    Stocks
    36 Posts 15 Posters 40.3k Views 14 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Mitch1138
      @Mitch1138 said in Stocks: > Has anyone else seen this?
      @pugsly > Yes same for me, this module no longer works.
      At first glance, putting the url into a browser results in a 404 error
      http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB
      homebrewH 1 Reply Last reply
      • cowboysdudeC
        The url in the module no longer works… it won’t give an error it’s a 404 error…
        I’m seeing if I can find a url replacement…
        • homebrewH
          homebrew @alexyak
          @alexyak
          can’t seem to get this updating on the MM display, any ideas? Was there any change to the original code?
          G 1 Reply Last reply
          • homebrewH
            homebrew @cowboysdude
            @cowboysdude
            Did you find a working URL replacement?
            Have you been using another Stocks module instead?
            • cowboysdudeC
              cowboysdude Module Developer @homebrew
              @homebrew No sorry I haven’t. I don’t use stock modules :) I don’t do stocks LOL
              BUT if you can find a url that works I can look at the module for you…
              Reply Quote 2
              • homebrewH
                homebrew @Mykle1
                @Mykle1
                have you found a replacement url or just using another stocks module?
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @homebrew
                  @homebrew
                  Like @cowboysdude, I don’t use stock modules. My interest in this topic was to troubleshoot for @Mitch1138 3 months ago. The API that was being used is no longer available. Cowboysdude and I both looked for a free API but there didn’t seem to be one available at the time.
                  If you can find a free API then I’ll certainly collaborate with Cowboysdude if he wanted some assistance
                  • G
                    goofy @homebrew
                    @homebrew
                    i’m too - i can’t see anything on my display if i use the Stocks module.
                    I‘m useing mm 2.2.1 on a raspberry pi.
                    A 1 Reply Last reply
                    • A
                      alexyak @goofy
                      I’ve found a web service which provides free intraday stock quotes. You will only need to register to get an API key.
                      https://www.alphavantage.co/support/#api-key
                      The code in the module will need to be modified though to parse a different payload result. I will try to update it today or tomorrow.
                      Reply Quote 3
                      • G
                        goofy @alexyak
                        @alexyak
                        Many Thanks - i‘m looking forward.
                        If you update your code - i will Test it ;)
                        • A
                          alexyak @goofy
                          I’ve updated the code to support the new API’s from https://iextrading.com/developer/docs/#stocks. Which BTW, doesn’t even require registration.
                          Reply Quote 2
                            shep99
                            Alexyak this is great thanks! The iex API seems to only support US stocks. Any chance of integrating Alphavantage into this great module? Would love to get some CDN ( TSX ) stocks into it
                            Thanks!
                            Reply Quote 2
                            • Mitch1138M
                              Mitch1138
                              Many thanks for all your work Alexyak. I can’t seem to get the stock to display. I am using the default configuration file and this is display on the terminal during execution:
                              Connecting socket for: stocks
                              stocks helper started ...
                              Launching application.
                              url:https://api.iextrading.com/1.0/stock/.DJI/quote
                              url:https://api.iextrading.com/1.0/stock/MSFT/quote
                              url:https://api.iextrading.com/1.0/stock/AAPL/quote
                              url:https://api.iextrading.com/1.0/stock/GOOG/quote
                              url:https://api.iextrading.com/1.0/stock/INTC/quote
                              url:https://api.iextrading.com/1.0/stock/CICS/quote
                              url:https://api.iextrading.com/1.0/stock/TSLA/quote
                              url:https://api.iextrading.com/1.0/stock/FB/quote
                              Any suggestions?
                              Thanks, Mitch
                              • G
                                goofy
                                Me too - i do not see anything on my display.
                                I use the default config too.
                                • A
                                  alexyak
                                  There are a few symbols that don’t exist. Remove .DJI and CICS
                                  • Mitch1138M
                                    Mitch1138
                                    Thanks again, that fixed it (although the DJI would be nice…).
                                    I really appreciate your efforts.
                                    Mitch
                                      shep99
                                      Awesome, and chance of getting alpha api to work for Canadian Stocks? ;) Thanks
                                        stevegoble @shep99
                                        @shep99
                                        This.
                                          stevegoble @alexyak
                                          @alexyak said in Stocks:
                                          I also was having many issues. This page will allow you to search for ticker symbols this api supports.
                                          Until Alphavantage is supported anyway…they even have cryptocurrency on theirs…
                                          • G
                                            goofy
                                            Hello, it work fine - but anybody knows a other API with includes more Country’s ?
                                            For example, i want to add German Stocks too.
