    After update to newest version = Black screen
    7 Posts 3 Posters 4.0k Views 3 Watching
    • I
      ironman_DK
      I got Black Screen after update, I have also tried to reinstall with the same result - what to do ?
      Best regards Michael
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ironman_DK
        @ironman_DK
        Assuming you’re using a Pi2 or a Pi3, and that you’ve properly prepared your Pi, and that you’ve installed Raspbian Jessie (Stretch has been problematic) then this will take you less than 30 minutes, with a 99% success rate. Ok, I made up the success rate, but it’s pretty damn good! :-)
        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
        I 1 Reply Last reply
        • I
          ironman_DK @Mykle1
          @Mykle1 I have followed you guide, but I still have a Black screen ?
          Best Regards
          Michael
          • I
            ironman_DK @ironman_DK
            @ironman_DK said in After update to newest version = Black screen:
            Best Regards
            Michael
            This is from automatic install >
            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                    \______/
            Updating packages ...
            Henter:1 http://mirrordirector.raspbian.org jessie InRelease [14,9 kB]
            Henter:2 https://deb.nodesource.com jessie InRelease [4.631 B]
            Henter:3 http://archive.raspberrypi.org jessie InRelease [22,9 kB]
            Henter:4 http://mirrordirector.raspbian.org jessie/main armhf Packages [9.536 kB]
            Henter:5 https://deb.nodesource.com jessie/main Sources [20 B]
            Henter:6 https://deb.nodesource.com jessie/main armhf Packages [1.003 B]
            Havde http://archive.raspberrypi.org jessie/main armhf Packages
            Henter:7 https://deb.nodesource.com jessie/main Translation-da_DK [162 B]
            Havde http://archive.raspberrypi.org jessie/ui armhf Packages
            Henter:8 https://deb.nodesource.com jessie/main Translation-da [162 B]
            Henter:9 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Henter:10 https://deb.nodesource.com jessie/main Translation-da_DK [162 B]
            Henter:11 https://deb.nodesource.com jessie/main Translation-da [162 B]
            Henter:12 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Henter:13 https://deb.nodesource.com jessie/main Translation-da_DK [162 B]
            Henter:14 https://deb.nodesource.com jessie/main Translation-da [162 B]
            Henter:15 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Henter:16 https://deb.nodesource.com jessie/main Translation-da_DK [162 B]
            Henter:17 https://deb.nodesource.com jessie/main Translation-da [162 B]
            Henter:18 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Henter:19 https://deb.nodesource.com jessie/main Translation-da_DK [162 B]
            Ignorerer https://deb.nodesource.com jessie/main Translation-da_DK
            Ignorerer http://archive.raspberrypi.org jessie/main Translation-da_DK
            Ignorerer http://archive.raspberrypi.org jessie/main Translation-en
            Henter:20 https://deb.nodesource.com jessie/main Translation-da [162 B]
            Henter:21 https://deb.nodesource.com jessie/main Translation-en [162 B]
            Ignorerer https://deb.nodesource.com jessie/main Translation-en
            Ignorerer http://archive.raspberrypi.org jessie/ui Translation-da_DK
            Ignorerer http://archive.raspberrypi.org jessie/ui Translation-en
            Henter:22 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [43,3 kB]
            Henter:23 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [84,2 kB]
            Henter:24 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1.356 B]
            Ignorerer http://mirrordirector.raspbian.org jessie/contrib Translation-da_DK
            Ignorerer http://mirrordirector.raspbian.org jessie/contrib Translation-en
            Ignorerer http://mirrordirector.raspbian.org jessie/main Translation-da_DK
            Ignorerer http://mirrordirector.raspbian.org jessie/main Translation-en
            Ignorerer http://mirrordirector.raspbian.org jessie/non-free Translation-da_DK
            Ignorerer http://mirrordirector.raspbian.org jessie/non-free Translation-en
            Ignorerer http://mirrordirector.raspbian.org jessie/rpi Translation-da_DK
            Ignorerer http://mirrordirector.raspbian.org jessie/rpi Translation-en
            Hentede 9.708 kB på 28s (337 kB/s)
            Indlæser pakkelisterne... Færdig
            Installing helper tools ...
            Opbygger afhængighedstræ
            Læser tilstandsoplysninger... Færdig
            build-essential er allerede den nyeste version.
            curl er allerede den nyeste version.
            git er allerede den nyeste version.
            unzip er allerede den nyeste version.
            wget er allerede den nyeste version.
            Følgende pakker blev installeret automatisk, og behøves ikke længere:
              coinor-libipopt1 libboost-filesystem1.55.0 libboost-program-options1.55.0
              libboost-regex1.55.0 libc-ares2 libffi5 libgmime-2.6-0 libmumps-seq-4.10.0
              liboauth0 libraw10 libv8-3.14.5 wolframscript
            Brug »apt-get autoremove« til at fjerne dem.
            0 opgraderes, 0 nyinstalleres, 0 afinstalleres og 153 opgraderes ikke.
            Minimum Node version: v5.1.0
            Installed Node version: v6.10.0
            No Node.js upgrade necessary.
            Cloning MagicMirror ...
            Cloning into 'MagicMirror'...
            remote: Counting objects: 8848, done.
            remote: Total 8848 (delta 0), reused 0 (delta 0), pack-reused 8848
            Receiving objects: 100% (8848/8848), 11.33 MiB | 230.00 KiB/s, done.
            Resolving deltas: 100% (5009/5009), done.
            Checking connectivity... done.
            Cloning MagicMirror Done!
            Installing dependencies ...
            npm WARN deprecated isarray@2.0.1: Just use Array.isArray directly
            npm WARN prefer global coffee-script@1.10.0 should be installed with -g
            npm WARN prefer global jsonlint@1.6.2 should be installed with -g
            > uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
            > node-gyp rebuild > build_log.txt 2>&1 || exit 0
            > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            > node ./download-chromedriver.js
            > electron@1.7.9 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            > magicmirror@2.1.3 install /home/pi/MagicMirror
            > cd vendor && npm install
            magicmirror-vendors@ /home/pi/MagicMirror/vendor
            ├── font-awesome@4.7.0
            ├── moment@2.19.2
            ├── moment-timezone@0.5.14
            └── weathericons@2.1.0
            > magicmirror@2.1.3 postinstall /home/pi/MagicMirror
            > sh installers/postinstall/postinstall.sh && npm run install-fonts
            Unable to install dependencies!
            pi@raspberrypi:~ $
            • Mykle1M
              pi@raspberrypi:~ $
              In terminal
              cd MagicMirror (Enter)
              npm install (Enter)
              npm start (Enter)
                CGwaltney
                I think this is what I am getting, If i run remotly, as i do not have a keyboard attached (another problem) the remoter terminal window vnc shows the Magic Mirror, but the actual Pi screen is black with mouse pointer, ( I have touch screen installed)
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @CGwaltney
                  @CGwaltney
                  try:
                  DISPLAY=:0 npm start
                  or
                  DISPLAY=:0 nohup npm start &
