    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.7k Views 47 Watching
      Doubleve
      don’t work for me, cannot connect to destination :-(
      when i do
      DISPLAY=:0 npm start
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log
      D H 2 Replies Last reply
        Doubleve @Doubleve
        why he’s looking for /home/pi/package.json then it is /home/pi/MagicMirror/package.json ?
        This is my log
        /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log:
        1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
        2 info using npm@5.3.0
        3 info using node@v8.3.0
        4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
        5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
        6 verbose cwd /home/pi
        7 verbose Linux 4.1.19+
        8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
        9 verbose node v8.3.0
        10 verbose npm v5.3.0
        11 error path /home/pi/package.json
        12 error code ENOENT
        13 error errno -2
        14 error syscall open
        15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
        16 error enoent This is related to npm not being able to find a file.
        17 verbose exit [ -2, true ]
        • H
          Hawking @Doubleve
          @Doubleve
          In which directory did you execute npm start
          ? I would assume you would first go to your MagicMirror directory (cd /home/pi/MagicMirror ). This would also explain the problem with the missing package.json file.
          However, I’m not sure if npm start works at all in combination with the serveronly mode (needed for the Pi Zero). For starting, I use the method described in the first post of this thread in the section “Setting up boot scripts”.
          I can acccess my MM from remote, however still didn’t get it to show in the Midori browser :-/
            Doubleve
            as you said I was not in the right record.
            I had an error with the libnss3 library. Now more error
            DISPLAY =: 0 npm start
            magicmirror@2.1.3 start / home / pi / MagicMirror
            sh run-start.sh
            pi @ raspberrypi ~ / MagicMirror $ npm run config: check
            magicmirror@2.1.3 config: check / home / pi / MagicMirror
            node tests / configs / check_config.js
            Checking file … /home/pi/MagicMirror/config/config.js
            Your configuration file not containt syntax error :)
            but it still does not work with midori
            • N
              noorm91
              What does npm start do in /MagicMirror
              B 1 Reply Last reply
                bhepler Module Developer @noorm91
                @noorm91 npm start is the command to start the Magic Mirror application and display the interface on the screen.
                N 1 Reply Last reply
                • N
                  noorm91 @bhepler
                  @bhepler
                  I can’t seem to start MM with npm start, tried through SSH and directly on rpi with keyboard.
                  pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                  [1] 890
                  pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’
                  ^C
                  [1]+ Exit 1 DISPLAY=:0 nohup npm start
                  magicmirror@2.1.0 start /home/pi/MagicMirror
                  electron js/electron.js
                  /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                  npm ERR! Linux 4.4.34+
                  npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                  npm ERR! node v4.2.1
                  npm ERR! npm v2.14.7
                  npm ERR! file sh
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.1.0 start: electron js/electron.js
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                  npm ERR! This is most likely a problem with the magicmirror package,
                  npm ERR! not with npm itself.
                  npm ERR! electron js/electron.js
                  npm ERR! You can get their info via:
                  npm ERR! npm owner ls magicmirror
                  npm ERR! /home/pi/MagicMirror/npm-debug.log
                  H 1 Reply Last reply
                  • H
                    Hawking @noorm91
                    @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                    @bhepler
                    Thats what I expected for the Pi Zero. Did you try the method described in the first post of this thread in the section “Setting up boot scripts”?
                      Doubleve
                      I took everything back with the first post everything works !!!
                      • H
                        Hawking @Doubleve
                        @Doubleve
                        Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
                          delusional112
                          Hi guys, I saw someone asked before, isn’t there anyone who has a working image for MM2 on a Pi Zero. I tried a lot of things before, cant get it to work. Now, I don’t have a lot of time to experiment with it, school and work are killing me. My mirror is lying around, unused. Please help me out here,
                          Thanks!!
                          • N
                            noorm91 @delusional112
                            @delusional112
                            Here is an image, it has a couple of errors that needs fixing but the magicmirror starts at least.
                            If you have any solutions please keep us informed…this image is made by Sebtota.
                            https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
                            Here is the topic I found the image at.
                            https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/85?page=9
                            • N
                              noorm91
                              Any clue on what is trying to start and not functioning alright here?
                              Starting MagicMirror: v2.1.0
                              Loading config ...
                              Loading module helpers ...
                              All module helpers loaded.
                              Starting server op port 8080 ...
                              Server started ...
                              Starting module: newsfeed
                              Ready to go! Please point your browser to: http://localhost:8080
                              { [Error: listen EADDRINUSE :::8080]
                                code: 'EADDRINUSE',
                                errno: 'EADDRINUSE',
                                syscall: 'listen',
                                address: '::',
                                port: 8080 }
                              (EE)
                              Fatal server error:
                              (EE) Server is already active for display 0
                                      If this server is no longer running, remove /tmp/.X0-lock
                                      and start again.
                              (EE)
                              (EE)
                              Please consult the The X.Org Foundation support
                                       at http://wiki.x.org
                               for help.
                              (EE)
                              XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                    after 7 requests (7 known processed) with 0 events remaining.
                                Whoops! There was an uncaught exception…
                                8080]
                                This usually means that you already have a process trying to serve up web pages on port 8080. In my experience, this happens when you do not terminate your previous attempt to run the MM process and start up another one. The new one also tries to serve up pages on port 8080 and you get that error.
                                You can use ps ax | grep node to see if node is running when you attempt to start your mirror. If it is, node is already serving up pages, so you will want to stop whatever process is running first. Alternately, if you are running a web server on port 8080 already, you can switch the port of the MM process in the config.js file.
                                • MarWindM
                                  MarWind
                                  So did anyone get MM2 on a Pi Zero W with Raspian Stretch lite running?
                                  Or is it better to stay with Jessie?
                                  ~ride bikes and boards not always on top~
                                  • H
                                    Hawking @MarWind
                                    @MarWind
                                    I still didn’t get it to work using Midori in combination with Raspian Stretch Lite.
                                    On this distribution, I could only get it to work using Epiphany or Chromium. However, their performance is much slower than Midori (which worked fine in Jessie Lite). I can’t tell if this is due to some general changes in Stretch or in the newer versions of Midori.
                                    • N
                                      noorm91
                                      How did you install Chromium on rpi 0 ?
                                      • MarWindM
                                        MarWind
                                        @hawking, thanks for your answer!
                                        I’ll do some more testing:
                                        *So my main issue will be now the update of mm2 :-(
                                        I’m running an working image on the pi zero w with npm 2.14 and node 4.2.1 for month’s now.
                                        But after updating MM2 last week with git pull && npm install it’s broken :-(
                                        • H
                                          Hawking @noorm91
                                          @noorm91
                                          I simply did
                                          sudo apt-get install chromium-browser
                                          and the start is by
                                          chromium-browser --incognito --kiosk http://localhost:8080
                                          I don’t know if this is a new possibility in Stretch light or is also possible in Jessie Lite (I know that there were some issues in the past). However, as I said, the performance is slow and not stable (I see that the free amount of memory gets low and the system freezes every few hours). Therefore I would prefer to use still Midori, whoch worked fine for me in Jessie. However, using Midori with Stretch I simply get a black screen. I don’t know if this is due to an error in my installation, due to changes from Jessie to Stretch, due to changes in the Midori browser, due to changes in MM (I tried to install an older version, which didn’t help) or yet another reason.
                                            Parth Bhandari
                                            • 10
                                            • 11
                                            • 7 / 11
