    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • cruunnerrC
      cruunnerr
      Great, that worked. Thank you.
      Another question:
      Do you think its possible to show the map just at specific times.
      like in this module: https://github.com/jclarke0000/MMM-MyCommute
      so you were able to show the map just at times u need to know the traffic situation. for example i just need it Mo-Fr between 05:00-07:00 am and on Fr between 02:00-08:00 pm and Sa-So between 09:00am-02:00pm.
      its just an idea. Anyhow its a great module that worked now really fine for me :)
      • K
        knubbl @cruunnerr
        @cruunnerr
        try mmm-scheduler . this is a modul which gives u the opportunity to schedule all modules to show and hide to a spedific time.
        nice if u have not enough space on ur screen and want to switch between modules by time
        • A
          Aurelsam
          Hi everybody,
          Do you think it would be possible to include a marker on the map to see my house on the map I display?
            sheddingmyskin
            Anyone else having issues with the map rendering streets / traffic /actual data rather than a blank frame? I have tried several of the forks, and they all end the same way. I have confirmed by use of MMM-Traffic that my API key is valid.
            config.js:
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
             // added Modules
                                    module: 'MMM-GoogleMapsTraffic',
                                    position: 'bottom_right',
                                            key: '************************',
                                            lat: '30.00000',
                                            lng: '-90.000000',
                                            height: '300px',
                                            width: '300px'
            			module: 'MMM-Traffic',
            			position: 'top_right',
            			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
            				api_key: '*******',
            				mode: 'driving',
            				origin: '**********',
            				destination: '*********',
            			//	mon_destination: '116th St & Broadway, New York, NY 10027',
            			//	fri_destination: '1 E 161st St, Bronx, NY 10451',
            				arrival_time: '0755', //optional, but needs to be in 24 hour time if used.
            				route_name: 'Home to Work',
            				changeColor: true,
            				showGreen: false,
            				limitYellow: 5, //Greater than 5% of journey time due to traffic
            				limitRed: 20, //Greater than 20% of journey time due to traffic
            				traffic_model: 'pessimistic',
            				interval: 60000, //1 minutes
            				showWeekend: false,
            				allTime: false,
            				startHr: 5,
            				endHr:   10,
            				hideOffHours: true
              //end of Module adds
            			module: "compliments",
            			position: "lower_third"
            • cruunnerrC
              cruunnerr
              @sheddingmyskin said in MMM-GoogleMapsTraffic:
                                          lat: '30.00000',
                                          lng: '-90.000000',
              This is wrong. Must look like this:
              lat: 30.00000,
              lng: -90.000000,
              Without the ’
                sheddingmyskin @cruunnerr
                @cruunnerr
                Thanks! That was it. I had it like that to begin with, but using a different fork, that did not allow the module to appear at all. I changed at some point and thought I was making progress.
                • A
                  alkank
                  Hi guys,
                  Is there anyway to change the Style of the map automaticaly according to sun like navigations systems?
                    rak @Aurelsam
                    @aurelsam asked for markers. I built this in a very generic way. Will create a pull request soon.
                      rak @rak
                      I added a pull request to the original module which adds markers and an option for transparent maps.
                      Have fun.
                      Regards
                      Ralf
                        Smotx
                          Smotx
                          when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
                          Anyone have an idea why?
                          Thanks for help.
                          • T
                            tbs86
                            Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
                            • evroomE
                              evroom
                              Read this for learning purposes:
                              https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                              If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
                              Good luck.
                              MagicMirror version: 2.37.0
                              T 2 Replies Last reply Reply Quote 1
                              • T
                                tbs86 @evroom
                                @evroom thank you i will give this a shot when i get home and post my results
                                • T
                                  tbs86 @evroom
                                  @evroom ```here is my code
                                  		header: "US Holidays",
                                  					symbol: "calendar-check-o ",
                                  	var config = {
                                          position: 'bottom_left',
                                              key: 'YOUR_KEY',
                                              lat: 37.8262306,
                                              lng: -122.2920096,
                                              height: '300px',
                                              width: '300px'
                                              styledMapType: "transparent",
                                              disableDefaultUI: true,
                                              backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                              markers: [
                                                      lat: 37.8262316,
                                                      lng: -122.2920196,
                                                      fillColor: '#9966ff'
                                  • evroomE
                                    evroom
                                    Yes, the README tricked you a bit.
                                    Remove this:
                                    var config = {
                                    and the last 2 lines:
                                    Verify with:
                                    cd ~/MagicMirror; npm run config:check
                                    • T
                                      tbs86 @evroom
                                      @evroom
                                      did what you said and did the config check and this is what i got
                                      Line 134 col 5 Unexpected ‘]’.
                                      Line 134 col 5 Expected an identifier and instead saw ‘]’.
                                      Line 134 col 6 Missing semicolon.
                                      Line 134 col 5 Unrecoverable syntax error. (95% scanned).
                                      pi@raspberrypi:~/MagicMirror $
                                      • T
                                        tbs86
                                        it says line 134 but the only thing on line 134 is a ]
                                        here is my code leading up to 134
                                            module: "MMM-EARTH",
                                            position: "bottom_center",
                                                mode: "Natural",
                                                rotateInterval: 15000,
                                                MaxWidth: "50%",
                                                MaxHeight: "50%",
                                        That is line 116 to 136 the end of my config
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @tbs86
                                          @tbs86
                                          This is your current config entry
                                          var config = {
                                                      key: 'YOUR_KEY',
                                                      lat: 37.8262306,
                                                      lng: -122.2920096,
                                                      height: '300px',
                                                      width: '300px'
                                                      markers: [
                                                              lat: 37.8262316,
                                                              lng: -122.2920196,
                                          Make it look like this or copy and paste
                                                      key: 'YOUR_KEY',
                                                      lat: 37.8262306,
                                                      lng: -122.2920096,
                                                      height: '300px',
                                                      width: '300px'
                                                      markers: [
                                                              lat: 37.8262316,
                                                              lng: -122.2920196,
                                          Props to @evroom
                                          • T
                                            tbs86 @Mykle1
                                            @mykle1 said in MMM-GoogleMapsTraffic:
                                                    key: 'YOUR_KEY',
                                                    lat: 37.8262306,
                                                    lng: -122.2920096,
                                                    height: '300px',
                                                    width: '300px'
                                                    markers: [
                                                            lat: 37.8262316,
                                                            lng: -122.2920196,
                                            still getting a error
                                            • 2 / 5
