Problem with module email
7 Posts 2 Posters 4.6k Views 2 Watching
    psteimann
    When i activate the mail-module, magigmirror stops (seems to crash)
    config.js seems ok, otherwise magicmirror would not start.
    How can i resolve this problem?
    M 1 Reply Last reply Aug 31, 2017, 9:22 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @psteimann
      @psteimann
      https://forum.magicmirror.builders/topic/4751/how-to-ask-for-help-for-absolute-beginners
        psteimann
        ok…what Information is missing?
          psteimann
          Still trying hard…I deleted 1 account, and the module crashes not anymore.
          But now, I have 2 different results:
          -With the Apple-Account (map.mail.me.com) it says no mmails found what is definitely wrong.
          -With the Imap-Account of my provider, the module stays and loading…but nothing happens
          How can I debug to see whats wrong?
          		module: 'email',
                          position: 'bottom_left',
                          header: 'Email',
                              accounts: [
                                      user: 'xxxxxxxx',
                                      password: 'xxxxxxxxxr',
                                      host: 'dompop.vtx.ch',
                                      port: 993,
                                      tls: true,
                                      authTimeout: 10000,
                                      numberOfEmails: 2,
                              fade: true,
                              maxCharacters: 30
          M 1 Reply Last reply Sep 1, 2017, 9:38 PM Reply Quote 0
            @psteimann
            I don’t use this module but I did install it and attempt to get it to function. I used my gmail account as a test but I was unable to get it to work. It reports No New Emails. I sent myself 3 emails to that account. I checked that they were there, as well.
            		module: 'email',
                            header: 'Email',
                                accounts: [
                                        user: 'xxxxxxxxx@gmail.com',
                                        password: 'xxxxxxxx',
                                        host: 'imap.gmail.com',
                                        port: 993,
                                        tls: true,
                                        authTimeout: 10000,
                                        numberOfEmails: 5,
                                fade: true,
                                maxCharacters: 30
            In my terminal I received an endless list of the same error.
            Email notifier error:  { Error: read ECONNRESET
                at exports._errnoException (util.js:1022:11)
                at TCP.onread (net.js:572:26)
              code: 'ECONNRESET',
              errno: 'ECONNRESET',
              syscall: 'read',
              source: 'socket' }
              code: 'ECONNRESET',
              syscall: 'read',
              source: 'socket' }
              code: 'ECONNRESET',
              syscall: 'read',
              source: 'socket' }
            Mykle@Mykle-Desktop MINGW32 ~/MagicMirror
            My dev console reports no errors.
            Perhaps someone else will lend a hand here.
            P 1 Reply Last reply Sep 1, 2017, 11:28 PM Reply Quote 0
              psteimann @Mykle1
              @Mykle1 how do I get the results into my dev console? (beginner:-()
              But I got it now. As a username, try to use xxxx instead of xxx@xx.com, this worked for me with map
              trying to setup a second account with an apple-account did not work. I heard that they changed something about security and certificates, so the module may have to be checked for this issue.
              If you use 2 accounts and the second one is not reachable for any kind (wrong password etc), MM2 will stay and loading…and will not even show the mails from the first working account. btw: No constellation worked in my MM2 as soon as i used more than 1 account, but I do not whirled need it, just for information.
              M 1 Reply Last reply Sep 2, 2017, 12:34 AM Reply Quote 0
                @psteimann said in Problem with module email:
                Open a new terminal. Enter cd MagicMirror. type npm start dev while in the MagicMirror dir. This will launch the mirror and open your dev tools. Click on console at the top to see all console messages
