based on a modified version from Bangee’s SwissTransport module.
      I guess it’s only of use for very few people, but I wanted to share it anyway =)
      It’s still BETA and the very first working version, please be patient :)
      Find it on GitHub:
      [card:georg90/MMM-HH-LocalTransport]
      screenshot
      Also I added a small article on my blog on how to install and how to obtain an API key: https://lane6.de
      S 1 Reply Last reply Reply Quote 3
        shgmongohh @georg90
        @georg90
        Hie George90,
        is it possible to have also Deutsche Bahn trains in your module. For exampe all departures from Hauptbahnhof?
        Regards,
        André
        • G
          georg90
          You can check on www.hvv.de - If I go to: http://www.hvv.de/fahrplaene/abfahrtsmonitor/index.php and look for the HBF, I get all ICE etc. trains.For them there is no realtime information available :(
          If you want to see the DB trains, check out the module which uses the Google API.
            PaulB
            @georg90 This is so cool. Love it! Fun Fact I am moving to HH again in several months. Will use it then ;)
            • K
              killing joke
              Hummel Hummel georg90,
              thanks for you local-support.
              The link in your github description is old and doesn´t work anymore.
              You can use http://www.hvv.de/fahrplaene/abruf-fahrplaninfos/uebersicht/index.php instead which gives you 4 options to choose.
              Your MMM isn´t installed on my Raspi at the moment but as soon as I have a better understanding of my Raspi and the MM2 I will install it!!!
              Best wishes from Winterhude
                doubleT Module Developer
                I’m from Hamburg, too. Cool module. Can’t really use it right now as I’m rarely using the HVV, but I might check it out and maybe play around with it a little.
                  PaulB
                  @georg90
                  I am about to install it on my setup. Unfortunately due to the old link its not possible. Although you can ask HVV for a Geofox-API I am not quite sure, if it is the smoothest solution.
                  What do you think?
                  • G
                    georg90
                    What do you mean? Since there is no official (open) api as of now, you’ll need to apply for access. I don’t use the addon at the moment, but I think it should still work, maybe some adjustment needs to be done to work with the latest version of the api. I’ll pick this up soonish as I am currently gathering materials to create a new mirror for myself ;-) But I don’t know when I’ll be ready.
                    Edit: Just checked, there is an api. But the geofox should still work ;-) I will switch to the public when I will pick this up again.
