    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • sailboarder79S
      sailboarder79 @Osyris
      @Osyris okay thanks!
      • Z
        zzaidi148 @vicmora
        @vicmora Hi, I’ve been trying for the past week to get your module to work on my magic mirror. The closest I’ve gotten is getting my magic mirror to boot up with the default modules with no google maps traffic module showing. I used npm start dev to see the console it and it looked perfectly fine, saying that it had launched. I’ve tried placing the module in different places in the config. Below is my config, I’ve put it both at the beginning and end of this config. Please let me know which place to put it and how to fix the issue. Thanks!
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 12,
        	units: "imperial",
                    		module: 'MMM-GoogleMapsTraffic',
                        	key: 'i have this',
                        	lat: 37.8262306,
                        	lng: -122.2920096,
                        	height: '300px',
                        	width: '300px'
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar",
        			module: "clock",
        			header: "US Holidays",
        					symbol: "calendar-check-o",
        					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
        			module: "compliments",
        			position: "lower_third",
        			module: "currentweather",
        				locationID: "4684888",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "private",
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				appid: "private",
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
                        	   key: 'I have this',
                        	   lat: 37.8262306,
                        	   lng: -122.2920096,
                        	   height: '300px',
                        	   width: '300px',
          A Former User @zzaidi148
          @zzaidi148
          I’ve found what is wrong.
          you should set position of this module.
          position: 'top_left', //this is missed.
                	   key: 'I have this',
          manual of @vicmora has missed this.
          Z 1 Reply Last reply Reply Quote 0
          • Z
            zzaidi148 @Guest
            @Sean Thank you so much! Finally, after toiling away at it, with your help, I got it to work. Next up, your calendar module!
              blue2monster
              @vicmora : I’ve been trying all night long: just cant get the map to be shown.
              I can see that the module is started in the dev logs.
              Funny thing: If I add some different HTML Output in the module.js It is printed on my screen, the only thing missing is the map.
              Same thing is happening on MMM-fuel and MMM-googlemap. Modules are working but the map itself is not shown.
              Different one for iFrame: This one is working.
              Interesting fact: If I check on the google dashboard for the traffic of this specific api key, I do not see any traffic. Is there anything special in the google api that I need to enable, or any additional module that needs to be installed.
              Any ideas: Thanks a lot for the help.
              B V 2 Replies Last reply Reply Quote 0
                blue2monster @blue2monster
                @blue2monster: found now a workaround with the iframe module: This one works… but I haven’t made to switch the traffic layer on
                • V
                  vicmora @blue2monster
                  @blue2monster Have you tried adding position: ‘top_left’ to your config? I missed this in the docs but will update them.
                    blue2monster @vicmora
                    @vicmora : yes, I added position to various spots(e.g top_left; bottom_center,…) and tried various width and heights but still frame not visible.
                    Tried as well a complete empty config with only this module loaded-> no sucess.
                    I guess it might be an Google api key issue: Could you please show you google api devboard: Which service needs to be activated in google api? An which is showing traffic on your google api?
                    Thanks.
                    • V
                      @blue2monster This is where I grabbed the api key: https://developers.google.com/maps/documentation/javascript/
                        sprior
                        I created a pull request that I’d like merged. I added a config parameter that allows you to specify the type of map to display, my favorite is the hybrid which shows a satellite image with the roads on top. I left the default to display just the road maps as before.
                        • V
                          vicmora @sprior
                          @sprior Thanks! I merged it today.
                            sprior
                            I’m familiar with git, but not github as much. Since I forked your repository to make my change, then did a pull request which you accepted, I now show my repo as being one commit behind yours. How do I tell github to pull that commit, or do I just delete my repo and fork again when/if needed?
                            • cruunnerrC
                              cruunnerr
                              Hey,
                              cool module but got some issues when trying to select a dark mode style.
                              I wanted to look the map like in this example: https://developers.google.com/maps/documentation/javascript/styling
                              well, i have tried to use your code and modify the colors. also i have tried to use the code from here: https://mapstyle.withgoogle.com
                              the module always starts, but i just got the standard view on it.
                              maybe you could explain a little bit more detailed how to do it. that would be great. thx
                              • K
                                knubbl @Osyris
                                @Osyris said in MMM-GoogleMapsTraffic:
                                Hey guys, I figured it’s easy enough to style the map by editing the JS file. So in order to get the night mode as shown in pflodo’s post (and to disable the UI buttons) I added the following to the JS code:
                                //original code
                                        script.onload = function () {
                                            var map = new google.maps.Map(document.getElementById("map"), {
                                            	zoom: 10,
                                            	center: {
                                            		lat: lat,
                                            		lng: lng
                                //add a comma after the } above
                                //new code:
                                		disableDefaultUI: true,
                                		styles: [
                                			{elementType: 'geometry', stylers: [{color: '#242f3e'}]},
                                			{elementType: 'labels.text.stroke', stylers: [{color: '#242f3e'}]},
                                			{elementType: 'labels.text.fill', stylers: [{color: '#746855'}]},
                                			    featureType: 'administrative.locality',
                                			    stylers: [{color: '#d59563'}]
                                				featureType: 'poi',
                                				featureType: 'poi.park',
                                			        stylers: [{color: '#263c3f'}]
                                				stylers: [{color: '#6b9a76'}]
                                				featureType: 'road',
                                				stylers: [{color: '#38414e'}]
                                				elementType: 'geometry.stroke',
                                					  stylers: [{color: '#212a37'}]
                                					  stylers: [{color: '#9ca5b3'}]
                                				featureType: 'road.highway',
                                				stylers: [{color: '#1f2835'}]
                                				stylers: [{color: '#f3d19c'}]
                                				featureType: 'transit',
                                				stylers: [{color: '#2f3948'}]
                                			        featureType: 'transit.station',
                                			        featureType: 'water',
                                				stylers: [{color: '#17263c'}]
                                				stylers: [{color: '#515c6d'}]
                                //old code again
                                Have fun!
                                Also, if you want to make the background black (so it looks cool on the mirror), set the first attribute ‘geometry’ to ‘#000000’.
                                Try this…works 4 me
                                • cruunnerrC
                                  cruunnerr
                                  • cruunnerrC
                                    cruunnerr
                                    but where to add this code?
                                    i typed in this in my MagicMirror/config/config.js:
                                                      position: 'bottom_left',
                                                          key: 'xxxx',
                                                          lat: 50.959023,
                                                          lng: 6.333991,
                                                          height: '250px',
                                                          width: '250px',
                                                          zoom: 9,
                                                          enableTraffic: true,
                                                          styles: [
                                    				featureType: 'poi',
                                    and it looks like this:
                                    • K
                                      knubbl
                                      n,o not in the config.
                                      u need to edit the js file (MMM-GoogleMapsTraffic.js)
                                      if u want just replace ur js with the code i use
                                      /* global Module */
                                      /* Magic Mirror
                                       * Module: MMM-GoogleMapsTraffic
                                       * By Victor Mora
                                       * MIT Licensed.
                                      Module.register("MMM-GoogleMapsTraffic", {
                                      	// Module config defaults
                                      	defaults : {
                                      		lat: '',
                                      		lng: '',
                                      		height: '300px',
                                      		width: '300px',
                                      		zoom: 10,
                                                      mapTypeId: 'roadmap',
                                      	getDom: function() {
                                              var lat = this.config.lat;
                                              var lng = this.config.lng;
                                              wrapper.setAttribute("id", "map");
                                              wrapper.style.height = this.config.height;
                                              wrapper.style.width = this.config.width;
                                              var script = document.createElement("script");
                                              script.type = "text/javascript";
                                              script.src = "https://maps.googleapis.com/maps/api/js?key=" + this.config.key;
                                              document.body.appendChild(script);
                                      	var self = this;
                                                  	zoom: self.config.zoom,
                                                      mapTypeId: self.config.mapTypeId,
                                                  	center: {
                                                  		lat: self.config.lat,
                                                  		lng: self.config.lng
                                      			//disableDefaultUI: self.config.disableDefaultUI
                                      			styles: [
                                      				featureType: 'poi',
                                                  var trafficLayer = new google.maps.TrafficLayer();
                                                  trafficLayer.setMap(map);
                                      		return wrapper;
                                      W 1 Reply Last reply Reply Quote 1
                                      • cruunnerrC
                                        cruunnerr
                                        Great, that worked. Thank you.
                                        Another question:
                                        Do you think its possible to show the map just at specific times.
                                        like in this module: https://github.com/jclarke0000/MMM-MyCommute
                                        so you were able to show the map just at times u need to know the traffic situation. for example i just need it Mo-Fr between 05:00-07:00 am and on Fr between 02:00-08:00 pm and Sa-So between 09:00am-02:00pm.
                                        its just an idea. Anyhow its a great module that worked now really fine for me :)
                                        • K
                                          knubbl @cruunnerr
                                          @cruunnerr
                                          try mmm-scheduler . this is a modul which gives u the opportunity to schedule all modules to show and hide to a spedific time.
                                          nice if u have not enough space on ur screen and want to switch between modules by time
                                          • A
                                            Aurelsam
                                            Hi everybody,
                                            Do you think it would be possible to include a marker on the map to see my house on the map I display?
                                            • 2 / 5
