    LED Backlight for mirror - PIR to control them
    17 Posts 6 Posters 15.7k Views 6 Watching
    • O
      orayoflighto Project Sponsor
      I did this.
      alt text
      I used the MMM-PIR-Sensor module and changed the following in node_helper.js:
              if (data.indexOf("0x120002") !== -1)
                exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
      To:
              if (data.indexOf("0x120002") !== -1){
                exec("python /home/pi/py-spidev/RPi-LPD8806/LED.py");
      and
            exec("/opt/vc/bin/tvservice -o", null);
      To:
            exec("python /home/pi/py-spidev/RPi-LPD8806/off.py");
      Note that in the first from - to there is a “)” missing in the original code that you will need to fix. Also note that as soon as the module gets updated if you hack the code like I did above it will be wiped out when you update.
      Reply Quote 3
      • cowboysdudeC
        cowboysdude Module Developer @orayoflighto
        @orayoflighto NICE!!! What light strips did you use?
        O 1 Reply Last reply
        • O
          orayoflighto Project Sponsor @cowboysdude
          @cowboysdude
          I used these only because they were incredibly cheap and I originally started out looking at MMM-PiLights which uses the same LPD8806 type:
          https://www.amazon.com/gp/product/B01COEJST8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
          I used this python code:
          https://github.com/longjos/RPi-LPD8806
          Reply Quote 2
          • cowboysdudeC
            @orayoflighto VERY nice, Thank you!!!
            You outta do a write up with instructions! MANY people would love this!
            • SnilleS
              Snille Module Developer
              Just to add some depth to this… If you really want to go “crazy” with animations, I’m recommending Bibliopixel and PixelWeb. Then you can “animate” lot’s and trigger them with a curl “command”. Plus you get a nice Web-interface to test the animations in. :)
              • KimzerK
                Kimzer
                Oh lawd! This looks insanely good. Thanks alot for the guide. Out to go buy some strips today! :D
                KimzerK 1 Reply Last reply
                • KimzerK
                  Kimzer @Kimzer
                  @Kimzer said in LED Backlight for mirror - PIR to control them:
                  To quote myself…
                  Can i use any sorts of led strips? Im looking to buy something from a store and not order online if possible.
                  Im in norway so if anyone knows something i could buy please let me know!
                  • O
                    Different strips have different ways they need to be programmed. Some have faster refresh rates than others.
                    Most people will suggest ADA102 for beginners. The strips I linked to are LPD8806. As I mentioned previously the only reason I bought those ones is that MMM-PiLights was programmed to use them.
                      Mirrorolentia
                      Any stats etc on comparison between LPD, APA102, WS2812 and SK series. I find that WS2812B isn’t always able to render all colors properly.
                      • KimzerK
                        Kimzer
                        Anyone know a way to control hue light strips to turn on/off via the pir sensor?
                          Mirrorolentia
                          Here is one link…
                          https://www.reddit.com/r/Hue/comments/48o51m/motion_sensor_controlled_hue_lightstrips/
                          • KimzerK
                            Kimzer
                            Found this hue motion but i couldnt get it to run.
                            Anyone that has some input?
                            • KimzerK
                              Kimzer @Kimzer
                              So i managed to do this. Its probably quite a dirty fix. And only setup to work with phillips hue bulbs/strips. But if u want to know shoot me a pm and ill show it.
