    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.6k Views 47 Watching
      A Former User @12wsx
      @12wsx
      Sometimes, this error seems to happen when MM is terminated abnormally. (I don’t know what is normal termination. :D)
      In my case, execution npm for debug or test after first normal pm2 bootup makes this error.(Of course, before npm start dev I stopped pm2 process.)
      For the solution, I change port from 8080 to 8081 or from 8081 to 8080(when I meet this problem again). It seems that after some minutes the port is freed automatically(or by execution with port changed.). And fortunately for me, first execution of MM(by pm2 on bootup) is always a success. So… I stop caring about this.
        12wsx
        my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
        P 1 Reply Last reply
          psteimann @12wsx
          @12wsx Change the Port from 8080 to 8099 and then try again…solved a lot of problems for me…
          • H
            Hawking
            After some weeks with the MagicMirror running, my SD card got corrupted and I decided to reinstall the system from scratch. I switched from “Jessie Light” to “Stretch light”, used node 6.11.4 and of course the latest MagicMirror 2.1.3.
            I can access the MM from the browser of my laptop, but Midori only shows a white page. Even for a very simple config file:
            var config = {
                    address: "",
                    port: 8080,
                    ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                    language: "en",
                    units: "metric",
                            module: "helloworld",
                            position: "bottom_bar",
                                    text: "Hello world!"
            The start of MM gives no error
            Starting MagicMirror: v2.1.3
            Loading config ...
            Loading module helpers ...
            No helper found for module: helloworld.
            All module helpers loaded.
            Server started ...
            Ready to go! Please point your browser to: http://localhost:8080
            and if I change from
            midori -e Fullscreen -a http://localhost:8080
            to
            midori -e Fullscreen -a http://www.google.de
            I see the google page. So Midori itself and the output on screen seems working as well.
            Is anybody having an idea where to search for the error?
            Is anybody using MagicMirror 2.1.3 on its Pi Zero?
            D 1 Reply Last reply
              Doubleve @Hawking
              @Hawking same problem rpi 1
              N 1 Reply Last reply
              • N
                noorm91 @Doubleve
                  12wsx
                  first set:
                  set ipWhitelist: [] to allow all IP addresses.
                  Warning, this enables from everywhere (on your net) have access.
                  then in webbrowser go to pizero ip with port set in config ex. 192.168.1.12:8080 and check if its working
                    Doubleve
                    don’t work for me, cannot connect to destination :-(
                    when i do
                    DISPLAY=:0 npm start
                    npm ERR! code ENOENT
                    npm ERR! errno -2
                    npm ERR! syscall open
                    npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                    npm ERR! enoent This is related to npm not being able to find a file.
                    npm ERR! enoent
                    npm ERR! /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log
                    D H 2 Replies Last reply
                      Doubleve @Doubleve
                      why he’s looking for /home/pi/package.json then it is /home/pi/MagicMirror/package.json ?
                      This is my log
                      /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log:
                      1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                      2 info using npm@5.3.0
                      3 info using node@v8.3.0
                      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                      5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                      6 verbose cwd /home/pi
                      7 verbose Linux 4.1.19+
                      8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                      9 verbose node v8.3.0
                      10 verbose npm v5.3.0
                      11 error path /home/pi/package.json
                      12 error code ENOENT
                      13 error errno -2
                      14 error syscall open
                      15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                      16 error enoent This is related to npm not being able to find a file.
                      17 verbose exit [ -2, true ]
                      • H
                        Hawking @Doubleve
                        @Doubleve
                        In which directory did you execute npm start
                        ? I would assume you would first go to your MagicMirror directory (cd /home/pi/MagicMirror ). This would also explain the problem with the missing package.json file.
                        However, I’m not sure if npm start works at all in combination with the serveronly mode (needed for the Pi Zero). For starting, I use the method described in the first post of this thread in the section “Setting up boot scripts”.
                        I can acccess my MM from remote, however still didn’t get it to show in the Midori browser :-/
                          Doubleve
                          as you said I was not in the right record.
                          I had an error with the libnss3 library. Now more error
                          DISPLAY =: 0 npm start
                          magicmirror@2.1.3 start / home / pi / MagicMirror
                          sh run-start.sh
                          pi @ raspberrypi ~ / MagicMirror $ npm run config: check
                          magicmirror@2.1.3 config: check / home / pi / MagicMirror
                          node tests / configs / check_config.js
                          Checking file … /home/pi/MagicMirror/config/config.js
                          Your configuration file not containt syntax error :)
                          but it still does not work with midori
                          • N
                            noorm91
                            What does npm start do in /MagicMirror
                            B 1 Reply Last reply
                              bhepler Module Developer @noorm91
                              @noorm91 npm start is the command to start the Magic Mirror application and display the interface on the screen.
                              • N
                                noorm91 @bhepler
                                @bhepler
                                I can’t seem to start MM with npm start, tried through SSH and directly on rpi with keyboard.
                                pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                                [1] 890
                                pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’
                                ^C
                                [1]+ Exit 1 DISPLAY=:0 nohup npm start
                                magicmirror@2.1.0 start /home/pi/MagicMirror
                                electron js/electron.js
                                /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                                npm ERR! Linux 4.4.34+
                                npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                                npm ERR! node v4.2.1
                                npm ERR! npm v2.14.7
                                npm ERR! file sh
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno ENOENT
                                npm ERR! syscall spawn
                                npm ERR! magicmirror@2.1.0 start: electron js/electron.js
                                npm ERR! spawn ENOENT
                                npm ERR!
                                npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                                npm ERR! This is most likely a problem with the magicmirror package,
                                npm ERR! not with npm itself.
                                npm ERR! electron js/electron.js
                                npm ERR! You can get their info via:
                                npm ERR! npm owner ls magicmirror
                                npm ERR! /home/pi/MagicMirror/npm-debug.log
                                H 1 Reply Last reply
                                • H
                                  Hawking @noorm91
                                  @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                                  @bhepler
                                  Thats what I expected for the Pi Zero. Did you try the method described in the first post of this thread in the section “Setting up boot scripts”?
                                    Doubleve
                                    I took everything back with the first post everything works !!!
                                    • H
                                      Hawking @Doubleve
                                      @Doubleve
                                      Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
                                        delusional112
                                        Hi guys, I saw someone asked before, isn’t there anyone who has a working image for MM2 on a Pi Zero. I tried a lot of things before, cant get it to work. Now, I don’t have a lot of time to experiment with it, school and work are killing me. My mirror is lying around, unused. Please help me out here,
                                        Thanks!!
                                        • N
                                          noorm91 @delusional112
                                          @delusional112
                                          Here is an image, it has a couple of errors that needs fixing but the magicmirror starts at least.
                                          If you have any solutions please keep us informed…this image is made by Sebtota.
                                          https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
                                          Here is the topic I found the image at.
                                          https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/85?page=9
                                          • N
                                            noorm91
                                            Any clue on what is trying to start and not functioning alright here?
                                            Starting MagicMirror: v2.1.0
                                            Loading config ...
                                            Starting server op port 8080 ...
                                            Server started ...
                                            Starting module: newsfeed
                                            { [Error: listen EADDRINUSE :::8080]
                                              code: 'EADDRINUSE',
                                              errno: 'EADDRINUSE',
                                              syscall: 'listen',
                                              address: '::',
                                              port: 8080 }
                                            (EE)
                                            Fatal server error:
                                            (EE) Server is already active for display 0
                                                    If this server is no longer running, remove /tmp/.X0-lock
                                                    and start again.
                                            (EE)
                                            (EE)
                                            Please consult the The X.Org Foundation support
                                                     at http://wiki.x.org
                                             for help.
                                            (EE)
                                            XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                                  after 7 requests (7 known processed) with 0 events remaining.
                                            • 10
                                            • 11
                                            • 7 / 11
