Module WunderGround problem
9 Posts 4 Posters 5.2k Views 3 Watching
    shgmongohh
    I have a problem with installing the WunderGround Module. I get some warnings when I execute npm install, see image.
    Can anybody please help me?
    Sebastian
    A 1 Reply Last reply Jul 24, 2016, 3:43 AM Reply Quote 0
      you are in the wrong directory cd into it first then npm install
        shgmongohh
        But which is the right directory?
          MMM-WunderGround
            shgmongohh
            No, that doesn´t work. I get the same message.
              well i looked in the repository and the author doesn’t say that you have to run the command npm install, so i don’t know why you are trying this?!
                amanzimdwini @shgmongohh
                @shgmongohh
                It’s not obvious what to do - but you can look at the instructions for, say, MMM-Wunderlist:
                “Navigate into your MagicMirror’s modules folder and execute git clone https://github.com/paviro/MMM-Wunderlist.git. A new folder will appear navigate into it.”
                So you need to do the same for WUNDERGROUND (but use the correct git). In other words, execute
                sudo git clone https://github.com/RedNax67/MMM-WunderGround.git
                Viel Glueck
                • K Offline
                  KirAsh4 Moderator
                  I said it before, I will say it again:
                  Do not run 'npm install' unless you are specifically told to do so by the module’s README, or by the author (who should be putting it in the README anyway.)
                    shgmongohh
                    Hello guys,
                    thank you for your help. I thought I have always to run npm install.
                    Now I´m a little bit smarter. Only run npm install when the author it´s write.
                    Sebastian
