    Show notification on the MagicMirror
    11 Posts 4 Posters 8.9k Views 3 Watching
      AnduriI
      @mykle1 there is no sound ringing or similar. I think the alert module is enabled by default or is that wrong? As stated by strawberry in #2 it should be working the way it is now.
      @strawberry-3.141 I run the module with the mirror started as npm start dev but don’t see any. Here is my log:
      pi@Spieglein:~/MagicMirror $ npm start dev
      > magicmirror@2.1.3 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.1.3
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-AlarmClock.
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/[XXX]/basic.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
      {here it went black, but no notification}
      @all sorry for taking the wrong config options for the module, didn’t read them carefully. Again here my config, just in case there is something wrong with other modules influencing this:
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "MMM-AlarmClock",
                                      alarms: [
                                              {time: "21:14", days: [0,1,2,3,4,5,6], title: "Test", message: "Es geht!!!"},
                              module: "clock",
                              position: "top_left"
                              header: "Termine",
                                                      symbol: "calendar-check-o ",
                                                      url: "https://calendar.google.com/calendar/ical/[XXX]$
      some more modules, but all standard without any changes
      Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @AnduriI
        @AnduriI said in Show notification on the MagicMirror:
        Well, some people change things. For instance, you put a position for the alert module. I’ve never seen that done before. Have you changed or added anything else to the module files? alarm sound? any of the defaults in the js file?
        Does your mirror work when you remove the AlarmClock entry?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @AnduriI
          @AnduriI I was more interested in the logs from the developer console in electron, because you said everything is working fine until the alarm goes off, so i guess there is a javascript exception in a render process
            I had plans for an alarm clock as soon as my brother gave me his old, “useless” 10 inch netbook. Started messing around with it just to see what I could do with it and to see if I had any issues with installation. Made a few modifications as well.
            https://youtu.be/aU1sDPC1Qpw
              AnduriI
              @strawberry-3.141 well didn’t knew that… how do I get the dev console in electron? For installation I have the RPI sitting on my desktop and access it from my normal pc. But I think I can also run it on the rpi using vnc.
              @Mykle1 the mirror itself is working fine. It’s only the alarm module making all black on alert. I have not changed anything else, it is a fresh installation of jessie.
