Blank Screen - MagicMirror Fresh Install
8 Posts 2 Posters 2.6k Views 2 Watching
    ryosshii
    Hi everyone, I just tried installing the MagicMirror module and when I started the module using npm start nothing shows up and all I can see is a black screen.
    Has anyone ran into this problem before? Any help would be much appreciated.
    Thank you!
    M 1 Reply Last reply Dec 22, 2017, 12:47 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @ryosshii
      @ryosshii
      Are there any errors in your terminal or console?
      R 1 Reply Last reply Dec 22, 2017, 12:49 AM Reply Quote 0
        ryosshii @Mykle1
        @Mykle1 no errors, I’m trying to manually install it using your tutorial I’ll let you know if i run into the same problem.
        M 1 Reply Last reply Dec 22, 2017, 12:50 AM Reply Quote 0
          @ryosshii
          Ok, take your time. Good luck.
            ryosshii
            just finished the install, however im still running into the same problem
            > magicmirror@2.1.3 start /home/pi/MagicMirror
            > sh run-start.sh
            Starting MagicMirror: v2.1.3
            Loading config ...
            Loading module helpers ...
            All module helpers loaded.
            Server started ...
            Starting module: newsfeed
            Launching application.
            im stuck, it seems like its running fine but im still getting a black screen.
            M 1 Reply Last reply Dec 22, 2017, 1:22 AM Reply Quote 0
              @ryosshii
              Your monitor is directly connected to the Pi?
              R 1 Reply Last reply Dec 22, 2017, 1:26 AM Reply Quote 0
                ryosshii @Mykle1
                @Mykle1 yes it is but I am using VNC Viewer to input commands from my laptop.
                M 1 Reply Last reply Dec 22, 2017, 1:35 AM Reply Quote 0
                  @ryosshii
                  Sounds like you’re in node server only mode. Try running DISPLAY=:0 npm start through VNC.
                  Also, after you launch MM but it doesn’t appear, try opening a browser window on your laptop and entering 192.168.1.1:8080 (but you would put the IP address of your Pi in place of 192.168.1.1)
