    Touch overly VS. "Smart Glass"
    20 Posts 9 Posters 15.8k Views 8 Watching
      DongerZone
      I’m going to be working on this soon, after I get my modules reacting to my mouse. I think putting a transparent capacitive touch panel, in front of the mirror, might give you this effect. If you want to put the mirror on top though, I think you’re looking for a resistive touch panel.
      • cowboysdudeC Offline
        I’m using a 32" IR Touch frame… it works REALLY well… very responsive.
        Mykle1M H 2 Replies Last reply Reply Quote 0
          @cowboysdude said in Touch overly VS. “Smart Glass”:
          Yes, but he would like to know if works with acrylic as opposed to actual glass. I could not help him as I don’t have real glass OR a touch screen.
            broberg Project Sponsor
            An IR-frame isn’t affected by the type of mirror (since it is placed in front of everything).
            Touch foils (pcap) however can’t be used on glass with metallic coatings, which most of the mirrors have, because the metal distorts the readings of the foil sensors.
            With that said I don’t know how the touch foil would react behind an acrylic mirror but my guess is that it most likely won’t work. (As most plastics are prone to get staticly charged and that could probably have a negative impact on the touch foil as well).
              broberg Project Sponsor @DongerZone
              @DongerZone said in Touch overly VS. “Smart Glass”:
              This could actually work, it will build on the thickness and weight of the mirror but you could have a really thin frame instead of a IR-frame around it.
              So it would be layers like :
              Glass
              Touch foil
              Air gap
              Mirror
              Screen
                I’m using an IR frame with standard window glass (1/8") thick.
                peemoellerP 1 Reply Last reply Reply Quote 0
                • H Offline
                  Hoosierdad @cowboysdude
                  @cowboysdude Yes mykle1 is correct. My plan is to turn it into a selfie mirror. i ran across this website that claims their glass works well with touch screens but like most people on their first build i’m trying to keep the cost down. So if i could use the same acrylic as opposed to a $350 glass i want to do it.
                  • H Offline
                    Hoosierdad
                    here is what i am trying to build Click here
                    But I want to start off small with a “table top” maybe 22" wide x 34" High or something like that.
                      MattZw @Hoosierdad
                      @Hoosierdad Have you managed to get the project done? What solution did you use ?
                        cowboysdude Module Developer @Hoosierdad
                        @Hoosierdad I paid about 110.00 for my IR frame…but I"m in the US too. I’m hearing horror stories of people paying HUGE amounts of money for shipping… just be careful whatever you decide :)
                          MattZw
                          This is my final product, the selfie magic mirror !
                            MMENT08048 @MattZw
                            @MattZw this is exactly what I’d love to build. Would you mind sharing with me how you did it and the costs?
                              MattZw @MMENT08048
                              @MMENT08048 around 3.5k euro
                              M S 2 Replies Last reply Reply Quote 0
                                MMENT08048 @MattZw
                                @MattZw where did you place the IR frame? Is it on the mirror or the monitor?
                                  stilly8 @MMENT08048
                                  @MMENT08048 I’m in the beginning stages of making one too. Since your using IR then you are using real glass? I am looking to buy a 36 x 60 inch 2way mirror. I was quoted $2500.00 U.S. Dollars. It’s seems a bit much, can you share what you are finding or maybe you have bought it by now. I heard to use Dialect Glass. Can you let me know any information about the he glass you have found. Acrylic it real glass? Thank you
                                    stilly8 @MattZw
                                    @MattZw Hi Matt, Can you let me know if you used real glass or acrylic? I heard the clearest material to use is Dialect Glass? Could you share what you have found? Thank you!
                                      stilly8 @cowboysdude
                                      @cowboysdude Hello, Do you know what the best glass to use for a smart mirror or mirror photo booth? I heard to use 2way mirror that is Dialect Glass. So I have heard if people using Acrylic, Dialect, or regular glass for the mirror. Can you help up clear what is the best material to use? Please and thank you!
                                        MMENT08048 @stilly8
                                        @stilly8 hello. I haven’t ordered yet but from what I’ve been reading acrylic seems to be the cheapest and works fine. Let me know how your build goes. I’m excited to work on this project!
                                        • peemoellerP Offline
                                          peemoeller @cowboysdude
                                          @cowboysdude Hi, I have my MM up and running but can’t seem to get my 42” IR Touch Frame to adjust from Landscape mode to Portrait. I swipe up but the cursor moves left. I installed Xinput but not having any luck :(
                                          How did you get you IR calibrated?
                                          Cheers!
