    Question regarding "System Load" and the "CPU temp" when MM is running.
    7 Posts 3 Posters 3.3k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @EventHorizon
      @EventHorizon
      Your problem could be related to this. It’s worth a read
      https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
      • E Offline
        EventHorizon
        Thanks @Sean and @Mykle1 for your replies! I really appreciate it.
        I think my problem DOES relate to what has been discussed in that thread, so I am going to try the fresh install with the lower MM version and electrum version 1.4.15. I will post my results in that thread.
        A quick noob question sorry, how do I install an older specific MM version, like the one state din the other topic?
        Thanks!
          @EventHorizon said in Question regarding “System Load” and the “CPU temp” when MM is running.:
          Here you’ll find the releases:
          https://github.com/MichMich/MagicMirror/releases
          For a fan, I was considering this one, would this do the trick?
          Any fan will work. In my case, I salvaged a fan from an old Mac G5 power supply, and even though it is a 12V fan, it works nicely using 5V from the Pi’s GPIO. I also have heatsinks installed. My Pi went from 60°C to 40°C.
          I look for your progress in the other topic. Good luck
          • E Offline
            EventHorizon @Mykle1
            @Mykle1 thank you I shall do! Another quick question. Can I keep my config.js file I have for the newest install? I have it backed up and saved. Can I just use that for when I downgrade? It will save me having to re-add all the modules and custom compliments etc.
              A Former User @EventHorizon
              Maybe available, unless none of your module has restriction of mm version.
