    MMM-SwissTransport
    transportation
    17 Posts 7 Posters 15.8k Views 9 Watching
    • floooF
      flooo @Bangee
      @Bangee is the first version of this module still around?
      I prefer the old versions style as it looks ‘cleaner’…
      If this version doesn’t exist anymore, is it a load of stuff I would have to change to create that look in the new version? :D
      KirAsh4K 1 Reply Last reply
      • KirAsh4K
        KirAsh4 Moderator @flooo
        @flooo, you can look at the repository’s commit history (https://github.com/Bangee44/MMM-swisstransport/commits/master), and then checkout a specific revision by using the SHA1: git checkout <sha1> Note that you may need to use the full sha1 value, not the truncated one.
        For example, the last commit on May 3rd is 146a6ce. If you click on that, it expands that commit and you can see the full sha1 value as 146a6cec2aaa5007255cb157ed415ba180639354 in the upper right. So your checkout command then becomes:
        git checkout 146a6cec2aaa5007255cb157ed415ba180639354
        This is of course done from INSIDE the module’s folder!
        • KirAsh4K
          KirAsh4 Moderator
          Oh, I just noticed that his post where he said he change it was also done on May 3rd … so perhaps that original version no longer exists, which sort of defeats the purpose of using git …
          • BangeeB
            Bangee Module Developer
            I think you would like to use this one.
            • floooF
              flooo
              cool, thanks a lot
              • kwyjibo089K
                kwyjibo089
                Great module. Already added it to my mirror. Is there any chance I could filter the list and display only trains? If I put in my Station (Wädenswil) I get lots of busses and also boats.
                • BangeeB
                  @kwyjibo089, yes it’s possible:
                  change the line function getParams() like this:
                  	/* getParams()
                  	 * Generates an url with api parameters based on the config.
                  	 * return String - URL params.
                  	getParams: function() {
                  		var params = "?";
                                  params += "id=" + this.config.id;
                  		params += "&limit=" + this.config.maximumEntries;
                                  params += "&transportations[]=ec_ic&transportations[]=s_sn_r&transportations[]=ir&transportations[]=re_d&transportations[]=ice_tgv_rj";
                  		return params;
                  The line params += "&transportations[]=ec_ic&transportations[]=s_sn_r..."; is new an should allow you to filter the transportation object.
                  Here are all option:
                  transportations
                  Transportation means; one or more of ice_tgv_rj, ec_ic, ir, re_d, ship, s_sn_r, bus, cableway, arz_ext, tramway_underground
                  example:
                  &transportations[]=ec_ic&transportations[]=bus
                  Source: http://transport.opendata.ch/docs.html#section
                  It’s not testet yet, but I think it should work for you.
                  Have fun,
                  Gruss aus Oberrieden :-)
                  kwyjibo089K 1 Reply Last reply
                  • kwyjibo089K
                    kwyjibo089 @Bangee
                    nice, works like a charm! thanks a lot!
                    • BangeeB
                      I’ve made an update. Now it works with a node_helper.js so you will have less problems with CORS errors.
                      Have fun
                        mydiva
                        Hi @Bangee
                        Now it stays with connection and shows nothing else. I tried a clean install of the module but it did’t work anymore.
                          BenGig
                          Has the station ID based data source been dropped by search.ch? Connections are not so convenient as station departure times. I have a bus stop nearby and want do display all departures, one particular connection is not informative enough.
                          • V
                            vanhoekd
                            Departure times have not been dropped by Search.ch. I had the same Issue as BenGig and then just reverted to the old version, which is still working.
                            • kwyjibo089K
                              kwyjibo089 @vanhoekd
                              @vanhoekd said in MMM-SwissTransport:
                              how do you do that?
                              • V
                                vanhoekd
                                Use
                                git checkout sha1
                                to check out a particular commit.
                                where sha1 is the number of the commit on this site: Git repo
