    Old LCD PC monitor
    20 Posts 3 Posters 17.0k Views 3 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @birdy
      @birdy said in Old LCD PC monitor:
      Any idea, what could be the problem?
      Your cat threw it down from the piano! ;^)
      Are you sure that your input is set correctly on the monitor?
      I would try it with another pc to eliminate the possibility that the Pi is not sending video.
      You can also try the DVI input. Again, making sure that the input is set to DVI when you try that.
        birdy
        small update:
        I got the screen up and running (I forgot to switch over from the monitor body a small controll panel), unfortunatelly only via VGA. HDMI is definitely not working.
        Any idea:
        1. if I could connect RaPi to the monitor via DVI (micro HDMI DVI)?
        2. or is there a connector (micro HDMI VGA)?
        -> do I need a digital connection (hdmi) or analog (vga)?
        For me a good information for today is, I don’t have to buy a new 27 inch LCD panel :D
        Cheers
        birdy
        • T
          tomyboy96 Project Sponsor @birdy
          @birdy why the micro Hdmi?
          I would recommend using dvi to hdmi since the Rapi will then recognise the cable directly and u won’t have to do any config to get the screen working propely.
          If you wanna use a hdmi to vga i used this:
          http://www.wish.com/c/557e6ed78fe81619f182a12b
          Worked really good after a bounch of configures in the Rapi.
            birdy
            @tomyboy96 - I have no idea why did I write micro HDMI (maybe I was playing with the micro SD adapter). But thanks for your remark! Adapter ordered (hope it will work). Next update in few days :)
            • T
              @birdy I used some stuff from this site when i configured the Rapi (Y)
              https://www.raspberrypi.org/forums/viewtopic.php?p=269212
              Good Luck!
                birdy
                Hi guys,
                the new cable is working!!!
                alt text
                Now the easiest part: coding ;)
                Next update, when I get a keyboard from somewhere :D
                  birdy
                  there is also another challenge:
                  alt text
                  I would liek to get rid of these metal body. The side you can see shoud me glued to the plastic.
                  What can I put between the curcuit and the plastic? Some small plastik tubes? Wood? Rubber? Should I then glue the boards or better (for the future) screw it to to the “legs”?
                  How about grounding it? Needed?
                  Cheers
                  Birdy
                  • T
                    @birdy i used one of thease.
                    http://www.biltema.se/sv/Fritid/Friluftsliv-och-camping/Kok-och-vatten/Vattendunk-2000023717/
                    Easy to bend och drill in
                      birdy
                      you used a plastic water canister? In what manner?
                      • T
                        @birdy i cut out flat pices that i drilled the board to.
                          birdy
                          so like this (side view)?
                          • T
                            @birdy yeah, but i used velcro tape insted of glue
                              birdy
                              one question, which is bothering me: the controller plate has spot for grounding (the plate was connected with the metal body before via this “grounding spot”). Do I need to ground it e.g. with power supply or similar or I can leave the plate ungrounded?
                                birdy
                                So I got the MM up an running :)
                                alt text
                                back side:
                                alt text
                                Next steps:
                                1. MM configuration & understanding how it works
                                2. to shorten the wooden legs
                                3. to order + build a frame
                                4. put everything together :)
                                BR
                                birdy
                                  birdy
                                  Dear all,
                                  next issue: to reduce the empty space behind the LCD panel, I bought a 90 degrees DVI adapter. But I have noticed, my plug was DVI-D and I bought DVI-I.
                                  Question: I don’t want to wait a week for a new one, can I remove few pins (esp. the 4 on the left) on my own? see picture below:
                                  Thx for your help!
                                  Regards
                                  birdy
