    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • V
      vicmora
      GitHub Repo: https://github.com/vicmora/MMM-GoogleMapsTraffic
      alt text
      Hi, I created a new module that is used to display a Google Map and it’s traffic layer, centered at provided coordinates. All instructions are at the repo link but let me know if you have any questions!
      P Z 2 Replies Last reply
      Reply Quote 3
        pflodo @vicmora
        @vicmora I like it.
        To make it generic , probably should expose the zoom as a variable, in my area I prefer showing a larger area with only major roads showing.
        With black background of mirror I also prefer the night mode of this sample: https://developers.google.com/maps/documentation/javascript/examples/style-array
        Maybe expose the Style as a variable as well, letting the user define it or leave it blank for default, alternatively you could hardcode a particular inverse colour style, and have a config to enable it.
        • O
          Osyris
          Hey guys, I figured it’s easy enough to style the map by editing the JS file. So in order to get the night mode as shown in pflodo’s post (and to disable the UI buttons) I added the following to the JS code:
          //original code
                  script.onload = function () {
                      var map = new google.maps.Map(document.getElementById("map"), {
                      	zoom: 10,
                      	center: {
                      		lat: lat,
                      		lng: lng
          //add a comma after the } above
          //new code:
          		disableDefaultUI: true,
          		styles: [
          			{elementType: 'geometry', stylers: [{color: '#242f3e'}]},
          			{elementType: 'labels.text.stroke', stylers: [{color: '#242f3e'}]},
          			{elementType: 'labels.text.fill', stylers: [{color: '#746855'}]},
          			    featureType: 'administrative.locality',
          			    stylers: [{color: '#d59563'}]
          				featureType: 'poi',
          				featureType: 'poi.park',
          			        stylers: [{color: '#263c3f'}]
          				stylers: [{color: '#6b9a76'}]
          				featureType: 'road',
          				stylers: [{color: '#38414e'}]
          				elementType: 'geometry.stroke',
          					  stylers: [{color: '#212a37'}]
          					  stylers: [{color: '#9ca5b3'}]
          				featureType: 'road.highway',
          				stylers: [{color: '#1f2835'}]
          				stylers: [{color: '#f3d19c'}]
          				featureType: 'transit',
          				stylers: [{color: '#2f3948'}]
          			        featureType: 'transit.station',
          			        featureType: 'water',
          				stylers: [{color: '#17263c'}]
          				stylers: [{color: '#515c6d'}]
          //old code again
          Have fun!
          Also, if you want to make the background black (so it looks cool on the mirror), set the first attribute ‘geometry’ to ‘#000000’.
          K 2 Replies Last reply
          • K
            knubbl @Osyris
            Good work.
            Any ideas how to adjust the zoom of the map?
            O 1 Reply Last reply
            • O
              Osyris @knubbl
              @knubbl See line 4 in the old code of my code snippet above. You can simply adjust the ‘zoom’ parameter: smaller numbers to zoom out, bigger numbers to zoom in.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Osyris
                @Osyris as you figured out to make those modifications, don’t you want to make config options for it and add it to the repository, so users can use it without the need of modificate the module and can easily update on new versions?
                • V
                  vicmora
                  @Osyris are you willing to submit a pull request on github with what @strawberry-3-141 mentioned?
                  If not, I can take care of this as soon as I get some time.
                  • O
                    Osyris
                    I can do that, but the Git seems to be locked so I can’t make branches. Also, there seems to be another user who forked your Git and added a night mode.
                    • strawberry 3.141S
                      @Osyris as you’re not added to the project the only way for you is to create a fork do your stuff there and then create a pull request to the source project
                      • O
                        Osyris
                        Ok, I’m at it.
                        • O
                          Osyris
                          Could someone test the changes from my fork? I have no time to test this on my mirror right now and I’m afraid there could be errors in the code:
                          https://github.com/Osyris187/MMM-GoogleMapsTraffic
                          • sailboarder79S
                            sailboarder79
                            I had a question about how often this updates traffic. Does this auto refresh every hour or something or does it only update when the magic mirror is booted up?
                            • O
                              Osyris
                              The traffic layer does update itself just as on the Google Maps website. I don’t know how long the update interval is, but it’s as good as it gets. Google does not provide any APIs for the traffic layer.
                              sailboarder79S 1 Reply Last reply
                              • sailboarder79S
                                sailboarder79 @Osyris
                                @Osyris okay thanks!
                                • Z
                                  zzaidi148 @vicmora
                                  @vicmora Hi, I’ve been trying for the past week to get your module to work on my magic mirror. The closest I’ve gotten is getting my magic mirror to boot up with the default modules with no google maps traffic module showing. I used npm start dev to see the console it and it looked perfectly fine, saying that it had launched. I’ve tried placing the module in different places in the config. Below is my config, I’ve put it both at the beginning and end of this config. Please let me know which place to put it and how to fix the issue. Thanks!
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: "en",
                                  	timeFormat: 12,
                                  	units: "imperial",
                                              		module: 'MMM-GoogleMapsTraffic',
                                                  	key: 'i have this',
                                                  	lat: 37.8262306,
                                                  	lng: -122.2920096,
                                                  	height: '300px',
                                                  	width: '300px'
                                  			module: "alert",
                                  			module: "updatenotification",
                                  			position: "top_bar",
                                  			module: "clock",
                                  			header: "US Holidays",
                                  					symbol: "calendar-check-o",
                                  					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                  			module: "compliments",
                                  			position: "lower_third",
                                  			module: "currentweather",
                                  				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  				appid: "private",
                                  			module: "weatherforecast",
                                  			header: "Weather Forecast",
                                  				appid: "private",
                                  			module: "newsfeed",
                                  			position: "bottom_bar",
                                  				feeds: [
                                  						title: "New York Times",
                                  				showSourceTitle: true,
                                  				showPublishDate: true
                                                  	   key: 'I have this',
                                                  	   lat: 37.8262306,
                                                  	   lng: -122.2920096,
                                                  	   height: '300px',
                                                  	   width: '300px',
                                  ? 1 Reply Last reply
                                    A Former User @zzaidi148
                                    @zzaidi148
                                    I’ve found what is wrong.
                                    you should set position of this module.
                                    position: 'top_left', //this is missed.
                                          	   key: 'I have this',
                                    manual of @vicmora has missed this.
                                    Z 1 Reply Last reply
                                    • Z
                                      zzaidi148 @Guest
                                      @Sean Thank you so much! Finally, after toiling away at it, with your help, I got it to work. Next up, your calendar module!
                                        blue2monster
                                        @vicmora : I’ve been trying all night long: just cant get the map to be shown.
                                        I can see that the module is started in the dev logs.
                                        Funny thing: If I add some different HTML Output in the module.js It is printed on my screen, the only thing missing is the map.
                                        Same thing is happening on MMM-fuel and MMM-googlemap. Modules are working but the map itself is not shown.
                                        Different one for iFrame: This one is working.
                                        Interesting fact: If I check on the google dashboard for the traffic of this specific api key, I do not see any traffic. Is there anything special in the google api that I need to enable, or any additional module that needs to be installed.
                                        Any ideas: Thanks a lot for the help.
                                        B V 2 Replies Last reply
                                          blue2monster @blue2monster
                                          @blue2monster: found now a workaround with the iframe module: This one works… but I haven’t made to switch the traffic layer on
                                          • V
                                            vicmora @blue2monster
                                            @blue2monster Have you tried adding position: ‘top_left’ to your config? I missed this in the docs but will update them.
                                            B 1 Reply Last reply
                                            • 1 / 5
