    Electron CPU usage
    247 Posts 46 Posters 628.1k Views 42 Watching
      Mykle1 Project Sponsor Module Developer @loctruong96
      @loctruong96 said in Electron CPU usage:
      it seems different people have different version of npm installed and you need the latest one.
      With regards to this topic only, you do NOT need or want the latest version of npm.
      You can also find the version of npm here MagicMirror/node_modules/electron/dist/version
      • cowboysdudeC Offline
        • L Offline
          loctruong96 @Mykle1
          @Mykle1 Agree, i was thinking the same thing. But some users are experiencing the problem where their npm failed to run install and start which i can only think of updating it which turned out to get it to work so far. I have also indicated a note in the install guide to have people aware of it.
              @cowboysdude said in Electron CPU usage:
              my bathroom mirror is a pi and it’s updated and I’m not having any of these issues…
              Would you please post your results, as everyone has above, for comparison? Raspbian version, MM version, Electron version and Pi version, and your nmon results
              • L Offline
                loctruong96 @cowboysdude
                Yeah, many didn’t update npm and have no problem whatsoever, only two users reported having 404 problem and only 1 user tried to npm install npm@latest -g and it worked for him. I made a note in my guide up in the thread in regard of this issue.
                  cowboysdude Module Developer @loctruong96
                    Very good! Thanks!
                      Mr.Sponti
                      Hello, here are some details on my configuration and the steps I’ve made to downgrade from 2.1.1 to MM 2.1.0 & electron 1.4.15. First, I use the following PI and OS
                      • Pi 3 Model B, 1024MB RAM
                      • Raspbian Stretch
                      pi@Infoboard:~ $ uname -a
                      Linux Infoboard 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
                      Downgrade MagicMirror from 2.1.1 to 2.1.0:
                      -rename of my MagicMirror folder to MagicMirrorSAVE
                      -download and unzip MM 2.1.0
                      -rename dir MagicMirror-2.1.0 to MagicMirror
                      -cd to MagicMirror
                      -npm install electron@1.4.15 # I didn’t install electron as a global package
                      -nano package.json
                      –> change electron version under dependencies to electron 1.4.15
                        "name": "magicmirror",
                        "version": "2.1.0",
                        "description": "A modular interface for smart mirrors.",
                        "main": "js/electron.js",
                        "scripts": {
                          "start": "electron js/electron.js"
                        "repository": {
                          "type": "git",
                       "dependencies": {
                          "electron": "1.4.15",
                          "express": "^4.14.0",
                          "express-ipfilter": "latest",
                          "feedme": "latest",
                      now, install MagicMirror
                      -npm install
                      -copy your own modules from the MagicMirrorSAVE to the respective MM2.1.0 directory
                      -install necessary node modules for your own modules
                      done
                      Check the installed version of electron
                      pi@Infoboard:~ $ more MagicMirror/node_modules/electron/dist/version
                      v1.4.15
                      run MM with ‘npm start’ and monitor the CPU usage with ‘top’
                      and the magic is there: 2 to 3 % CPU usage in case you are not running newsfeed or other modules with a lot of rendering stuff. If I include the newfeed modul CPU usage will increase up to 30%. So, I go without newsfeed!
                      alt text
                      I hope that help some or the other.
                      Mykle1M K 2 Replies Last reply Reply Quote 3
                        Mykle1 Project Sponsor Module Developer @Mr.Sponti
                        @Mr.Sponti said in Electron CPU usage:
                        Thank you for adding your results to this topic, and the steps you took to downgrade MM and Electron. I’m sure your post will help someone, as this topic has helped quite a few people.
                        Did you downgrade because you were having the CPU usage issue? Can you tell me what your usage was before you downgraded? Thanks
                          Mr.Sponti @Mykle1
                          @Mykle1 Yes, I downgraded due to high CPU usage with MM2.1.1 & electron1.4.17. Top showed a usage between 100 and 200% and my own written moduls had a really bad performance.
                            Ok, thank you. I’m glad that you’re seeing the benefit of this workaround. Let’s hope that it gets addressed and corrected sometime in the future.
                            • K Offline
                              Kugelfang @Mr.Sponti
                              @Mr.Sponti
                              I tried your precise instructions but my system still installed electron 1.7.9
                              i started with a fresh jessy install on my raspberry pi 3. i then installed the latest version of node.js and copied the MM 2.10 folder to my pi. I then modified the dependancy for electron to 1.4.15 in the package.json and run the installation. However i still ended up with electron 1.7.9 which runns really bad…
                              it would be great if someone could help me
                                Mykle1 Project Sponsor Module Developer @Kugelfang
                                @Kugelfang said in Electron CPU usage:
                                  Mr.Sponti
                                  cd $HOME/MagicMirror
                                  npm uninstall -g electron
                                  npm uninstall electron
                                  • K Offline
                                    Kugelfang
                                    @Mykle1: that seems to have worked. I just entered the MagicMirror folder and ran the command! thanks a lot! the animations are a lot better now!
                                    However, now i have another problem: it seems that the weather forecast module does not work. All other modules work as expected but the forecast does not show up. I double checked all the settings in the config.js and they seem ok.
                                    @Mr-Sponti: thanks for the input but it seems that simply installing 1.4.15 over the 1.7.9 seems to have already working
                                    Could it be that the weatherforecast plugin comming with MM 2.10 is the problem?
                                      I don’t think so. It’s more of an API key issue. The newer API keys are being rejected by the API source. You can search this forum. I don’t know if there is a fix. Or, try another weather module in the meantime
                                      • K Offline
                                        Kugelfang
                                        That is odd, my current config.js was working with my API keys for both actual weather and weather forecast modules brilliantly with the most recent mm version (the slow one)
                                        With 2.10/1.4.15 the actual weather module still works but the weather forecast modules simply does not show up on the screen although it’s fully setup in the config file including the proper API key
                                          @Kugelfang
                                          This is just one result of searching the forum for “Weather Not Showing”
                                          https://forum.magicmirror.builders/topic/4822/no-weather-showing
                                          • K Offline
                                            Kugelfang
                                            ok, thanks a lot, this was quite helpfull!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
