    MMM-SwissTransport
    transportation
    17 Posts 7 Posters 15.8k Views 9 Watching
    • KirAsh4K
      KirAsh4 Moderator
      Oh, I just noticed that his post where he said he change it was also done on May 3rd … so perhaps that original version no longer exists, which sort of defeats the purpose of using git …
      • BangeeB
        Bangee Module Developer
        I think you would like to use this one.
        https://github.com/Bangee44/MMM-swisstransport
        • floooF
          flooo
          cool, thanks a lot
          • kwyjibo089K
            kwyjibo089
            Great module. Already added it to my mirror. Is there any chance I could filter the list and display only trains? If I put in my Station (Wädenswil) I get lots of busses and also boats.
            • BangeeB
              @kwyjibo089, yes it’s possible:
              change the line function getParams() like this:
              	/* getParams()
              	 * Generates an url with api parameters based on the config.
              	 * return String - URL params.
              	getParams: function() {
              		var params = "?";
                              params += "id=" + this.config.id;
              		params += "&limit=" + this.config.maximumEntries;
                              params += "&transportations[]=ec_ic&transportations[]=s_sn_r&transportations[]=ir&transportations[]=re_d&transportations[]=ice_tgv_rj";
              		return params;
              The line params += "&transportations[]=ec_ic&transportations[]=s_sn_r..."; is new an should allow you to filter the transportation object.
              Here are all option:
              transportations
              Transportation means; one or more of ice_tgv_rj, ec_ic, ir, re_d, ship, s_sn_r, bus, cableway, arz_ext, tramway_underground
              example:
              &transportations[]=ec_ic&transportations[]=bus
              Source: http://transport.opendata.ch/docs.html#section
              It’s not testet yet, but I think it should work for you.
              Have fun,
              Gruss aus Oberrieden :-)
              kwyjibo089K 1 Reply Last reply
              • kwyjibo089K
                kwyjibo089 @Bangee
                nice, works like a charm! thanks a lot!
                • BangeeB
                  I’ve made an update. Now it works with a node_helper.js so you will have less problems with CORS errors.
                  Have fun
                    mydiva
                    Hi @Bangee
                    Now it stays with connection and shows nothing else. I tried a clean install of the module but it did’t work anymore.
                      BenGig
                      Has the station ID based data source been dropped by search.ch? Connections are not so convenient as station departure times. I have a bus stop nearby and want do display all departures, one particular connection is not informative enough.
                      • V
                        vanhoekd
                        Departure times have not been dropped by Search.ch. I had the same Issue as BenGig and then just reverted to the old version, which is still working.
                        • kwyjibo089K
                          kwyjibo089 @vanhoekd
                          @vanhoekd said in MMM-SwissTransport:
                          how do you do that?
                          • V
                            vanhoekd
                            Use
                            git checkout sha1
                            to check out a particular commit.
                            where sha1 is the number of the commit on this site: Git repo
