    Missing CSS icons?
    Scheduled Pinned Locked Moved Forum
    bug
    14 Posts 3 Posters 11.0k Views 1 Watching
    • K
      KirAsh4 Moderator
      Looks like the content that’s supposed to be there got mangled in the CSS file:
      P 1 Reply Last reply
        paviro @KirAsh4
        @KirAsh4 Any idea why that could be? There also is this strange white box sometimes when there are new posts in a topic:
        – The Doctor
        • K
          KirAsh4 Moderator
          I see that when I’m on my phone. I believe that’s a notification popup but it’s missing the contents … whatever it may be.
            paviro @KirAsh4
            @KirAsh4 Same thought but no idea why the content is missing… Will check the next couple of days and may open an issue on their GitHub.
            – The Doctor
            • K
              KirAsh4 Moderator
              Do you have access to the actual web server logs? That may shed some light, particularly in the error logs.
                paviro @KirAsh4
                @KirAsh4 I can access the node logs, yeah.
                The only thing it logged in the last hours is:
                6/5 07:30 [27307] - error: /sitemap/pages.xml
                 undefined
                6/5 09:45 [27307] - error: /sitemap/topics.1.xml
                 undefined
                6/5 18:32 [27307] - error: /sitemap/topics.1.xml
                 undefined
                6/5 19:41 [27307] - error: /sitemap/categories.xml
                 undefined
                6/5 22:19 [27307] - error: /sitemap/pages.xml
                 undefined
                – The Doctor
                • K
                  KirAsh4 Moderator
                  That’s node logs. You need the actual web server logs, whatever is serving those the pages …
                    paviro @KirAsh4
                    @KirAsh4 node is serving the pages :/ nginx only acts as a proxy but I will send you its logs via email.
                    – The Doctor
                    • K
                      KirAsh4 Moderator
                      Looking at stylesheet.css, there’s a big portion of it that’s mangled. The content: “” line is simply a square box. That tells me something didn’t translate right, either when you originally installed it, or when files were copied over, possibly from a different OS that mangled the file types …
                      • K
                        KirAsh4 Moderator
                        Myah, you have slow connections somewhere. From the log you sent me, I want to say the socket isn’t responding fast enough … why, who knows. Still need investigating …
                        I had to force refresh the page, then let it sit there for a bit before the notification icon popped up again, as well as the ‘Unread’ notification. Definitely some delay/timeout somewhere.
                        • MichMichM
                          MichMich
                          I’m so happy @paviro put all the effort in setting up this forum … 😂 If I had to deal with all the forum issues, MM would no longer be maintained. ;)
                          • K
                            KirAsh4 Moderator
                            Yeah, I hear you there. I’ve been trying to recreate the problems on my end but … no such luck. It runs flawlessly on my server, both as a super user as well as an unprivileged user. So something happened on his end with he switched things … maybe permissions … maybe something else. We’re trying to figure that out. You … you keep your focus on MM. :)
