    LED Backlight for mirror - PIR to control them
    17 Posts 6 Posters 15.4k Views 6 Watching
    • O
      orayoflighto Project Sponsor @cowboysdude
      @cowboysdude
      I used these only because they were incredibly cheap and I originally started out looking at MMM-PiLights which uses the same LPD8806 type:
      https://www.amazon.com/gp/product/B01COEJST8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
      I used this python code:
      https://github.com/longjos/RPi-LPD8806
      • cowboysdudeC
        cowboysdude Module Developer @orayoflighto
        @orayoflighto VERY nice, Thank you!!!
        You outta do a write up with instructions! MANY people would love this!
        • SnilleS
          Snille Module Developer
          Just to add some depth to this… If you really want to go “crazy” with animations, I’m recommending Bibliopixel and PixelWeb. Then you can “animate” lot’s and trigger them with a curl “command”. Plus you get a nice Web-interface to test the animations in. :)
          • KimzerK
            Kimzer
            Oh lawd! This looks insanely good. Thanks alot for the guide. Out to go buy some strips today! :D
            KimzerK 1 Reply Last reply Reply Quote 0
            • KimzerK
              Kimzer @Kimzer
              @Kimzer said in LED Backlight for mirror - PIR to control them:
              To quote myself…
              Can i use any sorts of led strips? Im looking to buy something from a store and not order online if possible.
              Im in norway so if anyone knows something i could buy please let me know!
              • O
                Different strips have different ways they need to be programmed. Some have faster refresh rates than others.
                Most people will suggest ADA102 for beginners. The strips I linked to are LPD8806. As I mentioned previously the only reason I bought those ones is that MMM-PiLights was programmed to use them.
                  Mirrorolentia
                  Any stats etc on comparison between LPD, APA102, WS2812 and SK series. I find that WS2812B isn’t always able to render all colors properly.
                  • KimzerK
                    Kimzer
                    Anyone know a way to control hue light strips to turn on/off via the pir sensor?
                      Mirrorolentia
                      Here is one link…
                      https://www.reddit.com/r/Hue/comments/48o51m/motion_sensor_controlled_hue_lightstrips/
                      • KimzerK
                        Kimzer
                        Found this hue motion but i couldnt get it to run.
                        Anyone that has some input?
                        • KimzerK
                          Kimzer @Kimzer
                          So i managed to do this. Its probably quite a dirty fix. And only setup to work with phillips hue bulbs/strips. But if u want to know shoot me a pm and ill show it.
