    MMM-NHL
    11 Posts 3 Posters 9.5k Views 3 Watching
    • cowboysdudeC Offline
      Description:
      NHL Scoreboard… just in time for the start of the season!
      Can view entire league or use focus_on to just view the team or teams you want!
      See Readme on Github.
      Screenshots:
      Start screen
      Last Season example
      Upcoming Match example
      Download:
      [card:cowboysdude/MMM-NHL]
      Version 1.0.0
        @cowboysdude said in MMM-NHL:
        That is a thing of beauty!
        • P-Bo726P Offline
          P-Bo726
          Need help troubleshoot this module. I’m a newbie and tried to troubleshoot before reaching out for help. The module is stuck on “Dropping the puck…”. Nothing stands out to me in the error log. I have run npm install from /MagicMirror/modules/MMM-Fracing as well as /MagicMirror/modules/MMM-NHL. I’ve removed and readded module to config file. Could I be missing a dependence?
          Here is my log
          magicmirror@2.1.2 start /home/pi/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.1.2
          Loading config …
          Loading module helpers …
          Module helper loaded: MMM-ModuleScheduler
          Module helper loaded: MMM-MyCalendar
          No helper found for module: MMM-EyeCandy.
          No helper found for module: calendar_monthly.
          Module helper loaded: MMM-NHL
          Module helper loaded: MMM-MotionEye
          Module helper loaded: MMM-JEOPARDY
          Module helper loaded: MMM-WunderGround
          Module helper loaded: MMM-Wunderlist
          Module helper loaded: MMM-MyCommute
          All module helpers loaded.
          Starting server on port 8080 …
          Server started …
          Connecting socket for: MMM-ModuleScheduler
          Starting node helper for: MMM-ModuleScheduler
          Connecting socket for: MMM-MyCalendar
          Starting node helper for: MMM-MyCalendar
          Connecting socket for: MMM-NHL
          Starting module: MMM-NHL
          Connecting socket for: MMM-MotionEye
          Starting module: MMM-MotionEye
          Connecting socket for: MMM-JEOPARDY
          Starting node_helper for: MMM-JEOPARDY
          Connecting socket for: MMM-WunderGround
          MMM-WunderGround helper started …
          Connecting socket for: MMM-Wunderlist
          Connecting socket for: MMM-MyCommute
          and config file:
                  		module: 'MMM-NHL',
                  		position: 'top_center',
          				focus_on: ['Blues'],
          				header: true,
          				maxWidth: "30%",
          				headlogo: true,
          				rotateInterval: 20 * 1000
            cowboysdude Module Developer @P-Bo726
            @P-Bo726 Yes I know that LOL Sorry… I did fix it but haven’t uploaded it yet to github, will do that tonight! :) It’s nothing you did wrong… it was a url issue
              @P-Bo726 there you go… working :)
              Tried to get the error checking to work but if there’s no match it’ll just show the date with nothing under it if you’re using focus_on… I’ll get to it… but for now it works again :)
              • P-Bo726P Offline
                P-Bo726
                Looks good. Thank you.
                  @P-Bo726 I’ve added error checking so if you’re using the focus_on and there is no match you’ll see this…
                  Do a git pull to get latest changes… :)
                  • P-Bo726P Offline
                    P-Bo726
                    I seem to still be having problems with this module. The day before the scheduled game the module displays a preview of the upcoming game. On the day of the game I get the error checking screen you referenced above.
                      Me too…just haven’t had time to look at like I should…but I promise I will :)
                      The focus_on seems to NOT work correctly…so I will investigate :)
                      • P-Bo726P Offline
                        P-Bo726
                        Have you had a chance to troubleshoot this module?
                          @P-Bo726 I have not but I promise to do in the next couple days :)
