    [SOLVED] Dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported
    5 Posts 3 Posters 3.8k Views 2 Watching
      [[global:former-user]]
      Hi.
      I’m trying to add a birthday calendar from my NexClound server, but it fails with the error “Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported”. The other calendars I’ve added works fine.
      The dates added to this calendar reflects when the person is born, thus i have dates previous to 1970.
      The complete error log i get is;
          at Object.toOrdinal (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:105:15)
          at Iterinfo.rebuild (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:1409:35)
          at RRule._iter (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:978:10)
          at RRule.between (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:794:21)
          at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:135:24
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
          at emitTwo (events.js:106:13)
          at Request.emit (events.js:191:7)
          at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
      Any idea how to fix this?
        Mykle1 Project Sponsor Module Developer @Guest
        @zynex said in Dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported:
        This issue came up a couple of months ago. You can try a forum search to see if they came up with a fix. Temporarily, you could change the date in your calendar so it’s usable. Good luck
          jasondreher
          You need to edit the /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js file. See the post below.
          https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
          From the post…
          Edit this file
          Go to line 56 or search for the first occurance of “ORDINAL_BASE” and change this line:
          ORDINAL_BASE: new Date(1970, 0, 1),
          set it to a lower year like 1900.
          Then restart your magic mirror (pm2 restart mm)
          ? Mykle1M 2 Replies Last reply Reply Quote 2
            [[global:former-user]] @jasondreher
            @jasondreher That worked like a charm! Thanks for the help :)
              Mykle1 Project Sponsor Module Developer @jasondreher
              @jasondreher said in [SOLVED] Dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported:
              Excellent!
