    Can't access from external browser. (RPI zero non-W)
    11 Posts 3 Posters 6.3k Views 2 Watching
    • I Offline
      ImTheBadWolf @broberg
      @broberg Yes
        Mykle1 Project Sponsor Module Developer @ImTheBadWolf
        @ImTheBadWolf said in Can’t access from external browser. (RPI zero non-W):
        Thanks for your answer but that doesnt work either :(
        Can you post the beginning portion of your config?
        var config = {
        	port: 8080,
                address: "0.0.0.0",
        	ipWhitelist: [],
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
        • I Offline
          ImTheBadWolf
          • I Offline
            ImTheBadWolf @Mykle1
            @Mykle1
            var config = {
            address: “0.0.0.0”,
            port: 8085,
            //ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.112”, “192.168.1.102”],
            ipWhitelist: [],
            language: “”,
            timeFormat: 24,
            units: “metric”
              @ImTheBadWolf
              So then, this SHOULD work:
              http://192.168.1.20:8085 substitute your Pi’s ip address
              You took the language OUT of your config???
              • I Offline
                ImTheBadWolf
                Thanks guys it is working now… I dont know why but in the morning it wasnt working and now it is :D I didnt change everything except rebooted rpi so that may be the answer
                • brobergB Offline
                  broberg Project Sponsor
                  And the " marks your have posted are the wrong type as well.
                  " " and not “ ”
                  This is a common mistakes when using word editors to alter your config file, Smart Quotes I think it’s called, and is not accepted in the code.
