Google assistant on magicmirror
@aro28 i already done all the steps mentioned in the link https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample
and it also worked fine.
But the real problem is when i start the magicmirror the google assistant does not start. How to bring the google assistant module in magicmirror? I also add the script in the config.js. In the display it shows only the image of the google assistant.
Yes. Same for me. I can see Google Logo and nothing happens on “Ok, google how’s the weather today?” No reaction.
@aro28 Please let me know once you figure it out… And thank you very much for your reply…
@nitrogen73 said in Google assistant on magicmirror:
I’ve posted my issue on below link. Please feel free and participate in discussion as well.
https://github.com/gauravsacc/MMM-GoogleAssistant/issues/18 -
@aro28 Could you please tell me what you done after completing the steps in below link?
I followed below link: https://github.com/eouia/MMM-Assistant/wiki
If you are able to launch google-assistant-demo(https://developers.google.com/assistant/sdk/prototype/getting-started-pi-python/run-sample) and use the assistant, you should able to use the ‘pi/assistant.py’ script that communicates with the magic mirror module.
@nitrogen73 Also, i register the Device Model as instructed in above link. In order for the Google Assistant to respond to commands appropriate to your device and the given context, the Assistant needs information about your particular device.
I also have problems with the operation of this module.
I posted in another post: https://forum.magicmirror.builders/topic/5575/assistant-error/8
In my case, the google icon appears but only triggers once and I do not get an answer.
I encounter the same problem with the icon of the mirror which remains stuck waiting. I have to restart the mirror.Should you also follow the steps in the link https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample
despite the fact that it is not mentioned in the wiki?Thanking you in advance for your answers.
Same problem here although mine doesn’t appear to trigger at all. I’ve gotten the sample to run. I can run assistant.py and interact but when altering the config file and running MM. Nothing but an icon at the top.
@clconner09
I was unfortunately forced to give up. After several installations, always the same problem.
I will wait to see if the developer of this great module will update soon.cordially,
@Chris A bit late but the module is updated now. Go ahead and pull the update, let me know if you are still facing issues. Happy to help!
I tried a git pull on the module MMM-Assistant but I still encounter the same problem. The voice is still jerky in English while I wish in French.
there is a good chance that I made a mistake during the installation but I can not find where.
Are you a beginning of track to communicate to me?
Thank you in advance, -
@gauravsacc First, many thanks for such an excellent effort. Unfortunately, despite having the latest and updated module version, I am having the same ‘no start’ issue in Magic Mirror as others have mentioned. I can start ‘assistant.py’ under “source env/bin/activate” and it works absolutely fine while staying in the terminal. But once in Magic Mirror, the google assistant remains unresponsive. Does ‘assistant.py’ needs to run as a script in the background at startup or is there anything else I am missing?
@hrjmsh Yes assistant.py should be running in the background
@gauravsacc Great, thanks. All working fine.
It might be a good idea to include that information in your module page at the end of instructions. It would help a lot to a novice and inexperienced like me! -
@hrjmsh sure you want to raise a pull request with this change?
I did all the current steps. GA worked. But the Smart mirror is not active. Only the GA symbol appears. I’m having trouble with assistant.py. Can you help?
See MMM-AssistantMk2
has GA and can execute actions on mirror
