    Blank Screen - MagicMirror Fresh Install
    8 Posts 2 Posters 3.0k Views 2 Watching
      ryosshii
      Hi everyone, I just tried installing the MagicMirror module and when I started the module using npm start nothing shows up and all I can see is a black screen.
      Has anyone ran into this problem before? Any help would be much appreciated.
      Thank you!
        Mykle1 Project Sponsor Module Developer @ryosshii
        @ryosshii
        Are there any errors in your terminal or console?
          ryosshii @Mykle1
          @Mykle1 no errors, I’m trying to manually install it using your tutorial I’ll let you know if i run into the same problem.
            @ryosshii
            Ok, take your time. Good luck.
              ryosshii
              just finished the install, however im still running into the same problem
              > magicmirror@2.1.3 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.1.3
              Loading config ...
              Loading module helpers ...
              All module helpers loaded.
              Server started ...
              Starting module: newsfeed
              Launching application.
              im stuck, it seems like its running fine but im still getting a black screen.
                @ryosshii
                Your monitor is directly connected to the Pi?
                  ryosshii @Mykle1
                  @Mykle1 yes it is but I am using VNC Viewer to input commands from my laptop.
                    @ryosshii
                    Sounds like you’re in node server only mode. Try running DISPLAY=:0 npm start through VNC.
                    Also, after you launch MM but it doesn’t appear, try opening a browser window on your laptop and entering 192.168.1.1:8080 (but you would put the IP address of your Pi in place of 192.168.1.1)
