    Stocks
    36 Posts 15 Posters 40.8k Views 14 Watching
    • A
      alexyak
      Here’s a basic scrolling stocks ticker module. You can get it from here:
      https://github.com/alexyak/stocks
      This is how it looks:
      homebrewH 1 Reply Last reply
        A Former User
        • L
          lb-rezende
          Is it possible to check currency rates using this module?
          • Z
            ZTA0796
            Great module! I’m currently modifying it for some visual changes as well as trying to get it to pull yahoo finance data instead of google. The reason for that is that Yahoo also lists commodities (crude oil, corn, etc).
            I’ve gotten what I think is most of it done, but I’m getting an error on the node_helper.js module. I’m relatively new to node, but can someone explain why if I change the URL in the code to a yahoo URL that also spits back a JSON file, that it gives me an “unexpected token u in JSON at position 0”?
            For reference, the yahoo URL is: https://query.yahooapis.com/v1/public/yql?q=select * from csv where url%3D'http%3A%2F%2Fdownload.finance.yahoo.com%2Fd%2Fquotes.csv%3Fs%3DMSFT,AAPL%26f%3Dsl1d1t1c1ohgv%26e%3D.csv' and columns%3D'symbol%2Cprice%2Cdate%2Ctime%2Cchange%2Ccol1%2Chigh%2Clow%2Ccol2'&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys
            Thanks!
            A 1 Reply Last reply
            • A
              alexyak @ZTA0796
              @ZTA0796 The original code does a hardcoded substring on the result:
              var result = JSON.parse(body.substring(3, body.length));
              You probably don’t need to do that.
              Z 2 Replies Last reply
              • Z
                ZTA0796 @alexyak
                • Z
                  ZTA0796 @alexyak
                  @alexyak Thanks! I have one more question about syntax that I’m having trouble with.
                  I can pull the Yahoo JSON into the node_helper file and print it to the terminal without a problem. But when I try to reference it in the “getDom” function, I get nothing. I haven’t changed the code at the start of that function at all. But when it runs “this.result.length”, the length returned is 0.
                  I’m not super-familiar with the “this” syntax, but was hoping you or someone else might have an idea of why the JSON you pass would work, but not the JSON that I pass?
                  Thanks!
                    chrisfoerg
                    great! would also be good for rss feeds :-)
                    • A
                      alexyak @ZTA0796
                      @ZTA0796 Could you show your code?
                      Z 1 Reply Last reply
                      • Z
                        ZTA0796 @alexyak
                        @alexyak Sure…see below.
                        In the node_helper.js:
                        getStocks: function (url) {
                        var self = this;
                          request({ url: url, method: 'GET' }, function (error, response, body) {
                              if (!error && response.statusCode == 200) {
                                  var result = JSON.parse(body);
                                  console.log(result.query.results.row);  //prints the JSON as expected to the terminal
                                  self.sendSocketNotification('STOCKS_RESULT', result);
                        //Subclass socketNotificationReceived received.
                        if (notification === ‘GET_STOCKS’) {
                        this.getStocks(payload);
                        in stocks.js:
                        getDom: function() {
                            var wrapper = document.createElement("table");
                            wrapper.className = 'normal regular small';
                            var count = 0;
                            var _this = this;
                        	console.log("in the DOM function");
                        	console.log("result is " + this);  //prints [object Object]
                        	console.log("result is " + _this); //prints [object Object]
                        	console.log("result length is " + this.result.length); //prints 0
                            if (this.result.length > 0){
                                this.result.forEach(function(stock) {
                        			//since length=0, it never gets in this loop
                        scheduleUpdate: function(delay) {
                        	console.log("scheduled update check");
                        	var nextLoad = this.config.updateInterval;
                        	if (typeof delay !== "undefined" && delay >= 0) {
                        		nextLoad = delay;
                        	var self = this;
                        	setInterval(function() {
                        		self.getStocks();
                        	}, nextLoad);
                        roundValue: function(value) {
                           return Math.round(value*100)/100;
                        getStocks: function () {
                            var url = 'https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20csv%20where%20url%3D%27http%3A%2F%2Fdownload.finance.yahoo.com%2Fd%2Fquotes.csv%3Fs%3D' + this.config.stocks + '%26f%3Dsl1d1t1c1ohgv%26e%3D.csv%27%20and%20columns%3D%27symbol%2Cprice%2Cdate%2Ctime%2Cchange%2Ccol1%2Chigh%2Clow%2Ccol2%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys';
                            this.sendSocketNotification('GET_STOCKS', url);
                            if (notification === "STOCKS_RESULT") {
                        		console.log("notification received");
                        		console.log(payload);  //prints Object { query: Object }
                                this.result = payload;
                                this.updateDom(self.config.fadeSpeed);
                        • Z
                          ZTA0796
                          Upon looking at it further-- in the “socketNotificationReceived: function(notification, payload)” function in the module.js file, it seems that when I run console.log(this.result), it outputs my JSON:
                          Object { symbol: “MSFT”, price: “62.30”, date: “12/16/2016”, time: “4:00pm”, change: “-0.28”, col1: “62.95”, high: “62.95”, low: “62.12”, col2: “42453083” }
                          When I go to the “getDom” function and run “console.log(this.result)”, I get:
                          [object Object]
                          I’m just not sure why that change occurs, but that seems to be my issue. Any help is massively appreciated!
                          • A
                            alexyak @ZTA0796
                            @ZTA0796 The object that you get int the stocks.js is the deserialized javascript object. In your case it’s going to be a single row object. You could just access the properties list this:
                            this.result.symbol, this.result.price, etc…
                            -Alex
                            • Z
                              ZTA0796 @alexyak
                              @alexyak So that’s what I expected as well. Unfortunately, it is somehow getting messed up between the “socketNotificationReceived” function and the “getDom” function.
                                      console.log(this.result);  //prints my JSON correctly console
                              So the above works correctly. Below, however, it doesn’t seem to maintain and I can’t figure out why.
                                  var count = 0;
                                  var _this = this;
                              	console.log("result is " + this.result); //prints "result is [object Object]"
                              	console.log("result length is " + this.result.length); //prints "result length is 0"
                              	console.log(this.symbol);  //prints "undefined"
                              I apologize if I’m being thick, but I can’t figure out why it’s not working…
                              • Z
                                ZTA0796
                                Ok, so I think i figured it out. Still not sure why it worked, but for some reason, running a console.log("descriptive text " + this) seems to corrupt or change the type of “this”. If I put two consecutive console.log() calls–first with descriptive text, second with just “this”–then it works. Basically in the example above, if I just comment out the first two console.log() calls, then it no longer prints “undefined” and instead prints “MSFT”. Sorry for all the trouble!
                                • Mitch1138M
                                  Mitch1138
                                  Several weeks ago this module seemed to stop working. It doesn’t generate any errors, just won’t display. Has anyone else seen this?
                                  Thanks, Dave
                                  pugslyP Mykle1M 2 Replies Last reply
                                  • pugslyP
                                    pugsly @Mitch1138
                                    @Mitch1138 Yes same for me, this module no longer works.
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Mitch1138
                                      @Mitch1138 said in Stocks: > Has anyone else seen this?
                                      @pugsly > Yes same for me, this module no longer works.
                                      At first glance, putting the url into a browser results in a 404 error
                                      http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB
                                      • cowboysdudeC
                                        The url in the module no longer works… it won’t give an error it’s a 404 error…
                                        I’m seeing if I can find a url replacement…
                                        • homebrewH
                                          homebrew @alexyak
                                          @alexyak
                                          can’t seem to get this updating on the MM display, any ideas? Was there any change to the original code?
                                          G 1 Reply Last reply
                                          • homebrewH
                                            homebrew @cowboysdude
                                            @cowboysdude
                                            Did you find a working URL replacement?
                                            Have you been using another Stocks module instead?
