    console.log in getDom
    6 Posts 5 Posters 2.8k Views 4 Watching
    • K Offline
      kiki99
      Hi Forum ;)
      Is it possible, that console.log and log.Info does not work in getDom? I did not get any Output. Is there a way?
      Many Tanks fort each tip :)
      Best regards k.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @kiki99
        @kiki99 where did you check for logs? those ones are in the browser/electron window and not in the terminal as the ones in the nodehelper
        • cowboysdudeC Offline
          When you do a console log in the developer window it shows up there…
          When you do a console.log in node_helper it shows up in the terminal window that you loaded MM by using npm start…
          Hope that helps.
            I’m gonna jump right in here, right after the two geniuses. :-)
            • K Offline
              kiki99
              Okay, many thanks at first for that.
              But is there a way to get the output from the “console of the browser” when i start it via npm start? In the npm log there is nothing.
              It’s a bigger structure so i can’t simple add it to the wrapper, or can i? ;))
              Best Regards.
                A Former User @kiki99
                @kiki99
                I think it might be related with electron. You can pipe whole electron console output to file or others. But I didn’t test. Check this.
                https://github.com/dustinblackman/winston-electron/blob/master/README.md
