    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 81.3k Views 28 Watching
    • K Offline
      knubbl @Osyris
      Good work.
      Any ideas how to adjust the zoom of the map?
      • O Offline
        Osyris @knubbl
        @knubbl See line 4 in the old code of my code snippet above. You can simply adjust the ‘zoom’ parameter: smaller numbers to zoom out, bigger numbers to zoom in.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Osyris
          @Osyris as you figured out to make those modifications, don’t you want to make config options for it and add it to the repository, so users can use it without the need of modificate the module and can easily update on new versions?
          • V Offline
            vicmora
            @Osyris are you willing to submit a pull request on github with what @strawberry-3-141 mentioned?
            If not, I can take care of this as soon as I get some time.
            • O Offline
              Osyris
              I can do that, but the Git seems to be locked so I can’t make branches. Also, there seems to be another user who forked your Git and added a night mode.
                @Osyris as you’re not added to the project the only way for you is to create a fork do your stuff there and then create a pull request to the source project
                • O Offline
                  Osyris
                  Ok, I’m at it.
                  • O Offline
                    Osyris
                    Could someone test the changes from my fork? I have no time to test this on my mirror right now and I’m afraid there could be errors in the code:
                    https://github.com/Osyris187/MMM-GoogleMapsTraffic
                    • sailboarder79S Offline
                      sailboarder79
                      I had a question about how often this updates traffic. Does this auto refresh every hour or something or does it only update when the magic mirror is booted up?
                      • O Offline
                        Osyris
                        The traffic layer does update itself just as on the Google Maps website. I don’t know how long the update interval is, but it’s as good as it gets. Google does not provide any APIs for the traffic layer.
                        sailboarder79S 1 Reply Last reply Reply Quote 0
                        • 1 / 9
