    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 661.4k Views 47 Watching
      psteimann @12wsx
      @12wsx Change the Port from 8080 to 8099 and then try again…solved a lot of problems for me…
      • H Offline
        Hawking
        After some weeks with the MagicMirror running, my SD card got corrupted and I decided to reinstall the system from scratch. I switched from “Jessie Light” to “Stretch light”, used node 6.11.4 and of course the latest MagicMirror 2.1.3.
        I can access the MM from the browser of my laptop, but Midori only shows a white page. Even for a very simple config file:
        var config = {
                address: "",
                port: 8080,
                ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                language: "en",
                units: "metric",
                        module: "helloworld",
                        position: "bottom_bar",
                                text: "Hello world!"
        The start of MM gives no error
        Starting MagicMirror: v2.1.3
        Loading config ...
        Loading module helpers ...
        No helper found for module: helloworld.
        All module helpers loaded.
        Server started ...
        Ready to go! Please point your browser to: http://localhost:8080
        and if I change from
        midori -e Fullscreen -a http://localhost:8080
        to
        midori -e Fullscreen -a http://www.google.de
        I see the google page. So Midori itself and the output on screen seems working as well.
        Is anybody having an idea where to search for the error?
        Is anybody using MagicMirror 2.1.3 on its Pi Zero?
          Doubleve @Hawking
          @Hawking same problem rpi 1
          • N Offline
            noorm91 @Doubleve
            • 1 Offline
              12wsx
              first set:
              set ipWhitelist: [] to allow all IP addresses.
              Warning, this enables from everywhere (on your net) have access.
              then in webbrowser go to pizero ip with port set in config ex. 192.168.1.12:8080 and check if its working
                Doubleve
                don’t work for me, cannot connect to destination :-(
                when i do
                DISPLAY=:0 npm start
                npm ERR! code ENOENT
                npm ERR! errno -2
                npm ERR! syscall open
                npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                npm ERR! enoent This is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR! /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log
                D H 2 Replies Last reply Reply Quote 0
                  Doubleve @Doubleve
                  why he’s looking for /home/pi/package.json then it is /home/pi/MagicMirror/package.json ?
                  This is my log
                  /home/pi/.npm/_logs/2017-10-19T18_58_10_170Z-debug.log:
                  1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                  2 info using npm@5.3.0
                  3 info using node@v8.3.0
                  4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                  5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                  6 verbose cwd /home/pi
                  7 verbose Linux 4.1.19+
                  8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                  9 verbose node v8.3.0
                  10 verbose npm v5.3.0
                  11 error path /home/pi/package.json
                  12 error code ENOENT
                  13 error errno -2
                  14 error syscall open
                  15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                  16 error enoent This is related to npm not being able to find a file.
                  17 verbose exit [ -2, true ]
                  • H Offline
                    Hawking @Doubleve
                    @Doubleve
                    In which directory did you execute npm start
                    ? I would assume you would first go to your MagicMirror directory (cd /home/pi/MagicMirror ). This would also explain the problem with the missing package.json file.
                    However, I’m not sure if npm start works at all in combination with the serveronly mode (needed for the Pi Zero). For starting, I use the method described in the first post of this thread in the section “Setting up boot scripts”.
                    I can acccess my MM from remote, however still didn’t get it to show in the Midori browser :-/
                      Doubleve
                      as you said I was not in the right record.
                      I had an error with the libnss3 library. Now more error
                      DISPLAY =: 0 npm start
                      magicmirror@2.1.3 start / home / pi / MagicMirror
                      sh run-start.sh
                      pi @ raspberrypi ~ / MagicMirror $ npm run config: check
                      magicmirror@2.1.3 config: check / home / pi / MagicMirror
                      node tests / configs / check_config.js
                      Checking file … /home/pi/MagicMirror/config/config.js
                      Your configuration file not containt syntax error :)
                      but it still does not work with midori
                      • N Offline
                        noorm91
                        What does npm start do in /MagicMirror
                          bhepler Module Developer @noorm91
                          @noorm91 npm start is the command to start the Magic Mirror application and display the interface on the screen.
                          • N Offline
                            noorm91 @bhepler
                            @bhepler
                            I can’t seem to start MM with npm start, tried through SSH and directly on rpi with keyboard.
                            pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &
                            [1] 890
                            pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’
                            ^C
                            [1]+ Exit 1 DISPLAY=:0 nohup npm start
                            magicmirror@2.1.0 start /home/pi/MagicMirror
                            electron js/electron.js
                            /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                            npm ERR! Linux 4.4.34+
                            npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                            npm ERR! node v4.2.1
                            npm ERR! npm v2.14.7
                            npm ERR! file sh
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno ENOENT
                            npm ERR! syscall spawn
                            npm ERR! magicmirror@2.1.0 start: electron js/electron.js
                            npm ERR! spawn ENOENT
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
                            npm ERR! This is most likely a problem with the magicmirror package,
                            npm ERR! not with npm itself.
                            npm ERR! electron js/electron.js
                            npm ERR! You can get their info via:
                            npm ERR! npm owner ls magicmirror
                            npm ERR! /home/pi/MagicMirror/npm-debug.log
                            • H Offline
                              Hawking @noorm91
                              @noorm91 said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                              @bhepler
                              Thats what I expected for the Pi Zero. Did you try the method described in the first post of this thread in the section “Setting up boot scripts”?
                                Doubleve
                                I took everything back with the first post everything works !!!
                                H 1 Reply Last reply Reply Quote 1
                                • H Offline
                                  Hawking @Doubleve
                                  @Doubleve
                                  Can you tell me which Linux distribution (lsb_release -a), node version ( node -v ) and version of MM you are using?
                                    delusional112
                                    Hi guys, I saw someone asked before, isn’t there anyone who has a working image for MM2 on a Pi Zero. I tried a lot of things before, cant get it to work. Now, I don’t have a lot of time to experiment with it, school and work are killing me. My mirror is lying around, unused. Please help me out here,
                                    Thanks!!
                                    • N Offline
                                      noorm91 @delusional112
                                      @delusional112
                                      Here is an image, it has a couple of errors that needs fixing but the magicmirror starts at least.
                                      If you have any solutions please keep us informed…this image is made by Sebtota.
                                      https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
                                      Here is the topic I found the image at.
                                      https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/85?page=9
                                      • N Offline
                                        noorm91
                                        Any clue on what is trying to start and not functioning alright here?
                                        Starting MagicMirror: v2.1.0
                                        Loading config ...
                                        Starting server op port 8080 ...
                                        Server started ...
                                        Starting module: newsfeed
                                        { [Error: listen EADDRINUSE :::8080]
                                          code: 'EADDRINUSE',
                                          errno: 'EADDRINUSE',
                                          syscall: 'listen',
                                          address: '::',
                                          port: 8080 }
                                        (EE)
                                        Fatal server error:
                                        (EE) Server is already active for display 0
                                                If this server is no longer running, remove /tmp/.X0-lock
                                                and start again.
                                        (EE)
                                        (EE)
                                        Please consult the The X.Org Foundation support
                                                 at http://wiki.x.org
                                         for help.
                                        (EE)
                                        XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                              after 7 requests (7 known processed) with 0 events remaining.
                                          Whoops! There was an uncaught exception…
                                          8080]
                                          This usually means that you already have a process trying to serve up web pages on port 8080. In my experience, this happens when you do not terminate your previous attempt to run the MM process and start up another one. The new one also tries to serve up pages on port 8080 and you get that error.
                                          You can use ps ax | grep node to see if node is running when you attempt to start your mirror. If it is, node is already serving up pages, so you will want to stop whatever process is running first. Alternately, if you are running a web server on port 8080 already, you can switch the port of the MM process in the config.js file.
                                          • MarWindM Offline
                                            MarWind
                                            So did anyone get MM2 on a Pi Zero W with Raspian Stretch lite running?
                                            Or is it better to stay with Jessie?
                                            ~ride bikes and boards not always on top~
                                            • 10
                                            • 11
                                            • 7 / 11
