    Adding a second news feed.
    25 Posts 4 Posters 17.8k Views 4 Watching
      ChrisEW
      Hi folks:
      Complete newbie here.
      I am really weak on coding, but the other day I did manage to add a second feed on my bottom bar. It was nice, because they alternated every few seconds.
      { and }.
      I’ve used npm run config:check but am getting nowhere. I am currently running OK with the single news feed.
      Thanks in advance.
      Chris
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ChrisEW
        @ChrisEW
        	disabled: false,
        		module: "newsfeed",
        		position: "bottom_bar",
        			updateInterval: 28 * 1000,
        			feeds: [
        					title: "New York Times",
        					title: "ANOTHER NEWSFEED HERE - CHANGE THE URL BELOW",
        					title: "ANOTHER NEWSFEED HERE - and so on and so forth",
        				showSourceTitle: true,
        				showPublishDate: true
          ChrisEW
          Thanks so much. A simple comma was missing, who knew?.
          • Mykle1M
            @ChrisEW said in Adding a second news feed.:
            You’re welcome.
            Those damned comma’s! :^)
              RIJOSROBERTO
              hello hope all are well another nubie here lol , iam trying to find out how I can replace the new times news feed with this new news feed because I have no clue how to get it to look like the wording that the current news feed has lol any help would be a blessing thanks ,
              http://www.wpbf.com/article/rss/3381423
              top stories and if its possible on magic mirror the weather videos as well especially this one wich would be better then the feed , http://www.wpbf.com/nowcast
                sdetweil @RIJOSROBERTO
                @rijosroberto
                top stories is
                http://www.wpbf.com/topstories-rss
                weather vids is
                http://feeds.hearstdigitalstudios.com/wsi_app_feed_wpbf.xml
                  RIJOSROBERTO
                  thank you going to try it now , ,
                  I need to learn how to make those lol ,
                    click on the link in the web page to select it (where the page says ‘XML’) , and then copy the URL (address) line
                      RIJOSROBERTO
                      oooo ok , thank you ,
                      so far everything loads up but the live news feed it says loading , so far 5 min have past
                      update seems to be stuck at loading , the live video feed
                        @rijosroberto might be an error…
                        alt-spacebar, n to minimize the mirror screen and see the console log in the terminal window where u did npm start (this will show the debug/errors from the node_helpers)…
                        and/or ctrl-shift-i (letter i) to open the debug console, select the console tab
                        (this will show the debug from the modules)
                          RIJOSROBERTO
                          ok ,
                          I noticed I had the yellow http:// and the one I copied and pasted so I just erased the blue one and left the yellow one and just rebooted to see
                          update ok so far the video feed one just says about the storie and who wrote the storie , it doesn’t show the live feed , trying the regular one now, that one works perfect , still would love the live feed tho any ideas ?
                            @rijosroberto i am guessing the RSS module doesn’t know about non-text content…
                            from the news items
                            media:content url=
                              RIJOSROBERTO
                              mmmm how can I fix that ? its a fresh install of noobs , and the raspian that the installer recommends , would I need to download a player or some sorts ?
                                the code doesn’t know about anything but the text of the items…
                                you would have to change the code, and use some player, and … I don’t know what else
                                  RIJOSROBERTO
                                  I suck at coding so that would take me 20 years to at least get a little half way lol is there an alternative
                                    @rijosroberto said in Adding a second news feed.:
                                    no idea
                                    i am a MM newbie
                                      RIJOSROBERTO
                                      me too , I know they have a module called iframe that can be used to open up smart tiles , but I tried it and it didn’t work for the live feed maybey I did it wrong tho , but it makes me think if mm is able to watch live camara feeds it should be able to watch the news
                                      I found this one that iam trying now hopefully it works
                                      https://github.com/maxenxe/MMM-RSS-FEED
                                        @rijosroberto no… that one doesn’t process the media link either
                                          RIJOSROBERTO
                                          this one opens it up like a web page
                                          https://github.com/alberttwong/MMM-iFrame
                                          but no vid I would have to resize it to fit the whole screen , it beats the purpose , of using a pi
                                            RIJOSROBERTO
                                            do you kno if theres away to go back to the pm2 save ? iam guessing when it saves it backs up?
