    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 79.8k Views 28 Watching
      pflodo @vicmora
      @vicmora I like it.
      To make it generic , probably should expose the zoom as a variable, in my area I prefer showing a larger area with only major roads showing.
      With black background of mirror I also prefer the night mode of this sample: https://developers.google.com/maps/documentation/javascript/examples/style-array
      Maybe expose the Style as a variable as well, letting the user define it or leave it blank for default, alternatively you could hardcode a particular inverse colour style, and have a config to enable it.
      • O Offline
        Osyris
        Hey guys, I figured it’s easy enough to style the map by editing the JS file. So in order to get the night mode as shown in pflodo’s post (and to disable the UI buttons) I added the following to the JS code:
        //original code
                script.onload = function () {
                    var map = new google.maps.Map(document.getElementById("map"), {
                    	zoom: 10,
                    	center: {
                    		lat: lat,
                    		lng: lng
        //add a comma after the } above
        //new code:
        		disableDefaultUI: true,
        		styles: [
        			{elementType: 'geometry', stylers: [{color: '#242f3e'}]},
        			{elementType: 'labels.text.stroke', stylers: [{color: '#242f3e'}]},
        			{elementType: 'labels.text.fill', stylers: [{color: '#746855'}]},
        			    featureType: 'administrative.locality',
        			    stylers: [{color: '#d59563'}]
        				featureType: 'poi',
        				featureType: 'poi.park',
        			        stylers: [{color: '#263c3f'}]
        				stylers: [{color: '#6b9a76'}]
        				featureType: 'road',
        				stylers: [{color: '#38414e'}]
        				elementType: 'geometry.stroke',
        					  stylers: [{color: '#212a37'}]
        					  stylers: [{color: '#9ca5b3'}]
        				featureType: 'road.highway',
        				stylers: [{color: '#1f2835'}]
        				stylers: [{color: '#f3d19c'}]
        				featureType: 'transit',
        				stylers: [{color: '#2f3948'}]
        			        featureType: 'transit.station',
        			        featureType: 'water',
        				stylers: [{color: '#17263c'}]
        				stylers: [{color: '#515c6d'}]
        //old code again
        Have fun!
        Also, if you want to make the background black (so it looks cool on the mirror), set the first attribute ‘geometry’ to ‘#000000’.
        K 2 Replies Last reply Reply Quote 0
        • K Offline
          knubbl @Osyris
          Good work.
          Any ideas how to adjust the zoom of the map?
          • O Offline
            Osyris @knubbl
            @knubbl See line 4 in the old code of my code snippet above. You can simply adjust the ‘zoom’ parameter: smaller numbers to zoom out, bigger numbers to zoom in.
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @Osyris
              @Osyris as you figured out to make those modifications, don’t you want to make config options for it and add it to the repository, so users can use it without the need of modificate the module and can easily update on new versions?
              • V Offline
                vicmora
                @Osyris are you willing to submit a pull request on github with what @strawberry-3-141 mentioned?
                If not, I can take care of this as soon as I get some time.
                • O Offline
                  Osyris
                  I can do that, but the Git seems to be locked so I can’t make branches. Also, there seems to be another user who forked your Git and added a night mode.
                    @Osyris as you’re not added to the project the only way for you is to create a fork do your stuff there and then create a pull request to the source project
                    • O Offline
                      Osyris
                      Ok, I’m at it.
                      • O Offline
                        Osyris
                        Could someone test the changes from my fork? I have no time to test this on my mirror right now and I’m afraid there could be errors in the code:
                        https://github.com/Osyris187/MMM-GoogleMapsTraffic
                        • 1 / 9
