Modifying Compliments module
This is the config…VERY simple!
module: ‘MMM-NiceThings’,
position: ‘lower_third’
},@Mykle1 will show you the errors so if you want you can also fix your config :) He’s good like that!
@acbc18 said in Modifying Compliments module:
Can anyone figure out what I’m doing wrong?
Your use of curly quotes
“Good morning love!”,Should be
"Good morning love!",No more curly quotes, EVER! :^)
Just so we’re clear, you can’t use them at all so you’ll have to check your entire config for them.
Find ” and “ Replace with "
@Mykle1 EVERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR LOL
@Mykle1 Thank you. I’m new at this and didn’t notice it but will do from now on.
@Mykle1 Outside of that though is there any syntax issue with the lines starting with config: { down to compliments: {?
Edit: thanks guys turns out I had left out a comma and putting that in fixed it (after changing the quotes). -
No worries friend. We’ve all been there.
Excellent! Those are two things you won’t forget.
Enjoy your mirror! :^)
