    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.7k Views 47 Watching
      A Former User @hoggboss22
      @hoggboss22 your mm seems being excuted multiple. Common pitfal is that more than one browser are opened.(maybe your previous test running?)
      Or your machine is already using port 8080.
      Kill all browsers(and node or npm) and restart. Or change port in your config like 8088.
      • H
        hoggboss22
        I thought the same thing, i changed from 8080 to 9090 and it gave me the same error. I ran the net stat command to find the port being in used and guess what… there was nothing that is using 8080 or 9090
        Active Internet connections (only servers)
        Proto Recv-Q Send-Q Local Address           Foreign Address         State
        tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN
        tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN
        tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
        udp        0      0 0.0.0.0:mdns            0.0.0.0:*
        udp        0      0 0.0.0.0:49645           0.0.0.0:*
        udp        0      0 0.0.0.0:bootpc          0.0.0.0:*
        udp6       0      0 [::]:mdns               [::]:*
        udp6       0      0 [::]:44605              [::]:*
        raw6       0      0 [::]:ipv6-icmp          [::]:*                  7
        Active UNIX domain sockets (only servers)
        Proto RefCnt Flags       Type       State         I-Node   Path
        unix  2      [ ACC ]     STREAM     LISTENING     7951     /var/run/dbus/system_bus_socket
        unix  2      [ ACC ]     STREAM     LISTENING     7954     /var/run/avahi-daemon/socket
        unix  2      [ ACC ]     STREAM     LISTENING     7957     /run/thd.socket
        unix  2      [ ACC ]     STREAM     LISTENING     10463    @/tmp/.X11-unix/X0
        unix  2      [ ACC ]     STREAM     LISTENING     5161     /run/systemd/fsck.progress
        unix  2      [ ACC ]     STREAM     LISTENING     10321    /run/user/1000/systemd/private
        unix  2      [ ACC ]     STREAM     LISTENING     10326    /run/user/1000/gnupg/S.gpg-agent
        unix  2      [ ACC ]     STREAM     LISTENING     10329    /run/user/1000/bus
        unix  2      [ ACC ]     STREAM     LISTENING     4967     /run/systemd/private
        unix  2      [ ACC ]     STREAM     LISTENING     10331    /run/user/1000/gnupg/S.gpg-agent.browser
        unix  2      [ ACC ]     STREAM     LISTENING     10363    /run/user/1000/gnupg/S.gpg-agent.ssh
        unix  2      [ ACC ]     STREAM     LISTENING     10365    /run/user/1000/gnupg/S.gpg-agent.extra
        unix  2      [ ACC ]     STREAM     LISTENING     8845     /var/run/dhcpcd.sock
        unix  2      [ ACC ]     STREAM     LISTENING     5005     /run/systemd/journal/stdout
        unix  2      [ ACC ]     STREAM     LISTENING     8847     /var/run/dhcpcd.unpriv.sock
        unix  2      [ ACC ]     SEQPACKET  LISTENING     5325     /run/udev/control
        unix  2      [ ACC ]     STREAM     LISTENING     10464    /tmp/.X11-unix/X0
          12wsx
          Hello:) I have similar problem. Magic Mirror installed from image downloaded from this thread. Installed on piZero. Working ok. On screen there was a message to update. I did this and now MM not working. Try config with only clock. Not help.
          Full update log.
           Starting MagicMirror: v2.1.0
          Loading config ...
          Loading module helpers ...
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Ready to go! Please point your browser to: http://localhost:8080
          { [Error: listen EADDRINUSE :::8080]
            code: 'EADDRINUSE',
            errno: 'EADDRINUSE',
            syscall: 'listen',
            address: '::',
            port: 8080 }
          MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
          If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
          (EE)
          Fatal server error:
          (EE) Server is already active for display 0
                  If this server is no longer running, remove /tmp/.X0-lock
                  and start again.
          (EE)
          (EE)
          Please consult the The X.Org Foundation support
                   at http://wiki.x.org
           for help.
          (EE)
          XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                after 7 requests (7 known processed) with 0 events remaining.
          pi@raspberrypi:~ $ ^C
          pi@raspberrypi:~ $ sudo su
          root@raspberrypi:/home/pi# cd ~/MagicMirror && sudo npm install
          bash: cd: /root/MagicMirror: No such file or directory
          root@raspberrypi:/home/pi# cd MagicMirror
          root@raspberrypi:/home/pi/MagicMirror# sudo npm install
          npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from stylelint-config-standard will no
          npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
          npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
          npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from stylelint-config-recommended will no
          npm WARN peerDependencies The peer dependency stylelint@^8.0.0 included from grunt-stylelint will no
          npm ERR! Linux 4.4.34+
          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
          npm ERR! node v4.2.1
          npm ERR! npm  v2.14.7
          npm ERR! code EPEERINVALID
          npm ERR! peerinvalid The package stylelint@7.7.1 does not satisfy its siblings' peerDependencies requirements!
          npm ERR! peerinvalid Peer grunt-stylelint@0.9.0 wants stylelint@^8.0.0
          npm ERR! peerinvalid Peer stylelint-config-standard@17.0.0 wants stylelint@^8.0.0
          npm ERR!     /home/pi/MagicMirror/npm-debug.log
          root@raspberrypi:/home/pi/MagicMirror# vendor && npm install
          bash: vendor: command not found
          ? 1 Reply Last reply
            A Former User @12wsx
            @12wsx
            Sometimes, this error seems to happen when MM is terminated abnormally. (I don’t know what is normal termination. :D)
            In my case, execution npm for debug or test after first normal pm2 bootup makes this error.(Of course, before npm start dev I stopped pm2 process.)
            For the solution, I change port from 8080 to 8081 or from 8081 to 8080(when I meet this problem again). It seems that after some minutes the port is freed automatically(or by execution with port changed.). And fortunately for me, first execution of MM(by pm2 on bootup) is always a success. So… I stop caring about this.
              12wsx
              my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
              P 1 Reply Last reply
                psteimann @12wsx
                @12wsx Change the Port from 8080 to 8099 and then try again…solved a lot of problems for me…
                • H
                  Hawking
                  After some weeks with the MagicMirror running, my SD card got corrupted and I decided to reinstall the system from scratch. I switched from “Jessie Light” to “Stretch light”, used node 6.11.4 and of course the latest MagicMirror 2.1.3.
                  I can access the MM from the browser of my laptop, but Midori only shows a white page. Even for a very simple config file:
                  var config = {
                          address: "",
                          port: 8080,
                          ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                          language: "en",
                          units: "metric",
                                  module: "helloworld",
                                  position: "bottom_bar",
                                          text: "Hello world!"
                  The start of MM gives no error
                  Starting MagicMirror: v2.1.3
                  Loading config ...
                  No helper found for module: helloworld.
                  Server started ...
                  and if I change from
                  midori -e Fullscreen -a http://localhost:8080
                  to
                  midori -e Fullscreen -a http://www.google.de
                  I see the google page. So Midori itself and the output on screen seems working as well.
                  Is anybody having an idea where to search for the error?
                  Is anybody using MagicMirror 2.1.3 on its Pi Zero?
                  D 1 Reply Last reply
                    Doubleve @Hawking
                    @Hawking same problem rpi 1
                    N 1 Reply Last reply
                    • N
                      noorm91 @Doubleve
                        12wsx
                        first set:
                        set ipWhitelist: [] to allow all IP addresses.
                        Warning, this enables from everywhere (on your net) have access.
                        then in webbrowser go to pizero ip with port set in config ex. 192.168.1.12:8080 and check if its working
                          Doubleve
                          don’t work for me, cannot connect to destination :-(
                          when i do
                          DISPLAY=:0 npm start
                          npm ERR! code ENOENT
                          npm ERR! errno -2
                          npm ERR! syscall open
                          npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                          npm ERR! enoent This is related to npm not being able to find a file.
                          npm ERR! enoent
                          npm ERR! /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log
                          D H 2 Replies Last reply
                            Doubleve @Doubleve
                            why he’s looking for /home/pi/package.json then it is /home/pi/MagicMirror/package.json ?
                            This is my log
                            /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log:
                            1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                            2 info using npm@5.3.0
                            3 info using node@v8.3.0
                            4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                            5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                            6 verbose cwd /home/pi
                            7 verbose Linux 4.1.19+
                            8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                            9 verbose node v8.3.0
                            10 verbose npm v5.3.0
                            11 error path /home/pi/package.json
                            12 error code ENOENT
                            13 error errno -2
                            14 error syscall open
                            15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                            16 error enoent This is related to npm not being able to find a file.
                            17 verbose exit [ -2, true ]
                            • H
                              Hawking @Doubleve
                              @Doubleve
                              In which directory did you execute npm start
                              ? I would assume you would first go to your MagicMirror directory (cd /home/pi/MagicMirror ). This would also explain the problem with the missing package.json file.
                              However, I’m not sure if npm start works at all in combination with the serveronly mode (needed for the Pi Zero). For starting, I use the method described in the first post of this thread in the section “Setting up boot scripts”.
                              I can acccess my MM from remote, however still didn’t get it to show in the Midori browser :-/
                                Doubleve
                                as you said I was not in the right record.
                                I had an error with the libnss3 library. Now more error
                                DISPLAY =: 0 npm start
                                magicmirror@2.1.3 start / home / pi / MagicMirror
                                sh run-start.sh
                                pi @ raspberrypi ~ / MagicMirror $ npm run config: check
                                magicmirror@2.1.3 config: check / home / pi / MagicMirror
                                node tests / configs / check_config.js
                                Checking file … /home/pi/MagicMirror/config/config.js
                                Your configuration file not containt syntax error :)
                                but it still does not work with midori
                                • N
                                  noorm91
                                  What does npm start do in /MagicMirror
                                  B 1 Reply Last reply
                                    bhepler Module Developer @noorm91
                                    @noorm91 npm start is the command to start the Magic Mirror application and display the interface on the screen.
                                    • N
                                      noorm91 @bhepler
                                      @bhepler
                                      I can’t seem to start MM with npm start, tried through SSH and directly on rpi with keyboard.
                                      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                                      [1] 890
                                      pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’
                                      ^C
                                      [1]+ Exit 1 DISPLAY=:0 nohup npm start
                                      magicmirror@2.1.0 start /home/pi/MagicMirror
                                      electron js/electron.js
                                      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                                      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                                      npm ERR! file sh
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno ENOENT
                                      npm ERR! syscall spawn
                                      npm ERR! magicmirror@2.1.0 start: electron js/electron.js
                                      npm ERR! spawn ENOENT
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                                      npm ERR! This is most likely a problem with the magicmirror package,
                                      npm ERR! not with npm itself.
                                      npm ERR! electron js/electron.js
                                      npm ERR! You can get their info via:
                                      npm ERR! npm owner ls magicmirror
                                      H 1 Reply Last reply
                                      • H
                                        Hawking @noorm91
                                        @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                                        @bhepler
                                        Thats what I expected for the Pi Zero. Did you try the method described in the first post of this thread in the section “Setting up boot scripts”?
                                          Doubleve
                                          I took everything back with the first post everything works !!!
                                          • H
                                            Hawking @Doubleve
                                            @Doubleve
                                            Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
                                            • 10
                                            • 11
                                            • 7 / 11
