Can not start MM anymore
 Hi, i have some problems - mainly after the latest update. I cant start MM anymore. The logfile (/home/pi/.npm/_logs/2017-10-14T02_58_48_833Z-debug.log) 0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'bugs', 'magicmirror' ] 2 info using npm@4.2.0 3 info using node@v7.10.1 4 silly fetchPackageMetaData magicmirror 5 silly fetchNamedPackageData magicmirror 6 silly mapToRegistry name magicmirror 7 silly mapToRegistry using default registry 8 silly mapToRegistry registry https://registry.npmjs.org/ 9 silly mapToRegistry data Result { 9 silly mapToRegistry raw: 'magicmirror', 9 silly mapToRegistry scope: null, 9 silly mapToRegistry escapedName: 'magicmirror', 9 silly mapToRegistry name: 'magicmirror', 9 silly mapToRegistry rawSpec: '', 9 silly mapToRegistry spec: 'latest', 9 silly mapToRegistry type: 'tag' } 10 silly mapToRegistry uri https://registry.npmjs.org/magicmirror 11 verbose request uri https://registry.npmjs.org/magicmirror 12 verbose request no auth needed 13 info attempt registry request try #1 at 04:58:46 14 verbose request id 3fa149b5af7f1094 15 verbose etag W/"56fbae0b-bef" 16 verbose lastModified Wed, 30 Mar 2016 10:44:27 GMT 17 http request GET https://registry.npmjs.org/magicmirror 18 http 304 https://registry.npmjs.org/magicmirror 19 verbose headers { date: 'Sat, 14 Oct 2017 02:58:46 GMT', 19 verbose headers via: '1.1 varnish', 19 verbose headers 'cache-control': 'max-age=300', 19 verbose headers etag: 'W/"56fbae0b-bef"', 19 verbose headers age: '22', 19 verbose headers connection: 'keep-alive', 19 verbose headers 'x-served-by': 'cache-hhn1550-HHN', 19 verbose headers 'x-cache': 'HIT', 19 verbose headers 'x-cache-hits': '1', 19 verbose headers 'x-timer': 'S1507949927.624052,VS0,VE0', 19 verbose headers vary: 'Accept-Encoding, Accept' } 20 silly get cb [ 304, 20 silly get { date: 'Sat, 14 Oct 2017 02:58:46 GMT', 20 silly get via: '1.1 varnish', 20 silly get 'cache-control': 'max-age=300', 20 silly get etag: 'W/"56fbae0b-bef"', 20 silly get age: '22', 20 silly get connection: 'keep-alive', 20 silly get 'x-served-by': 'cache-hhn1550-HHN', 20 silly get 'x-cache': 'HIT', 20 silly get 'x-cache-hits': '1', 20 silly get 'x-timer': 'S1507949927.624052,VS0,VE0', 20 silly get vary: 'Accept-Encoding, Accept' } ] 21 verbose etag https://registry.npmjs.org/magicmirror from cache 22 verbose get saving magicmirror to /home/pi/.npm/registry.npmjs.org/magicmirror/.cache.json 23 verbose correctMkdir /home/pi/.npm correctMkdir not in flight; initializing 24 silly bugs url https://github.com/MichMich/MagicMirror/issues 25 verbose stack Error: Command failed: xdg-open https://github.com/MichMich/MagicMirror/issues 25 verbose stack /usr/bin/xdg-open: 1: eval: www-browser: not found 25 verbose stack /usr/bin/xdg-open: 1: eval: links2: not found 25 verbose stack /usr/bin/xdg-open: 1: eval: elinks: not found 25 verbose stack /usr/bin/xdg-open: 1: eval: links: not found 25 verbose stack /usr/bin/xdg-open: 1: eval: lynx: not found 25 verbose stack /usr/bin/xdg-open: 1: eval: w3m: not found 25 verbose stack xdg-open: no method available for opening 'https://github.com/MichMich/MagicMirror/issues' 25 verbose stack 25 verbose stack at ChildProcess.exithandler (child_process.js:205:12) 25 verbose stack at emitTwo (events.js:106:13) 25 verbose stack at ChildProcess.emit (events.js:194:7) 25 verbose stack at maybeClose (internal/child_process.js:899:16) 25 verbose stack at Socket. (internal/child_process.js:342:11) 25 verbose stack at emitOne (events.js:96:13) 25 verbose stack at Socket.emit (events.js:191:7) 25 verbose stack at Pipe._handle.close [as _onclose] (net.js:511:12) 26 verbose cwd /home/pi/MagicMirror 27 error Linux 4.9.35-v7+ 28 error argv "/usr/bin/nodejs" "/usr/bin/npm" "bugs" "magicmirror" 29 error node v7.10.1 30 error npm v4.2.0 31 error code 3 32 error Command failed: xdg-open https://github.com/MichMich/MagicMirror/issues 32 error /usr/bin/xdg-open: 1: eval: www-browser: not found 32 error /usr/bin/xdg-open: 1: eval: links2: not found 32 error /usr/bin/xdg-open: 1: eval: elinks: not found 32 error /usr/bin/xdg-open: 1: eval: links: not found 32 error /usr/bin/xdg-open: 1: eval: lynx: not found 32 error /usr/bin/xdg-open: 1: eval: w3m: not found 32 error xdg-open: no method available for opening 'https://github.com/MichMich/MagicMirror/issues' 33 error If you need help, you may report this error at: 33 error 34 verbose exit [ 1, true ]and tail of the mm-error file: npm ERR! Please include the following file with any support request: npm ERR! /home/pi/.npm/_logs/2017-10-14T02_58_23_366Z-debug.log error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty fatal: loose object 5495af1f76e98870ede078c41304a08747792caa (stored in .git/objects/54/95af1f76e98870ede078c41304a08747792caa) is corrupt fatal: The remote end hung up unexpectedly Sat Oct 14 2017 04:58:52 GMT+0200 (CEST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now. npm ERR! Linux 4.9.35-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! node v7.10.1 npm ERR! npm v4.2.0 npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.1.3 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs magicmirror npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/.npm/_logs/2017-10-14T02_58_52_966Z-debug.log error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty fatal: loose object 5495af1f76e98870ede078c41304a08747792caa (stored in .git/objects/54/95af1f76e98870ede078c41304a08747792caa) is corrupt fatal: The remote end hung up unexpectedly Sat Oct 14 2017 04:59:23 GMT+0200 (CEST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now. npm ERR! Linux 4.9.35-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! node v7.10.1 npm ERR! npm v4.2.0 npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.1.3 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs magicmirror npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /home/pi/.npm/_logs/2017-10-14T02_59_23_738Z-debug.log error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty error: object file .git/objects/54/95af1f76e98870ede078c41304a08747792caa is empty fatal: loose object 5495af1f76e98870ede078c41304a08747792caa (stored in .git/objects/54/95af1f76e98870ede078c41304a08747792caa) is corrupt fatal: The remote end hung up unexpectedly
 @fox said in Can not start MM anymore: I cant start MM anymore. Most likely the update and/or the new dependencies failed to completely install. Long shot: run npm istallin the MagicMirror directory and try to run your mirror.
 Other case is don’t install updates if you don’t need to…
