    LED Backlight for mirror - PIR to control them
    17 Posts 6 Posters 15.7k Views 6 Watching
    • pjkoelemanP
      pjkoeleman
      @Mirrorolentia said in LED Backlight for mirror - PIR to control them:
      Please do let me know if you too have started on something.
      I’am working on a Pi-hat (plug on to the GPIO connector) witch can control an RGB-LED strip.
      For the software I want to use a PIR and the clock for switching On/Off. With PWM (Puls Wide Modulation) regulating the brightness. Color changing will be random, but there will be a fixed color in a white color, around 3000 K (warm-white).
      It will take some time to build/write the software, because I’am not a software guru.
        Mirrorolentia
        So finally have been able to integrate the led lights :) Got the code working just now. However, will need sometime to make a proper module out of it. Tried out with johnnyfive and node-pixel with some luck…but it was hyperion/boblight that did the magic for me.
        Of course, the trigger comes from Alexa/Echo rather than a PIR sensor.
        • O
          orayoflighto Project Sponsor
          I did this.
          alt text
          I used the MMM-PIR-Sensor module and changed the following in node_helper.js:
                  if (data.indexOf("0x120002") !== -1)
                    exec("/opt/vc/bin/tvservice --preferred && chvt 6 && chvt 7", null);
          To:
                  if (data.indexOf("0x120002") !== -1){
                    exec("python /home/pi/py-spidev/RPi-LPD8806/LED.py");
          and
                exec("/opt/vc/bin/tvservice -o", null);
          To:
                exec("python /home/pi/py-spidev/RPi-LPD8806/off.py");
          Note that in the first from - to there is a “)” missing in the original code that you will need to fix. Also note that as soon as the module gets updated if you hack the code like I did above it will be wiped out when you update.
          Reply Quote 3
          • cowboysdudeC
            cowboysdude Module Developer @orayoflighto
            @orayoflighto NICE!!! What light strips did you use?
            O 1 Reply Last reply
            • O
              orayoflighto Project Sponsor @cowboysdude
              @cowboysdude
              I used these only because they were incredibly cheap and I originally started out looking at MMM-PiLights which uses the same LPD8806 type:
              https://www.amazon.com/gp/product/B01COEJST8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
              I used this python code:
              https://github.com/longjos/RPi-LPD8806
              Reply Quote 2
              • cowboysdudeC
                @orayoflighto VERY nice, Thank you!!!
                You outta do a write up with instructions! MANY people would love this!
                • SnilleS
                  Snille Module Developer
                  Just to add some depth to this… If you really want to go “crazy” with animations, I’m recommending Bibliopixel and PixelWeb. Then you can “animate” lot’s and trigger them with a curl “command”. Plus you get a nice Web-interface to test the animations in. :)
                  • KimzerK
                    Kimzer
                    Oh lawd! This looks insanely good. Thanks alot for the guide. Out to go buy some strips today! :D
                    KimzerK 1 Reply Last reply
                    • KimzerK
                      Kimzer @Kimzer
                      @Kimzer said in LED Backlight for mirror - PIR to control them:
                      To quote myself…
                      Can i use any sorts of led strips? Im looking to buy something from a store and not order online if possible.
                      Im in norway so if anyone knows something i could buy please let me know!
                      • O
                        Different strips have different ways they need to be programmed. Some have faster refresh rates than others.
                        Most people will suggest ADA102 for beginners. The strips I linked to are LPD8806. As I mentioned previously the only reason I bought those ones is that MMM-PiLights was programmed to use them.
                          Mirrorolentia
                          Any stats etc on comparison between LPD, APA102, WS2812 and SK series. I find that WS2812B isn’t always able to render all colors properly.
                          • KimzerK
                            Kimzer
                            Anyone know a way to control hue light strips to turn on/off via the pir sensor?
                              Mirrorolentia
                              Here is one link…
                              https://www.reddit.com/r/Hue/comments/48o51m/motion_sensor_controlled_hue_lightstrips/
                              • KimzerK
                                Kimzer
                                Found this hue motion but i couldnt get it to run.
                                Anyone that has some input?
                                • KimzerK
                                  Kimzer @Kimzer
                                  So i managed to do this. Its probably quite a dirty fix. And only setup to work with phillips hue bulbs/strips. But if u want to know shoot me a pm and ill show it.
