    Calendar modification
    35 Posts 15 Posters 49.7k Views 12 Watching
    • 0
      00conman @KirAsh4
      @KirAsh4 I keep my calendar in month mode because it makes sure that events don’t delete halfway through a day and when in month mode it prevents a glitch from occurring. In that glitch on the mirror itself events will be assigned random times, in my case the newest event would be assigned 4:00 am and then each event after that would increase by the hour to 5:00 and so on. There is also an occurrence that events will randomly delete themselves from the actual mirror, not the online calendar, so putting this in month mode will cause them to remove themselves, or stop displaying, on the mirror at 12:00 o’clock midnight the day that they were assigned. It is certainly not necessary but I would do it because it take just a few seconds.
      • 0
        00conman
        To anyone wondering how to switch the calendar to month mode here is a few images.
        Main calendar:
        https://gyazo.com/52f994a4b33968c8a0ebe2effe349179
        And where you switch it:
        https://gyazo.com/81e42213091d63b75e4bb9798e01d4ac
        Please note that it might not work the first time in that case either try again and reload the page or try again and go to settings and save the calendar.
        • KirAsh4K
          KirAsh4 Moderator
          That’s something that is outside of the scope of MM itself. They don’t have anything to do with the MM calendar module itself. When you said to keep the calendar in monthly mode, my first reaction was, ‘Uh, the calendar doesn’t have a monthly view’, hence my request for clarification.
          It’s helpful to others who are using that specific service to host a calendar, and trying to incorporate it into MM, but you needed to specify what you were referring to.
          Thanks for the clarification.
          • A
            aarinsingh
            Wow, Thanks Guys.
            I took a couple days of from the project and hit the lake, so sorry for the slow replies.
            @MichMIch - That cured it, I had the maximunNumberOfDays Line to far down.
            I have a couple other questions but I won’t clutter up the calendar Module board with them.
              Plati
              How to get ICAL for a Facebook calendar:
              https://www.facebook.com/help/152652248136178/
              2 different ICAL for birthdays and upcoming events :)
              Useful config part: “maximumEntries: X”
              And holidays calendars for many countries: https://www.mozilla.org/en-US/projects/calendar/holidays/
                CCoates
                Anyone had any luck with Outlook 365 or Iphone calendars?
                lolobyteL yawnsY 2 Replies Last reply
                • lolobyteL
                  lolobyte @CCoates
                  @CCoates
                  iphone calendar is not a big problem.
                  U must go to iCloud Calendar and make the calendar of your choice usable for public access.
                  After that copy the link of your public calendar and insert this link into the config.js in your calendar module.
                  restart your magicmirror
                  • yawnsY
                    yawns Moderator @CCoates
                    @CCoates said in Calendar modification:
                    I use my outlook.com calendar without any problems
                    C 1 Reply Last reply
                      CCoates @yawns
                      @yawns said in Calendar modification:
                      How do you find out the ical or link???
                      In outlook?
                      • yawnsY
                        yawns Moderator
                        I went to the web calendar on my computer (not on a smartphone or tablet!), went to settings (gear symbol top right) and clicked on options. The you see Publish Calendar and you are able to create the ics link.
                        • L
                          l8kerjuan
                          is there a full month layout module?
                          • MdManM
                            MdMan
                            Would this be the proper way to have it setup with both the Holiday cal and my personal shared one?
                            			header: "US Holidays",
                            						symbol: "calendar-check-o ",
                            			module: 'calendar',
                            			header: 'Shared',
                            			position: 'top_left',
                            			maximumNumberOfDays: 7,
                            						symbol: 'calendar-check-o ',
                            						url: 'https://calendar.google.com/calendar/ical/your-info'
                            Holiday Cal is good for me hahaha reminds me of days off lol
                            • MdManM
                              MdMan
                              For anyone wondering the same question as me, that would be how you do it. I tried it when I got home and my private calendar was also showing along with Holidays
                                patrickmcdiver @garnett
                                @garnett There is a public iCal and a private iCal. Use the private and you will not have to make calendar public.
                                  patrickmcdiver
                                  Your instructions are clear and consice and I was easily able to modify the module even though I am a beginner. However, I’m only displaying “all day” events for some reason. Any ideas?
