    602 Posts 67 Posters 2.2m Views 68 Watching
    • NiggichN Offline
      Niggich
      @shbatm I try everything to get stream working with omxplayer but I always get a black blank screen. I don’t know what can I try anymore. When I change it back to ffmpeg the stream is working…
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xblackdemonx @Niggich
        @Niggich Then why do you insist on using omxplayer then?
        NiggichN 1 Reply Last reply Reply Quote 0
        • NiggichN Offline
          Niggich @xblackdemonx
          @xblackdemonx The ffmpeg have a time difference from live to stream about 10 seconds.
          • X Offline
            @Niggich Not for me. I see maybe a 1/2 second delay only.
            • NiggichN Offline
              @xblackdemonx how you did this? I try everything… how is your config?
              • X Offline
                @Niggich Nothing special. Maybe reboot your cameras?
                        module: 'MMM-RTSPStream',
                        position: 'bottom_bar',
                            autoStart: true,
                            rotateStreams: false,
                            rotateStreamTimeout: 10,
                            showSnapWhenPaused: false,
                            moduleWidth: 354,
                            moduleHeight: 240,
                            stream1: {
                                url: 'rtsp://192.168.1.2:554/unicast',
                                snapshotUrl: '',
                                snapshotRefresh: 10, // Seconds
                                frameRate: "15",
                                port: 9999,
                • NiggichN Offline
                  @xblackdemonx ok, almost the same like my config. Just the Framerate is different. I change it like it is in your config and will see.
                    Drooneyef
                    I noticed the following:
                    When using omxplayer i also had a black screen instead of the camera image.
                    I removed the sd card and inserted it in a different raspberry.
                    Then everything was working fine.
                    The only difference between those 2 is the monitor connected to it.
                    It was working on a 7 inch monitor and on a 24 inch monitor it didn’t work.
                    The problem was the resolution.
                    Now the module is using stream2 and i changed in my Hikvision camera the resolution settings for stream2.
                    Now my mirror is working fine.
                    Maybe this is also a solution for you.
                      bhepler Module Developer
                      I hope my configuration will help give you guys another possibility. I locked down my camera a bit with a username & password. So my configuration looks as so:
                      module: "MMM-RTSPStream",
                          position: "bottom_left",
                                autostart: true,
                                moduleWidth: 354,
                                moduleHeight: 242,
                                stream1: {
                                     url: 'rtsp://[username]:[password]@10.0.0.25/cam1/mpeg4',
                                     port: 8027,
                                     shutdownDelay: 0,
                                     width: 352,
                                     height: 240,
                                     frameRate: "30"
                      • NiggichN Offline
                        Niggich
                        The stream works fine with the omx… finally, after 4 weeks playing…
                        Another question. Is any way to remove the little white Frame around video picture?
                        D B 2 Replies Last reply Reply Quote 0
                          Drooneyef @Niggich
                          @Niggich
                          What was the trick that made it work finally?
                            barnosch @Niggich
                            @Niggich
                            Change the css file in the module folder like this
                            .MMM-RTSPStream .innerWrapper {
                              position: relative;
                              width: 352px; /* Video width + 2*border + 2*padding */
                              height: 242px;
                            /*  border: 1px solid white; */
                              /*float: left;*/
                              display: inline-block;
                              text-align: center;
                              margin: 15px;
                            the line “border: 1px solid white;” needs to be adujsted or uncommented like in my case
                            • NiggichN Offline
                              Niggich @Drooneyef
                              @Drooneyef I put the port of my cam behind the IP-adress…
                              position: 'bottom_center',
                              		autoStart: true,
                                      moduleWidth: 704,
                                      moduleHeight: 240,
                                      moduleOffset: { top: 212, left: 0 },
                                      localPlayer: 'omxplayer',
                                      	stream1: {
                                              url: 'rtsp://192.168.113.125:554/live/ch1',
                                              shutdownDelay: 0,
                                              width: 320,
                                              height: 240,
                                              frameRate: "20",
                                              port: 9999,
                              			stream2: {
                                              url: 'rtsp://192.168.113.103:554/live/ch1',
                                              shutdownDelay: 0,
                                              width: 320,
                                              height: 240,
                                              frameRate: "20",
                                              port: 10000,
                              • NiggichN Offline
                                Niggich @barnosch
                                @barnosch thx this works fine for me…
                                  shbatm Module Developer
                                  @barnosch @Niggich - Glad you got it working. I will clarify in the next update: the camera port should be included in the url. The port setting for the stream is actually the socket ffmpeg uses (when ffmpeg is used instead of omx).
                                  If anyone has any additional feature requests, clarifications, config options they would like, please let me know on here. I will get back to working on this module in the coming weeks; I am Houston, TX based so I’ve been occupied with other matters recently.
                                  • NiggichN Offline
                                    Niggich
                                    @shbatm - The stream is working. Now I have another question/problem. When I hide the module an show it again the Video picture is in Fullscreen. Any fix for this? thx a lot…
                                      @Niggich I will need to investigate further.
                                      As a temporary fix, you can try deleting Line 107 and Lines 109-114 in the node_helper.js file:
                                          ~/MagicMirror/modules/MMM-RTSPStream/node_helper.js
                                      You should be deleting the if…else block and this line will remain:
                                      args.unshift("--win", `${payload.box.left}, ${payload.box.top}, ${payload.box.right}, ${payload.box.bottom}`);
                                      I do not know if this will fix the problem but it is worth a try. I have opened Issue #13 to track the position, border, and fullscreen resume problems.
                                        shbatm Module Developer @barnosch
                                        @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        added the pkill commands but it does not work. It does not kill the apps.
                                        From time to time, the feed disappears. Have not yet found when and why.
                                        Sometimes it runs 2 days without problems, the other day it only lasts for some hours.
                                        Issue #14 opened to track this problem to closure.
                                        • NiggichN Offline
                                          Niggich @shbatm
                                          @shbatm thank you for the fast answer, but this doesn’t fix the problem.
                                            shbatm Module Developer @Niggich
                                            @Niggich could you please post your server log (console or PM2’s log file) when it does this? You should have several lines starting with:
                                            Starting stream stream1 with args:
                                            Also, what are you using to show/hide the module? (via MMM-Remote-Control or another module?)
                                            This will help diagnose.
                                            • 30
                                            • 31
                                            • 3 / 31
