    Missing CSS icons?
    Scheduled Pinned Locked Moved Forum
    bug
    14 Posts 3 Posters 11.0k Views 1 Watching
      paviro
      Yes already noticed that but no idea why…
      Will check once I have time.
      – The Doctor
      • K
        KirAsh4 Moderator
        Looks like the content that’s supposed to be there got mangled in the CSS file:
        P 1 Reply Last reply
          paviro @KirAsh4
          @KirAsh4 Any idea why that could be? There also is this strange white box sometimes when there are new posts in a topic:
          – The Doctor
          • K
            KirAsh4 Moderator
            I see that when I’m on my phone. I believe that’s a notification popup but it’s missing the contents … whatever it may be.
              paviro @KirAsh4
              @KirAsh4 Same thought but no idea why the content is missing… Will check the next couple of days and may open an issue on their GitHub.
              – The Doctor
              • K
                KirAsh4 Moderator
                Do you have access to the actual web server logs? That may shed some light, particularly in the error logs.
                  paviro @KirAsh4
                  @KirAsh4 I can access the node logs, yeah.
                  The only thing it logged in the last hours is:
                  6/5 07:30 [27307] - error: /sitemap/pages.xml
                   undefined
                  6/5 09:45 [27307] - error: /sitemap/topics.1.xml
                   undefined
                  6/5 18:32 [27307] - error: /sitemap/topics.1.xml
                   undefined
                  6/5 19:41 [27307] - error: /sitemap/categories.xml
                   undefined
                  6/5 22:19 [27307] - error: /sitemap/pages.xml
                   undefined
                  – The Doctor
                  • K
                    KirAsh4 Moderator
                    That’s node logs. You need the actual web server logs, whatever is serving those the pages …
                      paviro @KirAsh4
                      @KirAsh4 node is serving the pages :/ nginx only acts as a proxy but I will send you its logs via email.
                      – The Doctor
                      • K
                        KirAsh4 Moderator
                        Looking at stylesheet.css, there’s a big portion of it that’s mangled. The content: “” line is simply a square box. That tells me something didn’t translate right, either when you originally installed it, or when files were copied over, possibly from a different OS that mangled the file types …
                        • K
                          KirAsh4 Moderator
                          Myah, you have slow connections somewhere. From the log you sent me, I want to say the socket isn’t responding fast enough … why, who knows. Still need investigating …
                          I had to force refresh the page, then let it sit there for a bit before the notification icon popped up again, as well as the ‘Unread’ notification. Definitely some delay/timeout somewhere.
                          • MichMichM
                            MichMich
                            I’m so happy @paviro put all the effort in setting up this forum … 😂 If I had to deal with all the forum issues, MM would no longer be maintained. ;)
                            • K
                              KirAsh4 Moderator
                              Yeah, I hear you there. I’ve been trying to recreate the problems on my end but … no such luck. It runs flawlessly on my server, both as a super user as well as an unprivileged user. So something happened on his end with he switched things … maybe permissions … maybe something else. We’re trying to figure that out. You … you keep your focus on MM. :)
