    MMM-Memo - Add some memos on your page and manage them through HTTP request
    41 Posts 23 Posters 31.7k Views 23 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @ceddirr
      @ceddirr https://github.com/schnibel/MMM-Memo#to-temporary-display-the-second-memo-of-the-shopping-memo-note
      ceddirrC 1 Reply Last reply Reply Quote 0
      • ceddirrC
        ceddirr @strawberry 3.141
        @strawberry-3.141 Hi, Thank you for your quick reply =)
        I am sorry I read this already, but I didn’t understand how to make my memo stay longer… :/
        I have only one module with “memoDisplayNotification” set to “true”.
        I understand the alert module is managing this with:
        self.sendNotification(“SHOW_ALERT”, {});
        But how to integrate this into the command
        http://192.168.0.137:8080/DisplayMemo?memoTitle=SHOPPING&item=ALL
        Thank you again!
        • strawberry 3.141S
          @ceddirr add the config option display_time to the alert module https://github.com/MichMich/MagicMirror/tree/master/modules/default/alert#configuration-options
          • ceddirrC
            ceddirr
            Riiight, thank you very much! :D
            • ceddirrC
              ceddirr
              Hi all,
              Thank you again for your answer last time, playing with the option display_time from the alert module.
              However, if you modify it, every alert would be modified. For exemple, if I want to set my memo to keep displayed for at least 30 secondes, I go modify the display_time from the alert module. But, all alerts like for example “welcome back Mr Blabla” when I switch profile will stay longer than usual.
              The question is how do I have to do to only change the MMM-Memo alerts please?
              Many thanks,
              Cedric ;)
                schnibel
                Hi guys,
                Just came back on the Internet, and I saw your messages.
                @ceddirr, I’m sorry, but I didn’t develop a specific module for alerts as the existing one is quite nice… But I understand your problem.
                When I had this DisplayMemo option, the idea was to temporarily display a long message, is it your case ?
                • ceddirrC
                  ceddirr
                  Hi, thank you for getting back to me =)
                  Yes, the idea is basically the same, but I would just like to see the memo a little bit longer than the regular alert’s configuration.
                  The problem for me is if I change the display_time setting directly on the alert module, it would be too long for the other alert like “nice to see you %profile%”, etc lol
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @schnibel
                    @schnibel easiest soluton would be to replace notifications with alerts, as they can have a duration parameter, but the downside is there can be just one alert per module at the same time.
                    https://github.com/schnibel/MMM-Memo/blob/master/MMM-Memo.js#L123
                    to this.sendNotification("SHOW_ALERT", {title: ttl, message: msg, timer: 5000}); for 5 seconds or make a config option for it
                    • wiresharkW
                      wireshark
                      D wiresharkW 2 Replies Last reply Reply Quote 0
                        dsegel @wireshark
                        @wireshark Try something like this in your ~/MagicMirror/css/custom.css file:
                        .MMM-Memo .note {
                            font-size: 25px;
                            font-family: "Roboto Condensed", sans-serif;
                        Note that I just picked that size (25px) out of the air; I have no idea what the default size is. You’ll have to experiment. Also not sure if the size option will even work (although I know the font-family option does).
                        • V
                          Vauxdvihl
                          @schnibel
                          Thanks for this great module.
                          Can you please help me?
                          Unfortunately i am not able to run is (and i am sure that the prob sits in front of the pi)
                          It would help me a lot if somebody could share his working config (only the “alert” module" and from this "Memo one).
                          Thanks a lot for you help and support
                          • wiresharkW
                            wireshark @wireshark
                            • N
                              nobita @schnibel
                              @schnibel , If I would like to make this module without use voice command (Jarvis)
                              and add event by manual (like default calendar module), or add event in google calendar
                              question: How to do it? Thanks for your help
                              • E
                                efl23
                                but when I do this command “http://192.168.0.60:8080/AddMemo?memoTitle=SHOPPING&item=Fruits&level=INFO”, I have this message
                                “Cannot GET /AddMemo”
                                but this command “http://192.168.0.60:8080” show MagicMirror
                                • E
                                  efl23 @efl23
                                  @efl23
                                  Eureka, just a bad name of the module
                                  • JanneJ
                                    Janne
                                    Just a help to other magic Mirror builders.
                                    I have implemented this nice module. :smiling_face_with_heart-eyes:
                                    When I send URL-request I got the error “No memo file found”. After some grumbling and deep dive I found that it was because my language was not supported (Danish).
                                    I added my language-file under the translation directory and added the yellow line.
                                    Hope it can be of help to others. :smiling_face_with_smiling_eyes:
                                      Crayyy
                                      I still am unable to add or modify the memos in any way :) I don’t understand how to use the HTTP command to pass commands to the module, Here is what I typed at the SSH command prompt. “http://192.168.1.175:8080/AddMemo?memoTitle=SHOPPING&item=Fruits&level=INFO” but I get the following errors and no memo on my mirror :( “-bash: http://192.168.1.175:8080/AddMemo?memoTitle=: No such file or directory
                                      [7]- Exit 127 http://192.168.1.175:8080/AddMemo?memoTitle=SHOPPING
                                      [8]+ Done item=Fruits” please help :)
                                      • L
                                        lovesicker
                                        @schnibel
                                        Thank you for providing us this fantastic module! It’s so useful.
                                        I have a suggestion: could you merge multiple instances of MMM-Memo into only one instance? Like the following:
                                        module: ‘MMM-Memo’,
                                        config{
                                        memo1
                                        memoTitle: XXXX
                                        position:
                                        memo2
                                        memoTitle:YYYY
                                        position:
                                        Because there are six instances of MMM-Memo at least, the system performance will be affected and there are always many notifications about this module in console log when any notifications send by any modules.
                                          Robinson128
                                          Thank you for this module that I like a lot despite the harm I had to use it without Jarvis. :) beginner in computer science and big noob for HTML CSS and many other things. I search a little but I did not find how to make notes appear after each other in the same memo. The oldest note in 1 and the most recent in 2,3 or 4 and so on. Thanks for your help.
                                          (Google traduction)
                                          • WasupDudeW
                                            WasupDude Banned
                                            Such a usefull topic,thanks
                                            • 2 / 3
