    Stocks
    36 Posts 15 Posters 39.9k Views 14 Watching
    • Mitch1138M Offline
      Mitch1138
      Several weeks ago this module seemed to stop working. It doesn’t generate any errors, just won’t display. Has anyone else seen this?
      Thanks, Dave
      P Mykle1M 2 Replies Last reply Reply Quote 0
        pugsly @Mitch1138
        @Mitch1138 Yes same for me, this module no longer works.
          Mykle1 Project Sponsor Module Developer @Mitch1138
          @Mitch1138 said in Stocks: > Has anyone else seen this?
          @pugsly > Yes same for me, this module no longer works.
          At first glance, putting the url into a browser results in a 404 error
          http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB
          homebrewH 1 Reply Last reply Reply Quote 0
          • cowboysdudeC Offline
            The url in the module no longer works… it won’t give an error it’s a 404 error…
            I’m seeing if I can find a url replacement…
            • homebrewH Offline
              homebrew @alexyak
              @alexyak
              can’t seem to get this updating on the MM display, any ideas? Was there any change to the original code?
              G 1 Reply Last reply Reply Quote 1
              • homebrewH Offline
                homebrew @cowboysdude
                @cowboysdude
                Did you find a working URL replacement?
                Have you been using another Stocks module instead?
                  cowboysdude Module Developer @homebrew
                  @homebrew No sorry I haven’t. I don’t use stock modules :) I don’t do stocks LOL
                  BUT if you can find a url that works I can look at the module for you…
                  • homebrewH Offline
                    homebrew @Mykle1
                    @Mykle1
                    have you found a replacement url or just using another stocks module?
                      Mykle1 Project Sponsor Module Developer @homebrew
                      @homebrew
                      Like @cowboysdude, I don’t use stock modules. My interest in this topic was to troubleshoot for @Mitch1138 3 months ago. The API that was being used is no longer available. Cowboysdude and I both looked for a free API but there didn’t seem to be one available at the time.
                      If you can find a free API then I’ll certainly collaborate with Cowboysdude if he wanted some assistance
                      • G Offline
                        goofy @homebrew
                        @homebrew
                        i’m too - i can’t see anything on my display if i use the Stocks module.
                        I‘m useing mm 2.2.1 on a raspberry pi.
                          alexyak @goofy
                          I’ve found a web service which provides free intraday stock quotes. You will only need to register to get an API key.
                          https://www.alphavantage.co/support/#api-key
                          The code in the module will need to be modified though to parse a different payload result. I will try to update it today or tomorrow.
                          G 1 Reply Last reply Reply Quote 3
                          • G Offline
                            goofy @alexyak
                            @alexyak
                            Many Thanks - i‘m looking forward.
                            If you update your code - i will Test it ;)
                              alexyak @goofy
                              I’ve updated the code to support the new API’s from https://iextrading.com/developer/docs/#stocks. Which BTW, doesn’t even require registration.
                                shep99
                                Alexyak this is great thanks! The iex API seems to only support US stocks. Any chance of integrating Alphavantage into this great module? Would love to get some CDN ( TSX ) stocks into it
                                Thanks!
                                  Mitch1138
                                  Many thanks for all your work Alexyak. I can’t seem to get the stock to display. I am using the default configuration file and this is display on the terminal during execution:
                                  Connecting socket for: stocks
                                  stocks helper started ...
                                  Launching application.
                                  url:https://api.iextrading.com/1.0/stock/.DJI/quote
                                  url:https://api.iextrading.com/1.0/stock/MSFT/quote
                                  url:https://api.iextrading.com/1.0/stock/AAPL/quote
                                  url:https://api.iextrading.com/1.0/stock/GOOG/quote
                                  url:https://api.iextrading.com/1.0/stock/INTC/quote
                                  url:https://api.iextrading.com/1.0/stock/CICS/quote
                                  url:https://api.iextrading.com/1.0/stock/TSLA/quote
                                  url:https://api.iextrading.com/1.0/stock/FB/quote
                                  Any suggestions?
                                  Thanks, Mitch
                                  • G Offline
                                    goofy
                                    Me too - i do not see anything on my display.
                                    I use the default config too.
                                      alexyak
                                      There are a few symbols that don’t exist. Remove .DJI and CICS
                                        Mitch1138
                                        Thanks again, that fixed it (although the DJI would be nice…).
                                        I really appreciate your efforts.
                                        Mitch
                                          shep99
                                          Awesome, and chance of getting alpha api to work for Canadian Stocks? ;) Thanks
                                            stevegoble @shep99
                                            @shep99
                                            This.
