    Electron CPU usage
    247 Posts 46 Posters 668.8k Views 42 Watching
    • E
      EventHorizon
      Just a quick post in an attempt to re-create the above steps. I get to the part where I have to type “npm install && npm start” and I get an error 404 ‘Not Found’. ‘types/node’ is not in the npm registry. ‘It was specified as a dependency of ‘electron’’
      Any idea what I’m doing wrong?
      Thanks.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @EventHorizon
        @EventHorizon it should be @types/node
        E 1 Reply Last reply
        • E
          EventHorizon @strawberry 3.141
          @strawberry-3.141 thank you for the quick reply. Just to confirm: where am I entering @types/node. Sorry for being a noob at this. Thanks for your help!
          EDIT: I got the node/type to work by updating using sudo npm install npm@latest -g
          Now when I run sudo npm install in the magic mirror folder I get an error code LIFECYCLE. errno 1. “electron@1.7.6” postinstall ‘node install.js’.
          ‘failed at the electron@1.7.6 postinstall script’.
          Any ideas?
          EDIT2: used sudo npm install -g electron --unsafe-perm=true.
          This seemed to work. I will monitor performance and let you all know.
          EDIT3:
          Been monitoring it for an hour or so now. CPU temp has not gone over 50. While before it was around a constant 60 - 65.
          Compliments and Newsfeed animations are SUPER SMOOTH.
          I can confirm that using MM 2.1.0 with Electron 1.4.15 has insanely improved performance! Thanks to everyone in this thread and to @Mykle1 for pointing this thread out for me.
          I just have ONE final question guys. I used my custom.css file from my newer build and all was fine after I removed the ‘everyday’ segment of the code from the compliments module. HOWEVER…I notice in the background (If i tab to terminal) This message pops up:
          “Fatal: not a git repository (or any of the parent directories): .git”
          However, it does not seem to affect the mirror? Or not in any way I can see? Is there any way I can pinpoint how this message is being generated? Like I said, it does not appear to affect any of my modules.
          Any help would be greatly appreciated.
          Cheers all!
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @EventHorizon
            @EventHorizon said in Electron CPU usage:
            If you read this entire thread then you know that I’ve been at this for three weeks. It started as a question from a single user and grew quickly and substantially. 148 posts and 6.0k views later showed there was/is an issue affecting many users, yourself included. I’m glad this workaround has helped you. Enjoy!
            I get these, too, when I do a manual installation of a module, or the MM software itself. What type of installation did you do?
            In any event, it does not affect the operation of the MM software. Perhaps someone will give us a more detailed description of why it appears.
            • E
              EventHorizon @Mykle1
              @Mykle1 Thank you for the quick reply!
              For the custom modules I used the git commands however, for the magic mirror module I just downloaded it and unzipped it, as I wasn’t sure if I could use a git command to request a specific version of magic mirror. Is there a way of using git to call MM 2.1.0? Just out of pure curiosity!
              • Mykle1M
                That’s how I do it, as well. I’m old and somewhat set in my ways when it comes to some things.
                I’m really not sure if you can call an earlier version through git. It would be nice if we could do something like this:
                https://github.com/MichMich/**MagicMirror210**.git
                I never tried it. Anyone else have an answer to this?
                As it is, the link to the earlier version looks like this:
                https://github.com/MichMich/MagicMirror/archive/v2.1.0.zip
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @Mykle1
                  @Mykle1 you can go to every commit you’d like to go, but it’s easier to choose a specific tag
                  git clone ...
                  git checkout v2.1.0
                  Reply Quote 3
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @strawberry 3.141
                    @strawberry-3.141 said in Electron CPU usage:
                    git clone …
                    git checkout v2.1.0
                    And there you have it. Thanks :^)
                    • E
                      @Mykle1 We learn something new everyday! :) I’ve only started my magic mirror this week and I find this forum is so engaged and passionate about the mirror and all of its amazing stuff I love it.
                      I think my plan of action now will be: if at some point there is an update to fix this issue with the newest version I’ll just buy another SD card and keep this one as a backup.
                      • Mykle1M
                        Fantastic idea. You can also make a backup of the SD card itself. I have a couple in storage.
                        • Mykle1M
                          Got a few spare SD cards so I installed a fresh new Jessie and MagicMirror-develop(which installed Electron 1.7.6). Well, I’m sad to report that Electron 1.7.6 gags on a default installation of MM. Using nmon for stats, Electron CPU usage soared over 225% every time there was a transition of both the Compliments module and the newsfeed module. When either made a transition by themselves, CPU usage was well over 140%. There was not much “at rest” time because newsfeed rotates pretty quickly by default. However, rare moments of “at rest” time showed near normal CPU usage of about 15%.
                          I did this as a test, to satisfy my own curiosity, because my Pi3 doesn’t have the issues discussed here. Using the same Pi3 that hosts my mirror, running Jessie and MM 2.1.0 and Electron 1.4.15, it performs amazingly well, with no outrageous CPU usage or heat issues (fan installed).
                          The same Pi3, with the newest develop installation of MM, which installs Electron 1.7.6, is hard pressed to handle the default of 4 modules adequately.
                          Needless to say, I’m going back to my original SD card, with Jessie, MM 2.1.0 and Electron 1.4.15
                          Reply Quote 2
                          • E
                            @Mykle1 Brilliant work and testing mate :)
                            • Mykle1M
                              A few words of caution about Raspbian Stretch
                              I’ve been doing some testing recently, mostly concerning CPU usage with different versions of Raspian and MM. Once I got bluetooth to work, I continued testing with newer and newer versions, until I got to Raspbian Stretch.
                              The firmware update that accompanies Stretch disabled my Wifi and Bluetooth, and no amount of backward flashing to earlier firmware versions is fixing the issue. When I say disabled, I mean the Pi doesn’t recognize its own Wifi or Bluetooth adapter, as if it doesn’t have them. Google it BEFORE you attempt this upgrade.
                              • r3z3R
                                r3z3
                                I’ve just downgrade to the electron@1.4.15 version : no more high CPU usage !
                                Thanks !
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @r3z3
                                  @r3z3 said in Electron CPU usage:
                                  That’s fantastic! I’m really happy with the results of this topic. We put our heads together and came up with a workaround that works for most people. Kudos to everyone that participated and continues to participate.
                                  I only cooked one Pi3 during my testing. Can anyone help me to reflash a Pi3 B to a firmware version dated about January, 2017?
                                  • Mr.SpontiM
                                    Mr.Sponti
                                    I also did a downgrade from MagicMirror 2.1.1 and electron@1.7 as proposed
                                    to MagicMirror 2.1.0 and electron@1.4.15. and see a significant lower CPU usage. Formerly CPU usage was most of the time over 100% up to 200%. Now, top shows a CPU usage of electron between 2 to 3 %.
                                    I hope that the electron dev team will take a look to fix that problem in a future release!
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Mr.Sponti
                                      @Mr.Sponti said in Electron CPU usage:
                                      Yeah boy! :^)
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @wtidwell
                                        @wtidwell said in Electron CPU usage:
                                        Hey all, new user here.
                                        You see what you started? :^)
                                          Reotch2 @loctruong96
                                          @loctruong96 said in Electron CPU usage:
                                          1. sudo npm install electron@1.4.15 -g
                                          2. WAIT PATIENTLY FOR ELECTRON TO LOAD IN THE BACKGROUND
                                          3. a new line appear indicate electron has finished installing
                                          4. Go to your download folder, exact Magic Mirror 2.1.0
                                          5. Go to the newly exacted forlder, open another folder named config
                                          6. Change the file name Config.js.example to Config.js inside the config folder
                                          @Mykle1
                                          I keep getting the same issue as @EventHorizon but none of his fixes seem to work (sudo npm install -g electron --unsafe-perm=true) or (nom @latest -g).
                                          I’m starting with a fresh STRETCH install, and get to step 9 (npm install && npm start) where I get the (types/node) fault.
                                          Any ideas?
                                          Thanks all.
                                          L Mykle1M 2 Replies Last reply
                                          • L
                                            loctruong96 @Reotch2
                                            @Reotch2 Hello I think this happened because electron was not successfully installed using npm as a global variable. It happened to me too and i had to reinstall electron as a global variable which is the -g at the end is for. Can you confirm that you have successfully install electron ?
                                            R 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
