    Need help with making the rasberry pi start up delayed
    8 Posts 3 Posters 3.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @danwitz65
      @danwitz65
      Turn the tv on first?
        danwitz65
        Its all plugged in to an fancy three way extension cord so when i plug in the “mirrors” cord it powers the tv and pi.
        But the pi starts to run right away while the tv i have to push the button ive seen people that delay them and ive seen the code but i dont know how to get to where to put it or what commands to run.
          danwitz65
          https://www.raspberrypi.org/documentation/configuration/config-txt/boot.md
          Here the link where ive seen it
          If you scroll down you see the codes but i have nonidea how to command them in terminal. Can you walk me through that
          • dorfman2D Offline
            dorfman2
            Did you utilize pm2 as part of your setup? Possibly you could use;
            pm2 start mm --start-delay {time in milliseconds}
            *disclaimer, I haven’t tested this.
              danwitz65
              I did use pm2 but even with pm2 it dont work right itll start up show magic mirrors loading screen then go to raspbian desktop where i have to enter pmstart mm.sh or whatever and then itll load just fine thats also been a struggle that was never resolved that i have coped with tho however
