    Module WunderGround problem
    9 Posts 4 Posters 5.8k Views 3 Watching
      shgmongohh
      I have a problem with installing the WunderGround Module. I get some warnings when I execute npm install, see image.
      Can anybody please help me?
      Sebastian
      • strawberry 3.141S
        you are in the wrong directory cd into it first then npm install
          shgmongohh
          But which is the right directory?
          • strawberry 3.141S
            MMM-WunderGround
              shgmongohh
              No, that doesn´t work. I get the same message.
              • strawberry 3.141S
                well i looked in the repository and the author doesn’t say that you have to run the command npm install, so i don’t know why you are trying this?!
                • A
                  amanzimdwini @shgmongohh
                  @shgmongohh
                  It’s not obvious what to do - but you can look at the instructions for, say, MMM-Wunderlist:
                  “Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/paviro/MMM-Wunderlist.git. A new folder will appear navigate into it.”
                  So you need to do the same for WUNDERGROUND (but use the correct git). In other words, execute
                  sudo git clone https://github.com/RedNax67/MMM-WunderGround.git
                  Viel Glueck
                  • K
                    KirAsh4 Moderator
                    I said it before, I will say it again:
                    Do not run 'npm install' unless you are specifically told to do so by the module’s README, or by the author (who should be putting it in the README anyway.)
                      shgmongohh
                      Hello guys,
                      thank you for your help. I thought I have always to run npm install.
                      Now I´m a little bit smarter. Only run npm install when the author it´s write.
                      Sebastian
