    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 149.8k Views 11 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @stephenmelody
      @stephenmelody said in MMM-aviationwx (Aviation weather):
      Have you tried emailing the guy at avwx?
      I did. That’s how I know I can’t use a single url for multiple stations (as in aviationweather). It’s my own lack of coding capability that prevents me from making multiple calls to that API from within the module. Help with that will have to come from this forum or somewhere else, not the API.
      I’d be surprised if the gov api is converting reported units to kts
      The data says, wind_speed_kt
      • Mykle1M
        “C” removed
        Individual coloring of each line made easy for easier viewing.
        Still trying to work out the problem with /avwx.rest/api
        3 1 Reply Last reply Reply Quote 0
          320fan @Mykle1
          @Mykle1 said in MMM-aviationwx (Aviation weather):
          Hi again,
          Sorry for my long absence, I had really tough week of flights,and now I’m have 1 day off ;) Seem that you made a very good job with new module and I have seen that some questions were in place. So, just some of my opinions on these questions:
          1. Remove C from temperature? - yes, indeed. We just need to be sure that all data in C.
          2. Remove the kt from wind speed? The best way to keep initial units of measure (m/s in RU, kts in other contries from example). But, as I undestood, thats depends on API…
          3. About remarks: first, just to recall - best way to have them to be configurable (to have options to display them/not display them at all). And for me - best way to keep the whole RMK field. Is there any possibility to align it by the next way:
            0_1511605673698_Untitled.jpg ?
          4. Also, I would ask you to keep digits after OVC/FEW/etc - it’s a important information, which means a top of clouds. I’ve just seen that on the last screenshoots this information is missing.
          If you have any additional questions - please, let me know.
          And thanks you again for your job.
          • Mykle1M
            https://youtu.be/zAImRnR9HsM
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @320fan
              @320fan said in MMM-aviationwx (Aviation weather):
              I think, in the interest of mirror real estate, I will leave out the raw data for now. IMHO, an MM module is not meant to occupy all, or much of the display, as an iPad app would do.
              I am not using a table in the module (I don’t know how) so alignment is tricky. I’m doing the best I can.
              Agreed, and it will remain, as long as the data provides it.
              Eventually, I’ll learn how to make multiples calls within the module. Then I can use the API of choice. For now I am battling with xml data of aviationweather.gov
              • Mykle1M
                Ok, time for testing. Both of these modules are using aviationweather.gov for reasons explained above. I will learn how to make multiple requests within the module and move to avwx.rest/api, eventually.
                Most like original in appearance and does allow for international ICAO’s.
                https://github.com/mykle1/MMM-Pilot
                	disabled: false,
                	module: "MMM-Pilot",
                		ICAO: "KJFK,EGLL,UUDD,EDDT,RJAA,ZBAA,LFPG,LIRF", // Any 8 International ICAO's
                		colorCode: "Alternative", // Standard or Alternative
                		updateInterval: 10 * 60 * 1000,
                		useHeader: false,
                		header: "",
                		maxWidth: "400px",
                • Mykle1M
                  A new spin on the display and does allow for international ICAO’s.
                  https://github.com/mykle1/MMM-WISP
                          disabled: false,
                  	module: "MMM-WISP",
                  	position: "bottom_bar", // you could try top_bar and thirds
                  	        ICAO: "KJFK,EGLL,UUDD,EDDT,RJAA,ZBAA,LFPG,LIRF", // Not limited to 8 International ICAO's
                  		useHeader: false,
                  		header: "",
                  		maxWidth: "100%",
                  A 1 Reply Last reply Reply Quote 2
                  • A
                    Area 49 @Mykle1
                    @Mykle1,
                    Thanks for your work on this!
                    I just installed Magic Mirror and started looking around for an aviation weather module that included Alaska. I just now stumbled on this thread, and see that your work should include the airports that I want in my list. I’ll install and test it as soon as I get a chance.
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Area 49
                      @Area-49 said in MMM-aviationwx (Aviation weather):
                      Great! Let me know how things go. Use the four letter ICAO for each station you want to see
                      • A
                        Area 49 @Mykle1
                        @Mykle1,
                        Looks like there is a dependency required - from my PM2 error log file: Error: Cannot find module ‘xml2js’
                        I’m just getting started figuring out Linux, Git repository, and Javascript, so I’m not sure where to find - and under what directory to install this dependency.
                        Is this the one to install? https://github.com/Leonidas-from-XIV/node-xml2js
                        Mykle1M 3 Replies Last reply Reply Quote 0
                        • Mykle1M
                          • Mykle1M
                            @Area-49
                            You have to run npm install in the MagicMirror/modules/MMM-(THE MODULE NAME) folder
                            I don’t know which one of the two you are trying
                            So for MMM-Pilot it’s
                            npm install in the MagicMirror/modules/MMM-Pilot directory
                            And for MMM-WISP it’s
                            npm install in the MagicMirror/modules/MMM-WISP directory
                            • Mykle1M
                              Sorry about the lack of directions. I only just put this up for testing so it hasn’t been officially released or properly documented.
                              • A
                                Area 49
                                Mykle1,
                                Got it to install & run. Thanks for the clarification on how to install.
                                I put in my chosen airports in AK (also one in HI - just so I can feel bad about how cold it is here right now!)
                                Not sure if you know, but you can return only the most recent Metar data from each airport by using a slightly different URL and the following format:
                                http://aviationweather.ncep.noaa.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&hoursBeforeNow=4&mostRecent=true&stationString=PALH
                                I like the output format. I think it works well for at-a-glance information purposes. However if I had a choice, I’d like a config option for temperature and dew point units. I’m used to looking at these in Fahrenheit. I have my own simple personal website where I link to a few Metar reports directly, and the pages show both the raw units and (converted).
                                Example for PALH (Lake Hood AK): http://www.aviationweather.gov/adds/metars/?station_ids=palh&std_trans=translated&chk_metars=on&hoursStr=most+recent+only&submitmet=Submit
                                Not a huge deal on the units, but maybe put it on the wishlist?
                                Thanks again for your effort on putting this together!
                                • Mykle1M
                                  Sure, I’ll keep that in mind. I’m not in a rush after 500+ lines of code already. :-)
                                  You’re welcome. It’s nice to be appreciated. :-)
                                  Now, the first url you posted is great. If you can edit it to pull multiple ICAO’s at once, then I’ll use it. I tried briefly. It only seems to return 1 ICAO. The url I’m using pulls observations from the last hour.
                                  The second url you posted is also great. However, it doesn’t get me to the xml data that I need for the module. If you can manage to get a url to return the very same data like this, we’ll be jamming
                                  • Mykle1M
                                    I feel obliged to state that this module should only be used for entertainment purposes. Yes, the data is being pulled from the very same sites that you use ordinarily, but the thought of any of you relying on this module’s data for actual flights scares the shit out of me. Not that you would. You’re pilots. You’re smarter than that, I hope. :-)
                                    How would that work anyway? You’re going to hang your mirror in the cockpit? :-)
                                    That’ll be a $10.00 fee for Wi-Fi. :-)
                                    Peace!
                                    • Mykle1M
                                      When did 3.3k people look at this topic? Crazy
                                      Ok, so I’ve done the best I could with alignment of columns, considering there ARE no columns. At least the Flight Rules icon, the station, the wind direction and speed are relatively straight. I’m pretty much done with that. I hope it will suffice.
                                      I’ve added a Station header and a Conditions header. Here they are underlined. They don’t have to be. I was just experimenting.
                                      I’ve also added the most recent observation time to the end of each station’s conditions. This is converted from Zulu time to your local military time. Is this the way it should be?
                                      • Mykle1M
                                        Now I’ll add the most recent observation time to MMM-WISP for those that may want the rotating, bottom_bar version.
                                        Done!
                                        The updates have been pushed to Github although there is no documentation as of yet
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @Mykle1
                                          @Mykle1
                                          Merged both modules into one. Static or Rotating by config option
                                          https://github.com/mykle1/MMM-PilotWX
                                            stephenmelody
                                            I’m planning on pulling this down at some point soon… just having some stability issues with my raspberry pi at the moment. It keeps crashing on me every 12-24 hours…
                                            • 4 / 6
