    Stocks
    36 Posts 15 Posters 40.3k Views 14 Watching
    • Z
      ZTA0796 @alexyak
      @alexyak Thanks! I have one more question about syntax that I’m having trouble with.
      I can pull the Yahoo JSON into the node_helper file and print it to the terminal without a problem. But when I try to reference it in the “getDom” function, I get nothing. I haven’t changed the code at the start of that function at all. But when it runs “this.result.length”, the length returned is 0.
      I’m not super-familiar with the “this” syntax, but was hoping you or someone else might have an idea of why the JSON you pass would work, but not the JSON that I pass?
      Thanks!
        chrisfoerg
        great! would also be good for rss feeds :-)
        • A
          alexyak @ZTA0796
          @ZTA0796 Could you show your code?
          Z 1 Reply Last reply Reply Quote 0
          • Z
            ZTA0796 @alexyak
            @alexyak Sure…see below.
            In the node_helper.js:
            getStocks: function (url) {
            var self = this;
              request({ url: url, method: 'GET' }, function (error, response, body) {
                  if (!error && response.statusCode == 200) {
                      var result = JSON.parse(body);
                      console.log(result.query.results.row);  //prints the JSON as expected to the terminal
                      self.sendSocketNotification('STOCKS_RESULT', result);
            //Subclass socketNotificationReceived received.
            if (notification === ‘GET_STOCKS’) {
            this.getStocks(payload);
            in stocks.js:
            getDom: function() {
                var wrapper = document.createElement("table");
                wrapper.className = 'normal regular small';
                var count = 0;
                var _this = this;
            	console.log("in the DOM function");
            	console.log("result is " + this);  //prints [object Object]
            	console.log("result is " + _this); //prints [object Object]
            	console.log("result length is " + this.result.length); //prints 0
                if (this.result.length > 0){
                    this.result.forEach(function(stock) {
            			//since length=0, it never gets in this loop
            scheduleUpdate: function(delay) {
            	console.log("scheduled update check");
            	var nextLoad = this.config.updateInterval;
            	if (typeof delay !== "undefined" && delay >= 0) {
            		nextLoad = delay;
            	var self = this;
            	setInterval(function() {
            		self.getStocks();
            	}, nextLoad);
            roundValue: function(value) {
               return Math.round(value*100)/100;
            getStocks: function () {
                var url = 'https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20csv%20where%20url%3D%27http%3A%2F%2Fdownload.finance.yahoo.com%2Fd%2Fquotes.csv%3Fs%3D' + this.config.stocks + '%26f%3Dsl1d1t1c1ohgv%26e%3D.csv%27%20and%20columns%3D%27symbol%2Cprice%2Cdate%2Ctime%2Cchange%2Ccol1%2Chigh%2Clow%2Ccol2%27&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys';
                this.sendSocketNotification('GET_STOCKS', url);
                if (notification === "STOCKS_RESULT") {
            		console.log("notification received");
            		console.log(payload);  //prints Object { query: Object }
                    this.result = payload;
                    this.updateDom(self.config.fadeSpeed);
            • Z
              ZTA0796
              Upon looking at it further-- in the “socketNotificationReceived: function(notification, payload)” function in the module.js file, it seems that when I run console.log(this.result), it outputs my JSON:
              Object { symbol: “MSFT”, price: “62.30”, date: “12/16/2016”, time: “4:00pm”, change: “-0.28”, col1: “62.95”, high: “62.95”, low: “62.12”, col2: “42453083” }
              When I go to the “getDom” function and run “console.log(this.result)”, I get:
              [object Object]
              I’m just not sure why that change occurs, but that seems to be my issue. Any help is massively appreciated!
              • A
                alexyak @ZTA0796
                @ZTA0796 The object that you get int the stocks.js is the deserialized javascript object. In your case it’s going to be a single row object. You could just access the properties list this:
                this.result.symbol, this.result.price, etc…
                -Alex
                • Z
                  ZTA0796 @alexyak
                  @alexyak So that’s what I expected as well. Unfortunately, it is somehow getting messed up between the “socketNotificationReceived” function and the “getDom” function.
                          console.log(this.result);  //prints my JSON correctly console
                  So the above works correctly. Below, however, it doesn’t seem to maintain and I can’t figure out why.
                      var count = 0;
                      var _this = this;
                  	console.log("result is " + this.result); //prints "result is [object Object]"
                  	console.log("result length is " + this.result.length); //prints "result length is 0"
                  	console.log(this.symbol);  //prints "undefined"
                  I apologize if I’m being thick, but I can’t figure out why it’s not working…
                  • Z
                    ZTA0796
                    Ok, so I think i figured it out. Still not sure why it worked, but for some reason, running a console.log("descriptive text " + this) seems to corrupt or change the type of “this”. If I put two consecutive console.log() calls–first with descriptive text, second with just “this”–then it works. Basically in the example above, if I just comment out the first two console.log() calls, then it no longer prints “undefined” and instead prints “MSFT”. Sorry for all the trouble!
                    • Mitch1138M
                      Mitch1138
                      Several weeks ago this module seemed to stop working. It doesn’t generate any errors, just won’t display. Has anyone else seen this?
                      Thanks, Dave
                      P Mykle1M 2 Replies Last reply Reply Quote 0
                        pugsly @Mitch1138
                        @Mitch1138 Yes same for me, this module no longer works.
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Mitch1138
                          @Mitch1138 said in Stocks: > Has anyone else seen this?
                          @pugsly > Yes same for me, this module no longer works.
                          At first glance, putting the url into a browser results in a 404 error
                          http://finance.google.com/finance/info?client=ig&q=.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB
                          homebrewH 1 Reply Last reply Reply Quote 0
                          • cowboysdudeC
                            The url in the module no longer works… it won’t give an error it’s a 404 error…
                            I’m seeing if I can find a url replacement…
                            • homebrewH
                              homebrew @alexyak
                              @alexyak
                              can’t seem to get this updating on the MM display, any ideas? Was there any change to the original code?
                              G 1 Reply Last reply Reply Quote 1
                              • homebrewH
                                homebrew @cowboysdude
                                @cowboysdude
                                Did you find a working URL replacement?
                                Have you been using another Stocks module instead?
                                • cowboysdudeC
                                  cowboysdude Module Developer @homebrew
                                  @homebrew No sorry I haven’t. I don’t use stock modules :) I don’t do stocks LOL
                                  BUT if you can find a url that works I can look at the module for you…
                                  • homebrewH
                                    homebrew @Mykle1
                                    @Mykle1
                                    have you found a replacement url or just using another stocks module?
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @homebrew
                                      @homebrew
                                      Like @cowboysdude, I don’t use stock modules. My interest in this topic was to troubleshoot for @Mitch1138 3 months ago. The API that was being used is no longer available. Cowboysdude and I both looked for a free API but there didn’t seem to be one available at the time.
                                      If you can find a free API then I’ll certainly collaborate with Cowboysdude if he wanted some assistance
                                      • G
                                        goofy @homebrew
                                        @homebrew
                                        i’m too - i can’t see anything on my display if i use the Stocks module.
                                        I‘m useing mm 2.2.1 on a raspberry pi.
                                        • A
                                          alexyak @goofy
                                          I’ve found a web service which provides free intraday stock quotes. You will only need to register to get an API key.
                                          https://www.alphavantage.co/support/#api-key
                                          The code in the module will need to be modified though to parse a different payload result. I will try to update it today or tomorrow.
                                          G 1 Reply Last reply Reply Quote 3
                                          • G
                                            goofy @alexyak
                                            @alexyak
                                            Many Thanks - i‘m looking forward.
                                            If you update your code - i will Test it ;)
