    Old LCD PC monitor
    20 Posts 3 Posters 15.5k Views 3 Watching
      birdy
      Hi all,
      I’m starting my journey with the mirror. For the start I have dismantled my old PC monitor and have a question: can I use it? The controller is quite big, so maybe I can remove the steel or should I buy a new controller (if possible)?
      alt text
      Controller:alt text
      Plugs: alt text
      Thx for your support!
      BR
      birdy
      • T Offline
        tomyboy96 Project Sponsor
        Hi!
        Yes ofc you can! my tip is remove the metal and get some thin plastic that you drill holes in. then just mount the circuit board to the plastic and then directly on the back of the display.
        The plastic will eliminate that the display short circuit.
        I just finished my MM and built it like this.
        Need anything else i’m happy to help!
        • T Offline
          Here you have how i did: https://forum.magicmirror.builders/topic/4614/thomas-magicmirror-with-two-screens-55x83cm
            Mykle1 Project Sponsor Module Developer @tomyboy96
            @tomyboy96 said in Old LCD PC monitor:
            Absolutely right! You have to isolate the boards so if you remove them from the shielding you’ll have to do something like tomyboy did. I left mine in the shielding. There was plenty of room.
            You can see it here.
              birdy
              Hi all,
              for the start, thanks a lot for you answers!
              Rasberry is there, so I wanted to test, if the screen is working. Ta-da! It’s not :(
              I had already problems with HDMI (my cat threw the screen down from the piano…) but VGA was always working. Now neither nor. I have Samsung SyncMaster T260HD.
              Any idea, what could be the problem? I alreday ordered the mirror (40x60 cm) so if I would like to buy a new screen, it will be expensive…
              alt text
              Cheers
              birdy
                Mykle1 Project Sponsor Module Developer @birdy
                @birdy said in Old LCD PC monitor:
                Your cat threw it down from the piano! ;^)
                Are you sure that your input is set correctly on the monitor?
                I would try it with another pc to eliminate the possibility that the Pi is not sending video.
                You can also try the DVI input. Again, making sure that the input is set to DVI when you try that.
                  birdy
                  small update:
                  I got the screen up and running (I forgot to switch over from the monitor body a small controll panel), unfortunatelly only via VGA. HDMI is definitely not working.
                  Any idea:
                  1. if I could connect RaPi to the monitor via DVI (micro HDMI DVI)?
                  2. or is there a connector (micro HDMI VGA)?
                  -> do I need a digital connection (hdmi) or analog (vga)?
                  For me a good information for today is, I don’t have to buy a new 27 inch LCD panel :D
                  Cheers
                  birdy
                  • T Offline
                    tomyboy96 Project Sponsor @birdy
                    @birdy why the micro Hdmi?
                    I would recommend using dvi to hdmi since the Rapi will then recognise the cable directly and u won’t have to do any config to get the screen working propely.
                    If you wanna use a hdmi to vga i used this:
                    http://www.wish.com/c/557e6ed78fe81619f182a12b
                    Worked really good after a bounch of configures in the Rapi.
                      birdy
                      @tomyboy96 - I have no idea why did I write micro HDMI (maybe I was playing with the micro SD adapter). But thanks for your remark! Adapter ordered (hope it will work). Next update in few days :)
                      • T Offline
                        @birdy I used some stuff from this site when i configured the Rapi (Y)
                        https://www.raspberrypi.org/forums/viewtopic.php?p=269212
                        Good Luck!
                          birdy
                          Hi guys,
                          the new cable is working!!!
                          alt text
                          Now the easiest part: coding ;)
                          Next update, when I get a keyboard from somewhere :D
                            birdy
                            there is also another challenge:
                            alt text
                            I would liek to get rid of these metal body. The side you can see shoud me glued to the plastic.
                            What can I put between the curcuit and the plastic? Some small plastik tubes? Wood? Rubber? Should I then glue the boards or better (for the future) screw it to to the “legs”?
                            How about grounding it? Needed?
                            Cheers
                            Birdy
                            • T Offline
                              @birdy i used one of thease.
                              http://www.biltema.se/sv/Fritid/Friluftsliv-och-camping/Kok-och-vatten/Vattendunk-2000023717/
                              Easy to bend och drill in
                                birdy
                                you used a plastic water canister? In what manner?
                                • T Offline
                                  @birdy i cut out flat pices that i drilled the board to.
                                    birdy
                                    so like this (side view)?
                                    • T Offline
                                      @birdy yeah, but i used velcro tape insted of glue
                                        birdy
                                        one question, which is bothering me: the controller plate has spot for grounding (the plate was connected with the metal body before via this “grounding spot”). Do I need to ground it e.g. with power supply or similar or I can leave the plate ungrounded?
                                          birdy
                                          So I got the MM up an running :)
                                          alt text
                                          back side:
                                          alt text
                                          Next steps:
                                          1. MM configuration & understanding how it works
                                          2. to shorten the wooden legs
                                          3. to order + build a frame
                                          4. put everything together :)
                                          BR
                                          birdy
                                            birdy
                                            Dear all,
                                            next issue: to reduce the empty space behind the LCD panel, I bought a 90 degrees DVI adapter. But I have noticed, my plug was DVI-D and I bought DVI-I.
                                            Question: I don’t want to wait a week for a new one, can I remove few pins (esp. the 4 on the left) on my own? see picture below:
                                            Thx for your help!
                                            Regards
                                            birdy
