    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 93.2k Views 28 Watching
      sprior
      I’m familiar with git, but not github as much. Since I forked your repository to make my change, then did a pull request which you accepted, I now show my repo as being one commit behind yours. How do I tell github to pull that commit, or do I just delete my repo and fork again when/if needed?
      • cruunnerrC Offline
        cruunnerr
        Hey,
        cool module but got some issues when trying to select a dark mode style.
        I wanted to look the map like in this example: https://developers.google.com/maps/documentation/javascript/styling
        well, i have tried to use your code and modify the colors. also i have tried to use the code from here: https://mapstyle.withgoogle.com
        the module always starts, but i just got the standard view on it.
        maybe you could explain a little bit more detailed how to do it. that would be great. thx
        • K Offline
          knubbl @Osyris
          @Osyris said in MMM-GoogleMapsTraffic:
          Hey guys, I figured it’s easy enough to style the map by editing the JS file. So in order to get the night mode as shown in pflodo’s post (and to disable the UI buttons) I added the following to the JS code:
          //original code
                  script.onload = function () {
                      var map = new google.maps.Map(document.getElementById("map"), {
                      	zoom: 10,
                      	center: {
                      		lat: lat,
                      		lng: lng
          //add a comma after the } above
          //new code:
          		disableDefaultUI: true,
          		styles: [
          			{elementType: 'geometry', stylers: [{color: '#242f3e'}]},
          			{elementType: 'labels.text.stroke', stylers: [{color: '#242f3e'}]},
          			{elementType: 'labels.text.fill', stylers: [{color: '#746855'}]},
          			    featureType: 'administrative.locality',
          			    stylers: [{color: '#d59563'}]
          				featureType: 'poi',
          				featureType: 'poi.park',
          			        stylers: [{color: '#263c3f'}]
          				stylers: [{color: '#6b9a76'}]
          				featureType: 'road',
          				stylers: [{color: '#38414e'}]
          				elementType: 'geometry.stroke',
          					  stylers: [{color: '#212a37'}]
          					  stylers: [{color: '#9ca5b3'}]
          				featureType: 'road.highway',
          				stylers: [{color: '#1f2835'}]
          				stylers: [{color: '#f3d19c'}]
          				featureType: 'transit',
          				stylers: [{color: '#2f3948'}]
          			        featureType: 'transit.station',
          			        featureType: 'water',
          				stylers: [{color: '#17263c'}]
          				stylers: [{color: '#515c6d'}]
          //old code again
          Have fun!
          Also, if you want to make the background black (so it looks cool on the mirror), set the first attribute ‘geometry’ to ‘#000000’.
          Try this…works 4 me
            cruunnerr
              cruunnerr
              but where to add this code?
              i typed in this in my MagicMirror/config/config.js:
                                module: 'MMM-GoogleMapsTraffic',
                                position: 'bottom_left',
                                    key: 'xxxx',
                                    lat: 50.959023,
                                    lng: 6.333991,
                                    height: '250px',
                                    width: '250px',
                                    zoom: 9,
                                    enableTraffic: true,
                                    styles: [
              				featureType: 'poi',
              and it looks like this:
              • K Offline
                knubbl
                n,o not in the config.
                u need to edit the js file (MMM-GoogleMapsTraffic.js)
                if u want just replace ur js with the code i use
                /* global Module */
                /* Magic Mirror
                 * Module: MMM-GoogleMapsTraffic
                 * By Victor Mora
                 * MIT Licensed.
                Module.register("MMM-GoogleMapsTraffic", {
                	// Module config defaults
                	defaults : {
                		lat: '',
                		lng: '',
                		height: '300px',
                		width: '300px',
                		zoom: 10,
                                mapTypeId: 'roadmap',
                	getDom: function() {
                        var lat = this.config.lat;
                        var lng = this.config.lng;
                        wrapper.setAttribute("id", "map");
                        wrapper.style.height = this.config.height;
                        wrapper.style.width = this.config.width;
                        var script = document.createElement("script");
                        script.type = "text/javascript";
                        script.src = "https://maps.googleapis.com/maps/api/js?key=" + this.config.key;
                        document.body.appendChild(script);
                	var self = this;
                            	zoom: self.config.zoom,
                                mapTypeId: self.config.mapTypeId,
                            	center: {
                            		lat: self.config.lat,
                            		lng: self.config.lng
                			//disableDefaultUI: self.config.disableDefaultUI
                			styles: [
                				featureType: 'poi',
                            var trafficLayer = new google.maps.TrafficLayer();
                            trafficLayer.setMap(map);
                		return wrapper;
                W 1 Reply Last reply Reply Quote 1
                  cruunnerr
                  Great, that worked. Thank you.
                  Another question:
                  Do you think its possible to show the map just at specific times.
                  like in this module: https://github.com/jclarke0000/MMM-MyCommute
                  so you were able to show the map just at times u need to know the traffic situation. for example i just need it Mo-Fr between 05:00-07:00 am and on Fr between 02:00-08:00 pm and Sa-So between 09:00am-02:00pm.
                  its just an idea. Anyhow its a great module that worked now really fine for me :)
                  • K Offline
                    knubbl @cruunnerr
                    @cruunnerr
                    try mmm-scheduler . this is a modul which gives u the opportunity to schedule all modules to show and hide to a spedific time.
                    nice if u have not enough space on ur screen and want to switch between modules by time
                      Aurelsam
                      Hi everybody,
                      Do you think it would be possible to include a marker on the map to see my house on the map I display?
                        sheddingmyskin
                        Anyone else having issues with the map rendering streets / traffic /actual data rather than a blank frame? I have tried several of the forks, and they all end the same way. I have confirmed by use of MMM-Traffic that my API key is valid.
                        config.js:
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                         // added Modules
                                                position: 'bottom_right',
                                                        key: '************************',
                                                        lat: '30.00000',
                                                        lng: '-90.000000',
                                                        height: '300px',
                                                        width: '300px'
                        			module: 'MMM-Traffic',
                        			position: 'top_right',
                        			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                        				api_key: '*******',
                        				mode: 'driving',
                        				origin: '**********',
                        				destination: '*********',
                        			//	mon_destination: '116th St & Broadway, New York, NY 10027',
                        			//	fri_destination: '1 E 161st St, Bronx, NY 10451',
                        				arrival_time: '0755', //optional, but needs to be in 24 hour time if used.
                        				route_name: 'Home to Work',
                        				changeColor: true,
                        				showGreen: false,
                        				limitYellow: 5, //Greater than 5% of journey time due to traffic
                        				limitRed: 20, //Greater than 20% of journey time due to traffic
                        				traffic_model: 'pessimistic',
                        				interval: 60000, //1 minutes
                        				showWeekend: false,
                        				allTime: false,
                        				startHr: 5,
                        				endHr:   10,
                        				hideOffHours: true
                          //end of Module adds
                        			module: "compliments",
                        			position: "lower_third"
                          cruunnerr
                          @sheddingmyskin said in MMM-GoogleMapsTraffic:
                                                      lat: '30.00000',
                                                      lng: '-90.000000',
                          This is wrong. Must look like this:
                          lat: 30.00000,
                          lng: -90.000000,
                          Without the ’
                            sheddingmyskin @cruunnerr
                            @cruunnerr
                            Thanks! That was it. I had it like that to begin with, but using a different fork, that did not allow the module to appear at all. I changed at some point and thought I was making progress.
                              alkank
                              Hi guys,
                              Is there anyway to change the Style of the map automaticaly according to sun like navigations systems?
                                rak @Aurelsam
                                @aurelsam asked for markers. I built this in a very generic way. Will create a pull request soon.
                                  rak @rak
                                  I added a pull request to the original module which adds markers and an option for transparent maps.
                                  Have fun.
                                  Regards
                                  Ralf
                                    Smotx
                                      Smotx
                                      when I don’t activate this module, all my other modules work and display’s, when I activate this module, some modules are no longer displayed, such as: MMM-TPlink, MMM-CalendarExt, MMM-FreefoxMonitor.
                                      Anyone have an idea why?
                                      Thanks for help.
                                      • T Offline
                                        tbs86
                                        Every time i add this module and try to start the MM it tells me i have a syntax error and wont start any modules on my mirror.
                                        • evroomE Offline
                                          evroom
                                          Read this for learning purposes:
                                          https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
                                          If you post the config:check output and your MMM-GoogleMapsTraffic part inside config.js, I am sure someone can help you.
                                          Good luck.
                                          MagicMirror version: 2.37.0
                                          T 2 Replies Last reply Reply Quote 1
                                          • T Offline
                                            tbs86 @evroom
                                            @evroom thank you i will give this a shot when i get home and post my results
                                            • 2 / 5
