    Old LCD PC monitor
    20 Posts 3 Posters 16.9k Views 3 Watching
      birdy
      small update:
      I got the screen up and running (I forgot to switch over from the monitor body a small controll panel), unfortunatelly only via VGA. HDMI is definitely not working.
      Any idea:
      1. if I could connect RaPi to the monitor via DVI (micro HDMI DVI)?
      2. or is there a connector (micro HDMI VGA)?
      -> do I need a digital connection (hdmi) or analog (vga)?
      For me a good information for today is, I don’t have to buy a new 27 inch LCD panel :D
      Cheers
      birdy
      • T Offline
        tomyboy96 Project Sponsor @birdy
        @birdy why the micro Hdmi?
        I would recommend using dvi to hdmi since the Rapi will then recognise the cable directly and u won’t have to do any config to get the screen working propely.
        If you wanna use a hdmi to vga i used this:
        http://www.wish.com/c/557e6ed78fe81619f182a12b
        Worked really good after a bounch of configures in the Rapi.
          birdy
          @tomyboy96 - I have no idea why did I write micro HDMI (maybe I was playing with the micro SD adapter). But thanks for your remark! Adapter ordered (hope it will work). Next update in few days :)
          • T Offline
            @birdy I used some stuff from this site when i configured the Rapi (Y)
            https://www.raspberrypi.org/forums/viewtopic.php?p=269212
            Good Luck!
              birdy
              Hi guys,
              the new cable is working!!!
              alt text
              Now the easiest part: coding ;)
              Next update, when I get a keyboard from somewhere :D
                birdy
                there is also another challenge:
                alt text
                I would liek to get rid of these metal body. The side you can see shoud me glued to the plastic.
                What can I put between the curcuit and the plastic? Some small plastik tubes? Wood? Rubber? Should I then glue the boards or better (for the future) screw it to to the “legs”?
                How about grounding it? Needed?
                Cheers
                Birdy
                • T Offline
                  @birdy i used one of thease.
                  http://www.biltema.se/sv/Fritid/Friluftsliv-och-camping/Kok-och-vatten/Vattendunk-2000023717/
                  Easy to bend och drill in
                    birdy
                    you used a plastic water canister? In what manner?
                    • T Offline
                      @birdy i cut out flat pices that i drilled the board to.
                        birdy
                        so like this (side view)?
                        • T Offline
                          @birdy yeah, but i used velcro tape insted of glue
                            birdy
                            one question, which is bothering me: the controller plate has spot for grounding (the plate was connected with the metal body before via this “grounding spot”). Do I need to ground it e.g. with power supply or similar or I can leave the plate ungrounded?
                              birdy
                              So I got the MM up an running :)
                              alt text
                              back side:
                              alt text
                              Next steps:
                              1. MM configuration & understanding how it works
                              2. to shorten the wooden legs
                              3. to order + build a frame
                              4. put everything together :)
                              BR
                              birdy
                                birdy
                                Dear all,
                                next issue: to reduce the empty space behind the LCD panel, I bought a 90 degrees DVI adapter. But I have noticed, my plug was DVI-D and I bought DVI-I.
                                Question: I don’t want to wait a week for a new one, can I remove few pins (esp. the 4 on the left) on my own? see picture below:
                                Thx for your help!
                                Regards
                                birdy
