    Google assistant on magicmirror
    google assistantmagicmirror
    21 Posts 8 Posters 20.9k Views 9 Watching
    • aro28A
      aro28 @nitrogen73
      @nitrogen73 said in Google assistant on magicmirror:
      @aro28 Could you please tell me what you done after completing the steps in below link?
      I followed below link: https://github.com/eouia/MMM-Assistant/wiki
      If you are able to launch google-assistant-demo(https://developers.google.com/assistant/sdk/prototype/getting-started-pi-python/run-sample) and use the assistant, you should able to use the ‘pi/assistant.py’ script that communicates with the magic mirror module.
      • aro28A
        aro28 @nitrogen73
        @nitrogen73 Also, i register the Device Model as instructed in above link. In order for the Google Assistant to respond to commands appropriate to your device and the given context, the Assistant needs information about your particular device.
        • ChrisC
          Chris
          I also have problems with the operation of this module.
          I posted in another post: https://forum.magicmirror.builders/topic/5575/assistant-error/8
          In my case, the google icon appears but only triggers once and I do not get an answer.
          I encounter the same problem with the icon of the mirror which remains stuck waiting. I have to restart the mirror.
          Should you also follow the steps in the link https://developers.google.com/assistant/sdk/guides/library/python/embed/install-sample
          despite the fact that it is not mentioned in the wiki?
          Thanking you in advance for your answers.
            clconner09
            Same problem here although mine doesn’t appear to trigger at all. I’ve gotten the sample to run. I can run assistant.py and interact but when altering the config file and running MM. Nothing but an icon at the top.
            ChrisC 1 Reply Last reply Reply Quote 0
            • ChrisC
              Chris @clconner09
              @clconner09
              I was unfortunately forced to give up. After several installations, always the same problem.
              I will wait to see if the developer of this great module will update soon.
              cordially,
              gauravsaccG 1 Reply Last reply Reply Quote 0
              • gauravsaccG
                gauravsacc Module Developer @Chris
                @Chris A bit late but the module is updated now. Go ahead and pull the update, let me know if you are still facing issues. Happy to help!
                • ChrisC
                  Chris
                  @gauravsacc
                  I tried a git pull on the module MMM-Assistant but I still encounter the same problem. The voice is still jerky in English while I wish in French.
                  there is a good chance that I made a mistake during the installation but I can not find where.
                  Are you a beginning of track to communicate to me?
                  Thank you in advance,
                  • H
                    hrjmsh @gauravsacc
                    @gauravsacc First, many thanks for such an excellent effort. Unfortunately, despite having the latest and updated module version, I am having the same ‘no start’ issue in Magic Mirror as others have mentioned. I can start ‘assistant.py’ under “source env/bin/activate” and it works absolutely fine while staying in the terminal. But once in Magic Mirror, the google assistant remains unresponsive. Does ‘assistant.py’ needs to run as a script in the background at startup or is there anything else I am missing?
                    • gauravsaccG
                      gauravsacc Module Developer @hrjmsh
                      @hrjmsh Yes assistant.py should be running in the background
                      • H
                        hrjmsh @gauravsacc
                        @gauravsacc Great, thanks. All working fine.
                        It might be a good idea to include that information in your module page at the end of instructions. It would help a lot to a novice and inexperienced like me!
                        • gauravsaccG
                          @hrjmsh sure you want to raise a pull request with this change?
                          • O
                            onurcnbs
                            I did all the current steps. GA worked. But the Smart mirror is not active. Only the GA symbol appears. I’m having trouble with assistant.py. Can you help?
                              See MMM-AssistantMk2
                              has GA and can execute actions on mirror
